Question about Lexmark JetPrinter X1185 All-In-One InkJet
EPSON STYLUSCX5000 I INSTALLED A NEW INK CARTRIDGE AND THE BLINKER LIGHT ON THE INK BUTTON IS STILL BLINKING
    President:
  • 2,072 Answers
You have to select New Cartridge Installed. The machine needs to be told you replaced it.
Posted on Feb 22, 2008
Why is power button light blinking green on Epson SX200 printer?
Regarding your recent inquiry about the Epson T071 ink cartridge error message ("Ink Light is red", "Cartridge Not Recognized", "Replace Cartridge", "Installed ink cartridge is expended." or similar cartridge/printer alert message) associated with your Epson SX200 printer, the cartridge probably has a mis-programmed smart chip...
NOTE: If you had the cartridge refilled, the cartridge chip must be reset. Re-programming, which typically yields a green light to show success, it does not always result in correct smart chip reprogramming. It is also possible they may have forgotten to re-program the ink cartridge. If a compatible/clone cartridge, it could be a reprogramming issue or defective chip (which is common). Or, such a failure could be an electrical failure of the ink cartridge itself*. Unfortunately there is nothing you can do from home....the chip(s) need to be re-programmed (at refiller) or replaced with a new cartridge from vendor.
*OTHER POSSIBLE CAUSES OF FAILURE:
Either the external chip or internal ink sensor is electrically bad (the internal ink sensor detects if cartridge is really out of ink). If you return the cartridge to your retail refiller and they re-program the cartridge(s) a 2nd time but the "replace cartridge" message, or similar blocking message persists, then this is the likely cause and the cartridge will need to be replaced with a new one.
1) Confirm if this is just a nuisance/annoyance alert (i.e. "non-genuine" cartridge ) vs. an actual 'unrecognized cartridge' alert (i.e. Red X's on printer display / Windows pop-up message). Please visit the following Inkjet411 support page which will help you delineate the difference: http://inkjet411.com/?page_id=73
2) On some Epson printer models you may need to scroll thru the menu options AT THE PRINTER'S CONTROL MENU (i.e. right arrow key) to help determine which specific ink cartridge is actually causing the 'Unrecognized Cartridge' error condition. On the other hand, for general 'non-genuine' cartridge alerts, typically you can bypass these errors by clicking thru the acknowledgement prompts or via the arrow keys: http://inkjet411.com/?page_id=1939
3) We suggest you remove all the ink cartridges, inspect the smart-chips condition (on rear side) and ensure there are no cuts/gashes or ink residue present on the micro-chip surfaces. To be sure we suggest you clean the micro-chip surfaces; click here to see 2 different pictures of this along with cleaning instructions: http://inkjet411.com/?page_id=1939
4) If the error continues (following ink tank re-programming a 2nd time), then we suggest you install a new genuine Epson ink cartridge into the printer to verify the permanent PRINTHEAD is functioning ok. Here is how the PRINTHEAD works: http://inkjet411.com/?page_id=2054
NOTE 2: Following refilled cartridge installation, your printer/computer may display an ink alert message such as "non-genuine cartridge" or "you have not installed genuine Epson ink cartridges" - these are COMPLETELY NORMAL alerts when using refilled ink cartridges. Press proceed/continue/accept/yes/OK to dismiss the prompt. In some cases you may have to scroll over using the arrow keys to dismiss the alerts. Additional alerts may be displayed the first time you go to print or copy - dismiss the alerts accordingly to resume normal print operations. For more information on Epson ink cartridge alert messages please visit: http://inkjet411.com/?page_id=1939
CAUTION: Be advised, the use of compatible/clone cartridges (i.e. sold thru the internet from overseas) are known to be problematic and may cause printer errors or permanent PRINTHEAD damage (especially for 3rd party inks which contain volatile organic compounds or VOCs). We do NOT suggest refilling these types of ink cartridges.....refilling of Epson original/genuine ink cartridges is only suggested!
Epson T068 thru T130 Ink Refilling Services & Additional Cautions: http://www.youtube.com/watch?v=Jp575rE9y0Q
NOTE 3: If, after replacing the cartridge(s), with brand new Epson Original ink cartridge(s), is the only solution which corrects the problem, then you likely have a defective cartridge (internal ink level monitoring circuit), unrelated to the refilled cartridges. If, after replacing the cartridge, or cartridges, with brand new Epson Original ink cartridges, does NOT correct the problem, then you may have a defective PRINTHEAD (i.e. permanent electrical sub-assembly which the cartridges plug into). For more information please visit our support page which explains the natural degradation of PRINTHEADs over time: http://inkjet411.com/?page_id=2934
For any additional questions please contact us directly: Inkjet411help@gmail.com
-Thank you
Sep 03, 2014 | Epson 20 Ink For Stylus S20 Sx100 Sx200...
