Question about Dryers
How do I get to the baffle on my maytag atlantis? It broke off and I ordered a new part
  • 1 more comment
  • Anonymous Mar 20, 2008
    Baffle broke on Neptune dryer needing replaced
  • therapydog Jun 30, 2008
    I also have a broken baffle on my MDE 6200 AYW  Atlantis, How do I replace it?  Karen
  • James Greene
    James Greene May 11, 2010
    Can you send me your model number please. Then I can get you a diagram and lead you through. Thanks and talk to you soon.
    Sniper:
  • 65 Answers
Pop open top using screwdriver, rotate drum slowly by hand until broken baffle at 12:00 position remove two screws and reverse process.
Posted on Feb 16, 2008
How do I take the top off of the Maytag Atlantis dryer?
they are called baffles. and can only be accessed by getting to the outside of the drum. have to remove the body but u may have a bad baffle if the screw hole is busted up?
Sep 14, 2014 | Maytag Atlantis MDE7400AY Electric Dryer
Need to replace a baffle that broke off . MED9800TKo model baffle broke off insde on the dryer drum
Remove the top panel to access the outside of the drum where the baffle securing screws are found. Remove the three hex-head screws from the rear flange of the dryer's top cover the lift the rear of the cover and slide it back so the tabs clear the catches on the bracket and remove the cover from the unit.
Turn the drum until the baffle screws are on top then remove the screws and the baffles. Install the new baffles then the top cover. Make sure that the tabs slide under the bracket catches when you reinstall the top cover. The top cover screws have nylon flat washers on them. Be sure to use these screws when you reinstall the top cover.
Jul 18, 2011 | Maytag MED9800T / MED9800TQ / MED9800TK...
I have an MDE7600AYW electric dryer and two of the three fins came loose inside the dryer and one of them is now lost. Who can I contact to purchase a new one with the installation screws???
The fins are called "Baffles" and you can find the parts at the link below:
http://www.partselect.com/PartDetail.aspx?Inventory=2035811&SourceCode=1
Jan 06, 2010 | Maytag Atlantis MDE7400AY Electric Dryer
The paddle broke off in my Maytag Atlantis Dryer
you need to remove the frt cover 1st and then the screws will be accessible to remove top cover
Sep 19, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
What is this called
they are called "drum baffle" and you can order online at Repairclinic.com...
great source for parts. check here : http://www.repairclinic.com/Maytag-Dryer-Parts?n=8
May 25, 2009 | Maytag Dryers
MDE 6200 AYW Maytag Atlantis broken baffle
To lift the top and access baffle screws, proceed as follows;
1. Remove door hinge screws from cabinet. Door can remain in place.
2. Remove screws and plastic retainers opposite door hinge
3. Grasp each side of the top front panel and pull forward. Lift to remove panel
4. Remove lid retainer clamps from each front top corner.
5. Lift top to access drum baffle screws.
If you need further assistance, let me know
Regards,
reg501
Jun 30, 2008 | Dryers
A tumbler fin
This isn't much help, but those fins will break off. I have had them break off. I am ordering some new ones, called "baffles" and will be installing them. I hope I can the top open on the machine.
Jun 16, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
Maytag Atlantis Model 6400AEW Dryer bought 2003
On my 2006 Maytag Atlantis the top is held down by 4 screws 2 under the front and 2 on the back.
To remove the 2 on the front you need to remove the screws in the door and remove the door and front panel, than remove the 2 screws. The 2 screws on the back hold a white plastic fastener. After removing the screw, pry the bottom of the plastic fastener with a flat head screwdriver. Than with a very thin screwdriver or a thin pry bar wedge it under the top cover and just pop it off. Take care to not scratch your dryer while prying the plastic piece off.
Good Luck
Jan 11, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
Dryers Logo
236 people viewed this question
Top Dryers Experts
Marvin
Marvin
