Question about Kenmore 44072 Front Load Washer
44072 Kenmore Washer - Front Door Won't Lock
Any clues as to how to remedy a "no lock" situation with this washer? I didn't do any forcing of the door. It just doesn't want to start now, i.e., the Door Lock won't light up.
I've unplugged and re-plugged the power; removed clothes in case I had somehow put too much in, but none of that works.
All help appreciated!
  • 1 more comment
  • smashcan Feb 13, 2008
    Thanks, but the problem isn't the light. It's that it gives me the three beeps and won't start the wash cycle.
  • Anonymous Mar 31, 2008
    won't start. indicates door is not locked!!!!!!
  • dmwegman May 16, 2008
    message on machine is d:do and washer will not fill or lock. I unplugged machine and let it unplugged for several minutes.
There is a black peg on the round housing of the washer that gets pushed in when the door is closed and the machine locks the door. If the peg gets broken (as mine did) the machine won't lock. I now use a small screw...or you can buy a replacement part for the whole mechanism.
Posted on Aug 20, 2008
  • 77 Answers
Your bulb that lights up when it locks could be burnt out
Posted on Feb 13, 2008
Kenmore front load washer door won't latch lock light on
On some Kenmore front load models, if the black gasket around the door opening is unseated (for example, because you drag some heavy wet laundry over it) the door will not engage the lock and stay closed. This is a feature to prevent the washer from leaking when the gasket is not sealed. To fix it, simply reseat the gasket and the door will close and lock.
Jun 21, 2012 | Kenmore 44102 Front Load Washer
My kenmore front load washer doesn't want to start all lights are working but nothing happens even the door won't lock
your door switch is the problem,where the door latch goes into the machine a little switch sites behind this a safety feature and if this is broke the machine will still switch on but will not work it will need replaced they are cheap.adrianxxx
Jun 02, 2012 | Kenmore 44072 Front Load Washer
Kenmore HE2 front load washer. All power to the maching is good. Thhe start button just beeps in quick sucsession. Won't start. It seems to think the door isnt' closed but it is, and tightly. ...
It is indicating that there is a problem either with the door lock or the door locked sensor requiring a service call, sorry ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Sep 19, 2011 | Kenmore HE2 Plus Front Load Washer
The code f-DL displays whn I try to start the machine . I was thinking the door lock was jambed so I used a flat tip screw driver to jog the lock. The problem now is the lock is now locked and won't...
Remove the screws attaching the bottom flange of the lower front panel to the machine cabinet then pull the panel down and off. You can prop up the bottom front edge of the washer or cushion and lean it against the wall to access and remove the screws more easily. Once the panel is off, reach up along the inside of the front panel and locate the bottom of the door lock and switch assembly on the right side. Locate the tear-drop shaped tab then gently pull it down until a click is heard.
You can also remove the door gasket retaining hoop by stretching apart the retaining spring at the bottom of the door opening. Gently peel the part of the door gasket near the door lock/latch assembly off the lip of the right side of the door opening. Remove enough of the door gasket to access the door lock/latch assembly behind the front panel. Pull down gently on the release tab until a click is heard.
The FdL code indicates a door lock failure and you need to replace the door lock/switch assembly if the problem persists after resetting the door lock. Click on the link below for the details of the procedure.
Kenmore Elite and Whirlpool Duet Error Code FdL
Jul 16, 2011 | Kenmore Elite 45986 Front Load Washer
Kenmore model 44142400 door lock
Try unplugging for 2 minutes and if display looks the same, then theres and elec. issue.
Mar 08, 2009 | Kenmore HE2 Plus Front Load Washer
Door pops open during wash cycle
this is joyce
What I would do in this situation is fix the door lock first before I would do another load of clothes. you can go to Kenmore.com put in your model # and download your manual to your machine if you want to fix yourself
or you can call service tech out. I will help you find one in your area if you need.
thanks,
joyce
Feb 04, 2009 | Kenmore 44072 Front Load Washer
Did you try to unplug the machine and plug it back in? that is how I reset the lock on mine.
Dec 28, 2008 | Kenmore 43142 Front Load Washer
Kenmore elite front load washer
Make sure they didnt lock the control panel if it just beeps when u press buttons that might be it. there is a button u can press and hold for 3 seconds to lock and unlock the control hope that helps
Mar 13, 2007 | Kenmore 44072 Front Load Washer
Kenmore 44072 Front Load Washer Logo
75 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
