Question about Gateway Belkin 54g Wireless DSL/Cable Router (DHF5D72304)
Wireless password I need to had a password to my router connection, so other poeple can't use my internet. I know you have to put in a number in the address search bar but have lost number, not sure why the password would just stop working like this. Need to reset encryption key
  • 51 Answers
Hi
open command prompt and type ipconfig
you will have ip address and default gateway.the default gateway number is what you need to put in to the address bar and enter into the belkin router and after loggin in go the wireless setup and configure the wep and also make sure you configure the same wep in your laptop/wireless pc.
cheers !!!
Posted on Feb 13, 2008
I wuold like to know please all step to put pasword in my wireless links, because pleanty hause around and get slow because every boddy is conected in my wireless, please i need to know the way to put the...
connect to your router via cat 5 cable.
open internet explorer
browse to 192.168.1.1
login is blank password is admin
click on wireless
setup your wireless ssid network name
click on wireless security
select wpa
type in a passphase for your wireless password.
May 23, 2011 | Linksys Wireless-G WRT54G Router
Can access internet to my laptop via ethernet cable but not wifi through Cisco Linksys router model no SPA2102 as I have lost network security code... tried to find number to call for support but dont...
ok well if you lost your security code then the only way you can connect to your wireless connections again is to have the correct credentials correct Passwords .in your case you lost your Password the only options you have is to reset your router and setup new Password for your wireless . ok lets reset the wireless router now . on the back of your router their is a tiny hole says Reset use needle or a pen to press the button for 40 seconds and release turn off your wireless from the plug and turn it on again . now connect to your wireless and you will not need password to connect Internet.
if you need help with setting up password on your router then email me zana_adil86@hotmail.com
May 02, 2011 | Computers & Internet
I have an unsecured Linksys wireless set up installed. How can I go back and make it secure?
Hi jenkinsbebeg,
There's a possibilty that you will get an unstable connection due to unsecured Linksys setup. Poeple around you can pick up your network easily and could eat up your bandwith. So it is highly recommended to set up a security on your router. There are several options on how to set up or configure your router. You can use the setup wizard or by opening your web browser.
Here are some steps on how to set up your router using your web browser:
1. Open your web browser ( Internet Explorer, Mozilla ).
2. Now enter the the following URL: http://192.168.1.1
3. Enter your Username and Password.
common username and password for linksys:
--> username blank, password "admin"
--> username "admin", password blank
--> username "admin", password "admin"
4. You need to connect to the internet then click "internet setup".
5. From the drop down menu select DHCP for cable modems, and for DSL modems please select "PPPOE".
6. Now set the SSID (Service Set Identifier) to identify your network name. You could also change the password from here.
7. At this point you can encrypt your wireless connection using the WEP ( Wireless Encryption Protocol ) or WPA. If you will be using the WEP just go under " wireless security" option, then enter your preferred password (passphrase) then click on "generate".
From here you should now be able to connect to your router using your preferred password.
Hope it helps.
Thank you for using FixYa.
Feb 14, 2011 | Linksys Computers & Internet
Wireless won't connect to the internet when in WPA TPIP mode
I have found that some routers do not like text and numbers mixed in the password. After having a ton of problems I set up the wireless password to all numbers and haven't had a problem since.
Prior to that the wireless would work for a day or so and then quit. It was frustrating.
Also, when the router calls for text or hexadecimal I have found that they really don't mean text unless it is between A to F, which isn't really text but a hexadecimal number.
So, take the simple approach. Put in all 5's for your password. You can change it later if everything works, but use all 5's just to see if you can get going.
Don't read this part if you already know this.... You have to connect a computer via a hardwire ethernet cable to the router to set the password encryption. I used 192.168.200.1 as the IP address to get to the modem. Put the IP address in your browser address bar and you should come up with a screen that is addressing the modem. Select wireless security or some similar sounding menu item and then make your selections.
After you do this, and before you disconnect the ethernet cable, try to get on to the internet using the hard wired ethernet cable. That will be bypassing the wireless routines. If you can't get on via the ethernet cable direct connection, it is unlikely that you will be able to make the wireless work because there is a problem downstream from your computer -- the modem or perhaps the connection at the street.
