Question about Microsoft Windows Vista Ultimate Edition
MP4 player I have an MP4 player from acompany called TOOLPAK and cant get my Windows Vista Laptop to drive the program. There appears to be a serial number N61217R1F.70 inside the cover
  • 152 Answers
Check for the program compatibility.... i mean the Windows versions the software will run on....
Posted on Feb 13, 2008
    Scholar:
  • 84 Answers
The first time you connect a device that plugs into a universal serial bus (USB) port, Windows automatically installs a driver for that device. After a driver is installed, you can disconnect and reconnect the device without performing any additional steps.
Before you install your device Check the instructions included with the device to determine whether a driver should be installed before you connect the device. Typically, Windows detects a new device after you connect it, and then installs the driver automatically. However, some devices require you to install the driver before plugging the device in.
Also, while most devices that have power switches should be turned on before you connect them, others require that you turn them on during the installation process. Because of issues like this, it's a good idea to read the instructions included with a new device before you connect it.
If the instructions that came with your device contradict the information in this topic, follow the instructions that came with the device.
Plugging your device in If your USB deviceMP4 player - 1.gif uses a power cord, you should connect the device to a power source and turn it on before connecting it.
Next, determine which USB port you want to connect your device to. If your computer has USB ports1.gif on the front, consider using one of those if you plan to frequently connect and disconnect the device.
YOU MUST NOW " SYNC" YOUR DEVICE WITH MEDIA PLAYER THIS IS HOW TO DO IT.
Set up a device to sync in Windows Media Player You can use Windows Media Player to copy music, videos, and pictures from your Player library to a portable device, such as a compatible MP3 player. This process is called synchronization or syncing.
There are two methods for syncing items to a device: automatically or manually. When you connect a device to your computer for the first time, Windows Media Player selects the sync method that works best for your device, depending on the device's storage capacity1.gif and the size of your Player library. After your device is set up the first time, you can choose a different sync method if you want.
  1. Start the Player, turn on your device, and then connect it to your computer. If prompted, select the AutoPlay option to sync the device using Windows Media Player.
  2. Do one of the following:
    • If the Player has selected to sync your device automatically, click Finish. When you do so, the Player will sync your entire library to your device. After that, your device will automatically sync every time you connect it to your computer while Windows Media Player is running.
    • If the Player has selected to sync your device manually, click Finish. Then, in the Sync tab, you can select the files and playlists you want to sync manually. For more information, see Sync manually in Windows Media Player.
Comment by Christalnet, posted on Feb 12, 2008I HOPE THIS IS HELPFUL.... PLEASE CONSIDER USING A LIVE CHAT BOX OR YOU CAN INSTANT MESSAGE ME FOR HELP IN DOING A WALK THROUGH IN REAL TIME, YOU MAY CONTACT ME USING........
MSN MESSENGER- CHRISTALNET@HOTMAIL.COM
YAHOO MESSENGER- CHRISTALNET@YAHOO.COM
OR I USE ICQ # 147169792
Comment by Christalnet, posted on Feb 12, 2008You can find a nice walk through on transfering music manually and installing third party apps for this purpose by clicking HERE
  • Chris Lemke Feb 13, 2008
    If when running Vista you find a program not compatable with Vista you can right click onthe programs Icon and choose properties.. this will bring a pop up window on which you will find the tab "compatability" place a check mark in the box to run this program in compatability mode and choose XP SP2 from the drop down menu. Hit apply, then okay and try running your program again. It should run okay if as mentioned above it is a compatibility issue.
I want to learn the volume serial number of any harddisk by means of a program (software) (except chkdsk in dos window of winxp). Harddisk brand name is not important. The OS is Windows XP/Vista/Win7.
in dos you can type vol and hit enter and it will give you volume serial number. You can also use this software to view and change the volume serial number HERE. It's the third download called "disk serial number changer"
Apr 13, 2010 | Computers & Internet
The install and utility software setup not reading on my vista
hi there.. ur prob. is quite simple. its not compatible with windows vista.try to change ur o.s. to windows XP. for me vista is a garbage....
