Question about Dell InspironTM 600m Notebook
DELL 600M AC POWER CORD
My wife's computer received the message that the power cord that was attached was not charging the battery, but would only supply power to the computer. I figured that the cord must be damaged, so I bought another one (on ebay) to fix. This kind of fixed the problem because it now charges the computer, but I still get the message on startup. Now, 1 month later, the computer won't even recognize the cord anymore and the computer battery is now dead. The charger is showing a green light to indicate that it is on, but I am not sure if there is power coming out of the end or there is something wrong with the port for the plug. Any suggestions?
The internal power supply of your PC is broken, it needs to be serviced.
Posted on Feb 13, 2008
Plug in ac adaptor to Dell inspiron 600m and does
Sounds like you have a broken DC Power jack. This is where the small socket where you attach the AC adaptor breaks loose from the motherboard , resulting in the laptop not charging properly or at all . If you have to wiggle the power jack to get a connection then this is definately theproblem.
Most computer reapir shops can do this for about $100. Or if your handy with a soldering iron and dont mind disassembling the laptop , you can always buy a new DC jack for your make and model off ebay and try to solder it yourself!
If you found this post helpful , please rate my post
Regards
1234s282
Apr 17, 2010 | Dell Inspiron™ 600M PC Notebook
The Dell Inspiron 600m will not power up when you press the start button. Battery is fully charged. BLY
Try draining the flea power first:
1. Remove the battery and ac adapter
2. Press and hold the power button for at least 10sec.
3. Put back the battery and ac adapter
4. Turn on the computer
If there is still no display, tell me if there is also any lights that flashes on the (numlock, scrolllock, capslock). Hope this helps
Dec 15, 2009 | Dell InspironTM 600m Notebook
Dell 600m Computer won't power with adaptor connected
Bad motherboard, unfortunately. Seen it before as a Dell tech.
Jun 29, 2009 | Dell Inspiron 600M Notebook
Dell 600m won't power from ac
It could be the charging port is loose or has gone bad outrightly. If it is shaky or has a dry joint, then try scrapping off the solder and resoldering ok. Power down the pc and then to AC supply to see whether it charges. If it does, then you probably have a corrupt operating system and should be re-installed. If the RAM becomes unstable, it could also come with such a problem. Hence, I suggest too that a confirmed working and compatible memory should be tried on your pc. If all failed then your motherboard is bad and should be replaced. Good luck
Jun 03, 2009 | Dell Inspiron 600M Notebook
NO POWER
souns like a dc jack that is repairable
Apr 28, 2009 | Dell Inspiron™ 600M PC Notebook
CAN NOT CHARGE BATTERY AND AC POWER NOT WORKING ON MY DELL 600M INSPIRON
the battery could be a bad one or it my be a bad dc jack and would need to be replaced
No Power
there is a chance of battery failure
Feb 14, 2009 | Dell Inspiron 600M Notebook
Insprion 600m Reddish Tint when on Battery Power
hi there,
you are probably not getting enough power source from the battery or the battery is getting old and not charging fully or holding its charge ,is my guess good luck..try a new battery...
Jan 22, 2009 | Dell Inspiron 600M Notebook
Dell 600m Laptop Killing batteries
If you are using known good batteries, and you have the most current BIOS Flash, then it is likely a failure of the charging curcuit on the motherboard. The flashing Amber (Some people see it as red) led indicates a failed battery
The Multiple good batteries, I assume have been recently purchased, because computer batteries are consumable and are rated for 300 to 500 charging cycles before they wear out.
I replaced my 700m motherboard with one from Ebay for about $170.00 about a year ago.
Jul 05, 2008 | Dell Inspiron 600M Notebook
Dell inspiron 600m idle battery
the battery has gone bad and needs replaced, also check manufacturers web site to see if the battery is on recall, may be get it for free.
Nov 12, 2007 | Dell InspironTM 600m Notebook
Computers & Internet Logo
120 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