Once done you can remove the ethernet cable from your computer. Go to NETWORK CONNECTIONS and properties and set the identical parameters WPA, etc in the properties including the all 5's password.
If you have set the wireless to connect automatically it should connect to the internet.
good luck
May 10, 2009 | Edimax PRI-682 Router (PRI682)
Wireless internet connection
Hi, to connect to wireless you need to access your wireless router, by connecting it with a cable and access router control panel.
To access router control panel you need to type router IP number on Internet Explorer bar, once the router is connected, then enter user ID and Password.
Once you are in router control panel go to wireless settings and set up your wireless.
You find router IP and user/password on the router manual, follow instructions on route user manual to connect to router control panel.
If you need more help you can call the support number listed on the router manual, or get a chat on Fixya.
regards
Sep 11, 2008 | NetGear WGR614 Wireless Router
Network Key
Connect your PC to your router via a ethernet able, fro, the LAN ports to the machine. Reboot the router, wait 2 min, and boot up your machine.
Go to STARTt>RUN>type in CMD. Press Enter. In the black bix that opens, type ICONIFG.
Look for your IP Address. It should be 192.168.x.xxx. (X can be any number up to 254.) Subnet should be 255.255.255.0. Gateway IP should be 192.168.x.1.
If your IP address is 169.xxx.xxx.xxx, you are not connecting to your router. Put the Gateway Ip into your IE address bar. That should open a window that asks for your username and password. Put those in and go to the Security area, or tab. It should show your key there, and what security mode it is using, such as WEP, WPA, etc. There you can see what it is, or change it. Let everyone else using the router know about the change.
Jan 13, 2008 | Linksys Wireless-G WRT54G Router
Wireless password
The router adress is 192.168.2.1. For this particular model there is no username or password. This is Belkin default...
Jeff
Jan 08, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
SSID and WEB KEY number
i WANT TO CONNECT MY PS3 USING MY WIRLESS ROUTER BUT DON'T KNOW HOW TO CONNECT IT CAN YOU HELP
Jan 04, 2008 | Linksys Wireless-G Broadband Router
Cannot connect my lap tp to the internet via my d link router on my desk top
Please indicate which is your issue.
Is your issue with the router's administrative password to used to configure the router?
Please confirm your router's manufacturer and model number.
IF not go to Wireless Configuration
If the router needs to be reset (because of an unknown password) do you know the proper settings to reconfigure the router? If not or even if unsure please provide your Internet Service Provider's name so we can get accurate instructions before proceeding any further on this password issue.
Is your issue with the passphrase/password for a wireless adapter to access a secured wireless network using either WEP or WAP encryption?
Do you have another wireless computer that works? -- you may be able to find the passphrase in the configuration of that machine's wireless adapter avoiding the need to have the administrators password for the router for the time being.
Dec 13, 2007 | D-Link DI-624 Air Plus XtremeG Wireless...
Cant connect
Hi purplegarion,
hook up the router per instruction in manual and your particular internet connection.  With the Di524 powered up, use the end of a paperclip to depress the reset button located in a little hole beside the power connection.   open internet explorer and type in 192.168.0.1 and press enter.  The password is admin. once th screen appears, click on Wizard.  Follow the wizards directions carefully.
For simplicity of security click on the wireless button while in the  wireless screen.  Set radio to on.  Enter a SSID like purplegarion. Set to open system.  Set Security to WEP.  Wep to HEX.  64bit.  Enter into Key one a 10 digit number you can remember like 1234567890.  Click apply.  Change your password to a personal password other than ADMIN.
Any device that attaches will need to enter the WEP 64 Bit hex Security key 1234567890, or whatever 10 digit number you put in the router.
Internet connection will require powering down you modem, and the DI-524 router.  power up the modem first and let it go through the start up, then power up thte DI 524.  you may need to make sure your DHCP is set to Automatically assign an IP address.
Oct 07, 2007 | D-Link AirPlus DI-524 Wireless Router
Gateway Belkin 54g Wireless DSL/Cable Router (DHF5D72304) Logo
139 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
