Question about Lexmark JetPrinter X1185 All-In-One InkJet
INK BUTTON GOODEVENING, I BOUGHT AN INK CARTRIDGE FOR MY PRINTER TO691 Today AND I INSERTED IT AND THE INK BUTTON STILL BLINKS.WHATS WRONG? PRINTER NUMBER IS CX 5000 SERIAL #JG5P109536
  • NANAX7 Feb 13, 2008
    I JUST NEED HELP I DON'T HAVE ANY MONEY I'M UNEMPLOYED AND OLDER PARENT WITH A CHID THAT NEEDS HER PAPER PRINTED
    President:
  • 2,072 Answers
  1. Power off the printer and remove it from the mains supply.
  2. Open the printer lid so that you have access to the cartridges.
  3. Pull gently on the ribbon cable connected to the carrier until the carrier is accessible.
  4. Remove the cartridges.
  5. Using a dry, clean cloth, wipe the contacts of the carrier gently from top to bottom.
  6. Repeat Step 5 on the second carrier slot (where applicable).
  7. Reinsert the cartridges and close the lid.
  8. Reconnect the printer to the mains supply and turn on the printer again.
Posted on Feb 22, 2008
How to change ink cartridges on an Epson CX 3800
Be sure you have a new ink cartridge before you begin. Once you start replacing a cartridge you must complete all steps in one session.
1. Make sure the Epson CX printer is on.
2 Make sure the document cover is closed, then open the scanner
Caution: Do Not open the scanner when the document cover cover is open.
3. Press and release the " ink " button. The ink cartridge moves to the check position and the
" On " and " ink " lights flash. If one of the cartridges is low or empty, the printer moves the
cartridge to the _ink out mark.
Note: Don't hold down the " ink " button for 3 or more seconds or the printer starts cleaning the print head.
Caution: Do Not move the print head by hand; this may damage the printer, always press the ink
button to move it.
4. Press the " ink " button again
a. If more than one cartridge is low or empty, the next cartridge moves to the_ink out position.
b. If all of the empty or low cartridges have been identified, the print head moves to the ink
cartridge replacement position.
5. Open the cartridge cover.
6. Squeeze the tab at the back of the empty/low cartridge and lift it straight out.
7. Before you open the new ink cartridge package shake it four or five times, then remove it
from the package.
Caution: Do Not remove or tear the label on the cartridge; otherwise ink will leak.
Do Not touch the green chip on the front of the cartridge, this can damage the
ink cartridge.
8. Place the new ink cartridge into the cartridge holder and push it down until it snaps into
place.
a. Replace any other cartridges that need to be replaced.
9. Close the ink cartridge cover and press it until it clicks into place.
10.Close the scanner.
11. Press the " ink " button The print starts charging ink and the " On " light starts flashing. This
takes about one minute. When it's finished the " On " light stops flashing and remains on.
and the " ink " light goes out.
Caution: Never turn off the printer while the " On " light is flashing or you'll waste ink.
Note: If the " ink " light stays on ( not flashing ), the ink cartridge may not be installed correctly.
Press the " ink " button again and reinstall the ink cartridge until it clicks into place.
Feb 09, 2011 | Epson Office Equipment & Supplies
Please help, the Power light is blinking green rather that just solid and nothing will print. When I open the cartridge door the ink carriage is in the middle rather that to the right as it usually is....
Sounds like it is trying to tell you to change the ink cartridge as that is where the cartridge parks for changing? My printer blinks green when it needs paper, does yours have paper and is it inserted properly? Have you checked for a paper jam?
The clue will be in the manual's troubleshooting pages.
Modern printers have a chip on the cartridge itself and these can sometimes give wrong information to the printer..
Nov 22, 2009 | Canon BJC 4300 InkJet Printer
Replaced ink and wrong catridge message comes up
What I would do is check your maunal to see what cartridge you need for your printer and purchase this cartridge. If you have not need color cartridges before than you wont need them now. Just make sure you inserted the right ink cartridge for your printer
Sep 24, 2009 | Canon MultiPASS MP700 All-In-One InkJet...
5183 INK problem
You need to go into printer options in the Windows control panel. Chose properties, and find the option to install a new cartridge. Follow the onscreen instructions.
If you need more help, please tell me which version of Windows you have.
Sep 19, 2009 | HP Photosmart C5180 All-In-One InkJet...
My epson stylus cx6000 printer keeps showing -(install the ink cartridges) and I have already put in new ones. The code is E-02.
f you have just installed a new cartridge and you still see an ink related error message, the cartridge may be incorrectly installed. Follow these steps to make sure the cartridges are correctly installed:
  1. Make sure the Stylus CX is turned on.
  2. Check the photo viewer screen to determine which cartridge is incorrectly installed. Then do one of the following:
    • If printer shows the ink cartridge is expended, press the cp_button_6.gif Start button.
