Question about Hitachi 51SWX20B 51" Rear Projection Television
Moving the TV
Want to move TV to lower level of home. It is down a set of stairs that are separated by a landing. It is not a straight set of stairs, it is 6 steps landing then 5 stairs
What are the minimum stariwell dimensions to allow TV to turn and make the final flight of stairs? Stairwell is 31" wide.
Suggestions welcome.....
    Sergeant:
    Champion:
  • 301 Answers
You should be fine as long as you don't drop it of course. you and turn and twist it any which way but id say measure the height of the tv because at some point you will have the top and bottom of the tv touching 2 different walls if im not mistaken
Posted on Feb 22, 2008
I have a 60 inch Mitsubishi and there are light red shadows in the tv. is this an easy fix
It sounds like you need to re-adjust your convergence. The purpose of adjusting your convergence is to align your red, green, and blue colors. Moving your TV often causes this problem. I hope you get it going.
Sep 02, 2014 | Mitsubishi WD Televison & Video
Where is shifting sand land
After beating the first Bowser level, you go to that door under the stair and then down the stairs down there. Then go to Lethal Lava Land and go left. Shifting Sand Land is that stone looking wall straight ahead. Good luck...that's one of the harder lands...
Dec 02, 2012 | Nintendo Super Mario for 64
My big screen tv is about 3 inches to big to take down my stairs into my basement. Can it be dissasembled? Are there any sketches on how to dissasemble the speakers? Thanks Don
Yes but it would be easier to widen the stairs and just moving them can stop them from working so if you decide to take it apart just be careful, Manuals are available online but non are free
Dec 02, 2010 | Samsung HLT6187SAX 61" DLP HDTV
Safely moving a neptune f/l washer
There should be Bolts that run through the back panel that hold the whole tub in place when you move the machine around. Here is a Repair Manual for your Washer. It should help you out in finding the part numbers and where they go when you get them.
Thanks
Dec 29, 2008 | Maytag Neptune MAH5500B Front Load Washer
Moving a WS 55511 downstairs in my house
Do you have friends? If so, call them and get help.
Apr 12, 2008 | Mitsubishi WS-55511 55" Rear Projection...
Double vision on my samsung HDTV 1080i
If one or more of the colors, red, green or blue have separated from each other and you can`t correct the problem using the convergence procedure as described in the users manual, that would indicate you have a convergence problem. Bad solder connections on the convergence output chips are common. If the set had a rough ride down the stairs while moving, that may have facilitated in exposing a preexisting condition. However, the most likely cause is the natural failure of one of the convergence output chips and or related components and not the move. The fix is to have a qualified technician address the problem. This is not a do it yourself job.
Feb 22, 2008 | Televison & Video
Disassemble Rear Projection TV
well the short answer is : Check the sides of the set see if there is a crack in the middle where you could separate them
Long answer: i would not recommend it even if it does, the screens are sensitive and could get dust inside the screen.
Never taken one apart that far. i suspect most tech don't because of the problems aligning and dust ect.. trying to get it back together.
Dec 13, 2007 | Philips 60PP9202 60" Rear Projection...
Moving Information
Poczekaj, not a good idea to break it down, screen assembly is veery fragile when not installed into the set, best thing to do is rent a refridgerator type dolly, wrap the front of the set with blankets and then put the dolly under the side of the tv, winch up the strap and with 2 people walk it up the stairs, one pulling the dolly the other person at the other end to push upwards, slow and easy and you`ll have no problem, if hauling in a pick-up it MUST be winched down to the bed or it will fall, (been there done that :) hope this is what you needed, more questions? feel free to e-mail me back, Happy Holidays, BMW Rider
Dec 10, 2007 | Mitsubishi WS-65809 65" Rear Projection...
Relocating tv
Yes, this set does come apart for moving. Remove the lower screw from each side of the TV back. On both sides, pull off the two plastic caps and remove the two exposed screw. Lift the cabinet top straight up until the guide pins clear the holes in the bottom cabinet. Be careful and don't drop anything.
May 03, 2007 | Mitsubishi WS-65807 65" Rear Projection...
Taking apart and moving a 55 inch projection TV
hi do this as last option! there is 30,000v inside the tv!! you can die before you even think about it the only way to do soo is unplug the T.V from the wall for a week at least (so the volt will dissolves) you can turn the tv on its side you will have a problem if it will get a slap or will fall in my opinion just take on its side....but its your decision JUST BE CAREFUL PLEASE!!! good luck
Mar 20, 2006 | Pioneer SD-P55A3-K 55" Rear Projection...
Hitachi 51SWX20B 51" Rear Projection Television Logo
163 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