Feb 27, 2010 | Argosy HV358T Audio/Video MP4/MP3/...
Vista compatibility problems when trying to install set up program for yumi pro mp4 player v 4.05 get message blocked due to known compatibility problems
Copy the installation to your hard drive.
now take the properties and setup it for windows xp under the tab compatibility.
now run your application with administrative privilage. right click then "Run as Administrator'
Vista's Compatibility assistant is known to have a lot of bug.
if it didn.t work then
Press the keyboard combination "Windows Key +R"
you will have run dialogue box
type in "services.msc"
in the window that appears look for "Program compatibility assistant" and then disable it.
now restart your computer and try installation
it will be fine
its recommended that you switch your os to windows 7 from vista as windows 7 is more bug free and crash is unlikely to happen
Jan 08, 2010 | Sumvision Yumi Pro Digital Media Player
I wont to find vista drivers for a 2GB MP4 player from IKASU
depends how old all the new computers are very selective on wat they connect with your mp3 player could be obselete
Dec 08, 2009 | Audio Players & Recorders
Downloading music to my mp4 player
first connect your mp4 to your laptop with a usb cable. once it shows up on the laptop copy or cut and paste your music to the root folder of your mp4 or the music folder. after that is done disconect your mp4 from your laptop.
restart you mp4 and your music should now show up. enjoy your music
Jun 06, 2009 | Digital Mind Corporation iQ Sound...
Dont now how to put music videos on my mp4?
Can you hook it up to your computer? If you are running Windows XP or Vista, your Konaki should appear as another drive. Double click on your "My Computer" icon on your desktop. Then double click on the drive that represents your Konaki (usually called Removeable Disk or the name of your MP3 player). There should be folders labeled according to media type like Music, video etc. Double click on the folder called video. This is where you want to save your music video files. You then need to browse to where you have the music video stored on your computer. Right click on the video file and select copy. Then go back to the Konaki folder called video, and right click anywhere on the right and select paste. This will copy the files over to your MP3 player.
Mar 23, 2009 | Konaki MP4-NS MP3 Player
I can not boot window vista
Aha!
You have to activate your OS,
On your laptop you have a key for the vista, type that key in, if that dosent work you must call and activate your vista. You do that like this way:
1:) if you have a valied licens you just call that number that appears if you continue when it ask you to use the automated phone system
2:) call that number, type in those numbers you see on you laptop given to you when u get the phone number.
3:) Listen carrefull cos you going to get an actication code, and thats a lot of number, whrite them down so you dont forget them,
4:) type in those numbers you get when you be asked to do that in the activation window on your laptop
5:) continue the boot up, vista will now check to the number you typed in are valied and you will never have to to this again, if you dont format your laptop.
If you dont have a valied licens, Buy one!
Good luck to you M8!
Please take a moment and rate my help to ypu
Nic
Feb 13, 2009 | Acer Computers & Internet
My mp4 player drive in the usb section is not reconised
i have a mp4 player brand name ikasu now it is not being reconised in the usb drive i have lookin in the secotion computer nd it hasent *** up it dosent say any thing usefull in the manual and clearlyt doesent have it in my windows media and when i plug it in it starts chagin when i also dont know how to get music on it i have windowns media player and i am on vista home premiare i dont have a clue how to get music on any ideas ?
Oct 18, 2008 | Konaki MP4-NS MP3 Player
MP4 1GB n61217r1f.70
if you are using windows vista forget about using that player in ur laptop dude.... vista has compatibility issues... many softwares which used to run well in windows xp are not running in vista,,,, try finding the driver for the player for vista,,,...
Feb 13, 2008 | Microsoft Windows Vista Ultimate Edition
Microsoft Windows Vista Ultimate Edition Logo
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
