Question about Mercury P4VM800M7 Motherboard
Wiring i need to know how to wire the mother board correctly but i cant find a guide any where and it didnt come with one its mainly the power, usb and the cases lcd display cables if any 1 knows how to do it or knows where i can get a guide from i would realy apreciate it thanks. its a gigabyte p4 titan ga-8pe800 ultra
  • 1 more comment
  • shadow ninja Feb 13, 2008
    brilliant thanks mate
  • Anonymous Feb 23, 2008
    need to know how to wire up board
  • Anonymous Aug 27, 2008
    need to wire motherboard
    President:
  • 2,351 Answers
Click the link listed below that will take you Gigabyte. Download the manual described as, (English-Rev. 1103, format pdf, size 7.47Mb). The case leds placement is on pg. 25. USB's on pg. 27. Everything you need to setup this Ultra motherboard is here.
http://www.giga-byte.com/Support/Motherboard/Manual_Model.aspx?ProductID=1621
The only thing not mentioned for connecting the case led wires to the motherboard is the wire colors. Which is, pos+ & which are neg -. Usually white colored & black colors are negetive -. Other colors like Green, Blue & red are pos+.
This should make it much easyer to install.
please vote...
Posted on Feb 13, 2008
My computer wont turn on
take out the psu completely from the cpu/tower, plug in the power cord,if there is a switch on the psu turn it on, next locate the main power connector (24pin) and find green wire,take a piece of wire and insert it into the green wire connector,next touch the other end of the wire to the psu outer case or a black wire on the main connector,if all is well the psu will turn on,if you have a dc voltage tester check the voltages on the red and black wires on molex connector...5vdc,yellow and black...12vdc.if ok look at the main board and inspect the capacitors to see if they are swollen, if ok
replace psu and disconnect hdd,cd/dvd,floppy ect from main board only leave memory,processor and video, power on if ok shut off and reconnect hdd, power on, if ok shutoff and connect floppy, if ok power off and connect cd/dvd drive.during this testing you will know what is bad.let me know how it turns out.email; arjoon.ken@gmail.com
Feb 19, 2010 | Computers & Internet
Hi Guys I have disconnect my front Panel USB connections in my System iam using intel 945 GCNL mother board. Please help me with screen shot , its very difficult to connect at back Please help me.
Open your manual to page 40. Your better off download the manual. You'll need Adobe Reader to view the manual. Using the program Adobe you can zoom in which will help greatly. You'll be able to see exactly where each wire goes. Here is the link for your manual;
http://downloadmirror.intel.com/15115/eng/D945GCNL_ProductGuide02_English.pdf
Figure 20. Internal Headers. Intel Desktop Board D945GCNL Product Guide. If your USB wires should be marked. To help you connect the correct wire to the USB MB pins use the guide provided below;
http://www.directron.com/installusb.html
There are a few different types for USB connections. You'll find one just for your MB on the site.
Happy holidays!
Mike
Dec 15, 2009 | Intel Motherboard
Emachine t1840 wiring diagram power switch wire to mother board ?
Because there are so many different case and motherboard combinations sometimes it can be difficult following the instructions for connecting the front panel, USB header and audio header.
Below is a few generic guide that should stop some of the confusion with the labels on the wires.
Front Panel Audio
***Please note this is a generic wiring guide and we can not guarantee it will work with every motherboard. Please check your motherboard manual first. Wiring the headers wrong can cause damage to the motherboard and case, this damage is not covered by the warranty***
another handy USB wiring guide can be found here http://www.directron.com/installusb.html
this maybe easier to follow
FRONT PANEL AUDIO
2________10
__
1________9
Pin Wire
1) Mic In
2) GND (ground) or if 2xGND available, it’s the GND for the headphones, NOT the Mic
3) Mic BIAS
4) n/c
5) Speaker Right Out
6) Speaker Right Return
7) n/c
8) no pin (n/c)
9) Speaker Left Out
10) Speaker Left Return
n/c = not connected
USB (F_USB1 and also F_USB2)
2________10
 x
1________9
Top row of pins
2 = USB port 2 : VCC/Power/+5V
4 = USB port 2 : Data -/D-
6 = USB port 2 : Data +/D+
8 = USB port 2 : Ground/GND
10 = USB port 2 : pin present, but not connected to anything.