How to change ink cartridges on an Epson CX 3800
Be sure you have a new ink cartridge before you begin. Once you start replacing a cartridge you must complete all steps in one session.
1. Make sure the Epson CX printer is on.
2 Make sure the document cover is closed, then open the scanner
Caution: Do Not open the scanner when the document cover cover is open.
3. Press and release the " ink " button. The ink cartridge moves to the check position and the
" On " and " ink " lights flash. If one of the cartridges is low or empty, the printer moves the
cartridge to the _ink out mark.
Note: Don't hold down the " ink " button for 3 or more seconds or the printer starts cleaning the print head.
Caution: Do Not move the print head by hand; this may damage the printer, always press the ink
button to move it.
4. Press the " ink " button again
a. If more than one cartridge is low or empty, the next cartridge moves to the_ink out position.
b. If all of the empty or low cartridges have been identified, the print head moves to the ink
cartridge replacement position.
5. Open the cartridge cover.
6. Squeeze the tab at the back of the empty/low cartridge and lift it straight out.
7. Before you open the new ink cartridge package shake it four or five times, then remove it
from the package.
Caution: Do Not remove or tear the label on the cartridge; otherwise ink will leak.
Do Not touch the green chip on the front of the cartridge, this can damage the
ink cartridge.
8. Place the new ink cartridge into the cartridge holder and push it down until it snaps into
place.
a. Replace any other cartridges that need to be replaced.
9. Close the ink cartridge cover and press it until it clicks into place.
10.Close the scanner.
11. Press the " ink " button The print starts charging ink and the " On " light starts flashing. This
takes about one minute. When it's finished the " On " light stops flashing and remains on.
and the " ink " light goes out.
Caution: Never turn off the printer while the " On " light is flashing or you'll waste ink.
Note: If the " ink " light stays on ( not flashing ), the ink cartridge may not be installed correctly.
Press the " ink " button again and reinstall the ink cartridge until it clicks into place.
Feb 09, 2011 | Epson Office Equipment & Supplies
Yellow ink blinking
Please clean the printhead using the software installed in your PC . Try printing now.
Apr 30, 2010 | Epson Stylus Photo R2400 InkJet Printer
(Epson Stylus C60)red light blinking, says contact
keenepadgl, "Contact service engineer" for a C60 used to be all you could do. Now you can go to SSC Service Utility and download it. But the red light blinking (if that is all that is happening) simply means you have a ink cartridge that is low but not empty. If the red light stays on, then it means a ink cartridge is empty. By downloading SSC Service Utility you can solve about any problem you have with a C60. That's what the "Service Engineers" use. Check out the protection counter reset in SSC, that is the main reason people had to send their C60s to have serviced., and what service would do is press the reset button in SSC program. NOTE: I would go to inkmizer and get some cleaning fluid instead of nail varnish remover.
Jan 05, 2010 | Epson Stylus C60 InkJet Printer
Red lights blinking
the problems are :-
  • cartridges are not recognised or installed
  • there is a paper jam.
Dec 10, 2009 | Epson Stylus Photo R200 InkJet Printer
Power and error botton blinking epson cx 2900
Could be ink cartridge no contact, or it is dirty. Or if you try to print and this printer that flag a message " end of service life......parts." . You should reset it counter using third party software. In kinda connection with ink pad.
Apr 18, 2009 | Epson Office Equipment & Supplies
Red light is plinking
this mean that your printer waste pad is full and your printer needs to be reset go to this website http://www.ssclg.com/epsone.shtml
this will reset your printer
plz rate me
Mar 23, 2009 | Epson Stylus Photo R300 InkJet Printer
Epson Stylus 440, solid light on for black ink, have replaced and still won't print
This morning I was researching to purchase a new printer to replace the 10 year one. The last cartridges I had purchased were from Printpal and made in China. They looked the same, but I had to force the door closed on them. With the solid red light on and replacing the cartridge three times with new ones from this order, it was time to find an old used cartridge from another company that I intended to refill myself. I did, installed it and the solid red light disappeared. The old Epson Stylus 440 is still ticking! However, I had written off InkGrabber for unused cartridges going dry in 2 months and now Printpal is on my $%%# list for non-uniform replacement cartridges as well as not lasting long. I am back to refilling my own. I had followed the instructions for resetting the ink level indicator, but to no avail as those instructions are for a blinking light, not a solid light.
I appreciate your website, if for nothing else, to be able to vent. Thanks so much for your follow-up inquiry and I'm sure you'll hear from me again soon about my old Epson.
Shirley
Aug 17, 2008 | Epson Stylus Color 440 InkJet Printer
C43sx both lights on
ok...start by removing the drivers from control panel, go to website and get new drivers, install them, try it again.
http://tinyurl.com/6qcpgy
Jun 11, 2008 | Epson Stylus C43SX InkJet Printer
Lexmark JetPrinter X1185 All-In-One InkJet Logo
110 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