    • If the printer shows the cartridge is low on ink, press the Setup/Utilities button. Press the cp_button_41_er.gif or cp_button_42_er.gif button to select Press Start to change cartridges. Then press the cp_button_6.gif Start button.
  3. Press the cp_button_6.gif Start button again.
  4. Lift up the scanner, then open the cartridge cover.
alert_caution.gif Caution:
Never attempt to open the cartridge cover when the print head is moving. Wait until the cartridges have moved to the replacement position.
  • Press down all the ink cartridges until they click into place to make sure they are properly seated.
  • alert_note.gif Note:
    If a cartridge is properly seated already, you may not hear a click.
  • Close the ink cartridge cover and press it until it clicks into place.
  • Close the scanner.
  • Press the cp_button_6.gif Start button. The Stylus CX charges ink for about one minute and displays Charging Ink on the photo viewer screen until charging is finished.
  • alert_caution.gif Caution:
    Never turn off the Stylus CX while the Charging Ink message is displayed or you'll waste ink.
  • Press the Setup/Utilities button to return to the previous mode, if necessary.
  • Aug 26, 2009 | Epson Stylus CX6000 All-In-One InkJet...
    My printer has a new ink cartridge but does not recognize the ink
    What model printer do you have and can you list the print cartridge?
    Also have you selected on the onboard printer menu that you have inserted a new cartridge?
    Jul 28, 2009 | Epson Stylus Multifunction Inkjet Printer/...
    CX 3900 Ink Problem
    Normal 0 Normal 0 Driver could be corrupt.
    Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
    Hope this helps. Bud
    Jan 06, 2009 | Epson STYLUS CX3900 All-In-One InkJet...
    Error inkcartridge
    Error message: No color or black ink cartridge-->Press the Color Copy button to install a new ink cartridge.
    Solution: The indicated ink cartridge is not installed. Please install the necessary cartridge(s).
    Error message: Color or black ink out -- >Press the Color Copy button to begin replacing the ink cartridge.
    Solution: The indicated ink cartridge is out of ink. You will need to replace the necessary ink cartridge(s).
    Error Message: Ink cartridge error -- > Press the Color Copy button to begin replacing the ink cartridge.
    Solution: There is something wrong with the ink cartridge. Make sure the cartridge is genuine Epson ink. Also, try reseating the cartridge (remove it, and then reinstall it).
    Error Message: Paper jam or misfeed -- > Press the Color Copy button and clear the paper jam by hand if necessary.
    Solution: Paper is jammed. Check for any obstructions under the unit's cover, and in the paper tray.
    Error Message: Paper out -- > Load paper in the sheet feeder and press the Color Copy button.
    Solution: Load paper in the sheet feeder, and then press the Color Copy button to continue printing.
    Error Message: Scanner unit open -- > close the scanner unit
    Solution: Carefully close the scanner and press it down until it clicks securely into place.
    Error Message: Scanner error -- > See your documentation and call service if necessary.
    Solution: Press the ON button to turn off the Epson Stylus CX3200. Unlock the transportation lock, if necessary. If it is already unlocked, toggle the lock back and forth, 5-10 times. Turn on your Stylus CX3200 again.
    Error Message: Printer error -- > See your documentation and call service if necessary.
    Solution: Press the ON button to turn off the Epson Stylus CX3200. Disconnect it from power, and then reconnect it to power. Press the ON button to turn on the Stylus CX3200
    Nov 28, 2008 | Epson Stylus CX3200 All-In-One InkJet...
    Refilled ink cartridges not recognizby printer.
    I fixed the problem by using original Canon ink cartridges and not getting them refilled. Apparently their chemists put a chemical in all of their inks so that only their Canon printers will recognize. It's a guarded trade secret that no one else knows about, unless it was analized. Other ink manufacturers produce ink that looks exactly as Canon ink, but that's where the similiarities end.
    Nov 24, 2008 | Canon PIXMA iP6700D InkJet Photo Printer
    CANON MP210 ERROR E15 - INK NEW PRINTER, NEW INK
    Go to this link. In the search window in the center of the screen, type "error e 1 5" and click on the Search button. Select the appropriate error message, then select the answer that says "reseat ink cartridge". You may not have locked the cartridges into place by lifting up until they click.
    Oct 24, 2008 | Canon PIXMA MP210 Photo All-In-One Printer
    Lexmark JetPrinter X1185 All-In-One InkJet Logo
    108 people viewed this question
    Top Lexmark Office Equipment & Supplies Experts
    Don  Farrell
    Don Farrell
    Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