Bottom row of pins
1 = USB port 1 : VCC/Power/+5V
3 = USB port 1 : Data -/D-
5 = USB port 1 : Data +/D+
7 = USB port 1 : Ground/GND
9 = USB port 1 : no pin present
Front Panel Connector (FP1)
1 2
x 
9 10
1 = no pin present
3 & 5 = Power Switch
7 & 9 = Power LED (light)
2 = pin present, but not connected to anything.
4 & 6 = Reset Switch
8 = 10 = Hard Drive LED (light)
Jul 30, 2009 | Computers & Internet
Usb
please click follow:
http://www.pctechguide.com/tutorials/MBoard_USB.htm
acording the table and picture you can make easy to correct your USB connection.
hope help you fix it, any question send any time please!
please take a rating let me know how much helped you, thanks!
May 17, 2009 | MSI 865PE Neo2-PFS Motherboard
Case wire two mother board
Here is your front Audio guide:
http://www.fixya.com/uploads/images/3C3CD07.jpg
Here is your USB guide:
http://www.marnscda.com/Guide/USBPinMB.jpg
And here is your front Panel guide:
http://www.elhvb.com/mboards/intel/pinout-OEM-Intel-2x9pin.jpg
Let me know how that works out. The front panel guide is rotated 180 degrees however.
May 02, 2009 | Foxconn 661FX7MF-S Motherboard
Need to know where LED wires connect on Foxconn mother board.
You can try going to the following site and download the user manual for the motherboard , which would give you the detailed diagram of which cables to connect where
http://www.foxconnchannel.com/support/downloads.aspx?ProductModel=661FX4MR-ES&TypeID=en-us0000001
Thanks
proton
Apr 08, 2009 | Foxconn 661FX4MR-ES Motherboard
Emachines computer not turning on
IS ALL CONNECTION CORRECT, TYPE IN
EMACHINE COMPUTER DOWNLOAD DRIVES
ENTER
SEE IF ANY OF THIS INFO CAN HELP YOU
THE MAIN SWITCH FROM THE PANEL ON THE FRONT OF YOUR COMPUTER DIDNT MATCH YOUR NEW MOTHERBOARD CONFIGURATION
START BY REMOVING ALL WIRES AND CONNECTORS EXCEPT POWER ONE, SEE IF SYSTEMS TURNS ON, THE POWER SWITCH MAYBE THE PROBLEM, RESET SWITCH, ANY EXTRA CARD YOU PLUG INTO YOU MOTHER BOARD
*********REMOVE ANYADD ON CARD ANY ADAPTER DEVICE ALSO,
ADD ONE WIRE AT A TIME UNTIL ALL WIRES ARE CONNECTED
CANDYMANCANDY
Jan 27, 2009 | E-Machines (308714) Motherboard
Wirring for a mother board
For information like this :-
Go to the manufacturers WEB site to download the documentation/manual for your model motherboard.
If it is ASUS motherboard try www.asus.com
Dec 03, 2008 | ASUS A7S333 Motherboard
Volume
follow the below checklist :
Check1 : Is power for speakers on
Check2 : Are speakers connected correctly to laptop (fixcables)
Check3 : nothing on volume control is muted
Check 4 : try to check with other pc or laptop if speakers are working.
If speakers are working with other computer , then all you need to do is instal audio drivers from mother board CD which you get from hardware manufacturer....
If the speaker is not working with other PC
check 5: if all the wires are in good condtion
If yes.. then contact hardware manufacturer
If no.... fix wires correctly ......
Hope this anwwers your problem.... thanks..Robosoft.
Dec 16, 2007 | Computers & Internet
K7ama2 USB cable wire unplugged
the comon colors for usb are [red +5v] [white data -] [green data +] [black ground] and you need pinouts on your mother board also you may have 2 jacks so there is a 9 pin connector on board for external usb jacks, just get the manuel for it on internet but I need the motherboard number and make
Dec 12, 2007 | EliteGroup K7AMA Motherboard
Mercury P4VM800M7 Motherboard Logo
119 people viewed this question
Top Mercury Computers & Internet Experts
Mark Gough
Abhinandan  Patil
Abhinandan Patil
Alun Cox
Are you a Mercury Computer and Internet Expert? Answer questions, earn points and help others
