Question about Hampton Bay 04379 Madison Avenue Ceiling Fan
Replacing a 3 speed sw.
I just replace a sw. on may fan and it wont work ???
  • 25 Answers
Does the fan work with direct wires to it? If it works then the switch is bad or your wiring is mixed up.
Posted on Aug 20, 2008
Wiring diagrams
What make/model of fan? How many wires on capacitor & what color goes into which slot. You can't just buy a switch off the rack and think it's going to work, even if it looks the same on the outside.
Aug 21, 2014 | Dryers
Model Ford Tourneo Kombi. fault: a/c works but fan only operates on max speed (positions 1 to 3 fan wont work) any clues welcomed
Sounds like an blower motor resistor. It regulates voltage going to the motor depending on what speed you select. Speed one , or low only lets so much voltage to the motor and full lets all the voltage through. If it is blown, it cannot regulate voltage and acts like its not there. I would start with that.
Aug 14, 2011 | Ford Transit Connect Cars & Trucks
Blower fan wont work replaced it and control panel allso replaced bloerfan relay for the 3 speed on firerwall
Sounds like a ground problem. I had one that I ran a new ground for and it worked fine. Also check for power to the switch and blower motor.
Oct 09, 2010 | 1996 Plymouth Voyager
Wiring diagram for a 3 way ceiling pull switch.
These fans are manufactured by a number of overseas companies and sold exclusively by Home Depot. They do not have a standard color code for the fan switch. What you can do is turn off the power, keep the white neutral connected. Then using the black power wire fro the ceiling, take one of the switch wires and connect to that black, turn the power on and observe the speed .. low mark it 1, medium mark it 2, high mark it 3. Repeat untill you have identified all the speed wires. Then connect these wires to the 1,2,3, terminations of your new switch
Questions?
Please Vote !
May 29, 2010 | Hampton Bay 24750 Huntington III Ceiling...
Trying to replace 3 speed ceiling fan switch and don't know which wires go where - 3 speed fan switch, 4 wire unit.
Hi
The pull switch has 4 wires, L, 1, 2, 3.
Connect ' L' to the reverse switch red wire or the wire that is free.
Connect ' 3 ' to the main black ( hot ) wire entering the fan.
Connect ' 1 ' to the capacitor's lowest uF eg. ( 1.5 uF )
Connect ' 2 ' to the capacitor's next uF eg. ( 3 uF )
the Capaciotr also has to be connected to the neutral wire entering the fan, usually black attached to another color wire. If you have a VOM tester, veryfy that it is a neutral wire.
Regards
H. Montero
Aug 06, 2008 | Westinghouse Fans Indoor Ceiling Fans
Hampton Bay 04379 Madison Avenue Ceiling Fan Logo
Top Hampton Bay Dryers Experts
Steve
Donald Klecher
Donald Klecher
Level 1 Expert
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
