Question about Danby DDW496W Free-Standing Dishwasher
Door not locking
The door just doesnt want to close, any ideas on how to fix it
Had some problem, cause was I was keeping a small air filter on top. Removed it cured my problem
Posted on Apr 20, 2008
Interior driver side door handle does not open the door and doesnt lock.
remove interior door card and inspect door handle rod to lock mechanism make sure it is connected both ends
Oct 06, 2015 | Cars & Trucks
Not locking
I had this problem also with my Maytag Neptune TL. The door lock would click multiple times before displaying the FL code. I was able to fix this by removing the left door look(the one with the door close sensor) and cleaning the 2 metal pones on top of the left door mechanism, which had rusted and no longer was able to since the door closed. I use a nail file i sure either that or sandpaper will do. After that it went through the whole cycle without stopping or displaying the "FL" code.......hope this helps
Jan 14, 2013 | Maytag Neptune MAH5500B Front Load Washer
Door on 95 geo metro 4 door won't close because the child proof lock in on and I can't get it to go off. Door won't stay shut. Any ideas how to fix this?
Your childproof lock have nothing to do with the latch not closing. It only makes it where you can not open the door from the inside. I would think you are in need of a new latch.
Feb 12, 2018 | Geo Metro Cars & Trucks
I have a 98 cherokee and the driver door doesnt lock with the remote or with the panel switch- although i can hear the motor whizzing. it will however lock manually. also, it SOMETIMES(although very...
the lock motor could be jammed or a gear inside it could be broken. best bet would be to go to a parts store or junk yard and get a new one and try that out.
Feb 23, 2010 | 1998 Jeep Cherokee
Back window doesnt roll down properly when you open the door, so I have to push it down a little before I close it. Also the lock bottom for the windows doesnt work.
dis-connect your battery for 30 seconds to do a switch reset on your window, when you reconnect the batt your window will go down, open and close rear door to check lock functions ok first. close rear door and using key or switch inside car close window fully with out stopping, this should reset the window.
Jan 05, 2010 | 2003 Land Rover Freelander
When i press the central locking on my x reg freelander it doesnt open the drivers door but will lock it with the fob any ideas whats wrong with it
Synchronization
When remote control battery replaced,or system malfunction.
Hold remote close to vehicle
Press either button of remote 5 times or more in quick succession.
Nov 13, 2009 | 2002 Land Rover Freelander
The door in a Hyundai Accent 2000 doesn't close (the lock doesn't click to keep the door closed). What can be done to fix it?
try spraying it w/ wd-40 or graphite, work the lock back and forth w/ your finger or a screwdriver. it also could be that its in the locked position now, w/ door open pull handle and see if latch moves/ opens. if it does close door. if this doesnt work go to local junk yard and pick latch up for 50.00 bucks. hope this helps
Nov 08, 2008 | Hyundai Accent Cars & Trucks
Won't start
startlight blinking? any fault codes coming up,Possible door lock issue, i fthe machine doesnt think the door is closed it wont operate at all
Feb 21, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Maytag mah8700A
ds - means that the door is open while the washer is running sometimes this can be easily fixed by opening the door then closing it and pushing it pretty firm to make sure it latches.
If that doesnt work there very well could be a problem that would need to be fixed by a service repairman you can call Maytag USA Customer Service @ (800)688-9900
hope that helps.
Jan 27, 2008 | Maytag MAH8700A Front Load Washer
Danby DDW496W Free-Standing Dishwasher Logo
77 people viewed this question
Top Danby Dishwashers Experts
Kevin Getz
Kevin Getz
Are you a Danby Dishwasher Expert? Answer questions, earn points and help others
