Question about Panasonic CT-32SX12 32" TV
My Panasonic CT-32SX just stopped working? I came to turn this TV on and I do not get any response. It's just as if the TV were unplugged. Everything is working correctly around it and we did not experience lightning storms, power outages, etc. I've noticed through browsing on-line that this is a common problem with the CT-32SX and I'm looking to see if anyone has some detailed information regarding the faulty power supply system. Any suggestions are greatly appreciated. Chris Walke
  • 1 more comment
  • gooman666 Jul 10, 2008
    hig frequency beeping
  • Anonymous Apr 01, 2009
    My Panasonic CT-32SX12 32" TV just stopped working. I turned it off and later in the day tried to turn it on again and nothing. Everything is hooked up the same as before but the TV does nothing when the on button is pressed. It is like it is unplugged.
  • Anonymous Apr 29, 2009
    It's like the TV is just unplugged.
4 Suggested Answers
  • 18 Answers
SOURCE: After power outage, tv doesn't turn on
First, the blinking light is a code, how many blinks? Second, regulators are not resettable. Don
Posted on Aug 17, 2007
Orbixx
  • 133 Answers
SOURCE: panasonic ct-36hl43 tv
This is usually down to a safety feature cutting out the Television from harming itself. Or quite possibly a fault that make it turn itself off - it may well be thinking it's receiving the command to turn itself off. Either way, it's impossible to find out without opening it up. A professional repair is the only way, check up on your warranty. You may want to plug it into a different power source, just on the off-chance that it may solve your problem - but don't get your hopes up.
Posted on Sep 07, 2007
sodeep
  • 3267 Answers
SOURCE: panasonic CT-36HX42F I turn it on and then, turns off
It seems that the electrical relay's, it getting completed is not able to create the high voltage required for proper display. Hence on switching it on, the power LED will immediately light up but since the circuit is not completed it switches to standby and then off. Get the relays replaced and make sure you connect the main power chord to a 15 Ampere rating wiring usually the line meant for A/c and hot water Geyser(called as high power line)..........sodeep
Posted on Sep 19, 2009
I have a panasonic tv CT-34wx54j red light 5 blinks
The power supply probably has failed. The clicks indicate it is trying to start up but can't.
Dec 30, 2013 | Panasonic Viera TH-50PZ85U Plasma TV
My Panasonic CT-27SC14 tv won't turn on. worked fine last night. The cable box does but nothing happens with the tv..whether I use the remote or the power button. Unplugged it from the power source and...
hi,disconated from AC main. if you know bit of repairing tv and soldering? this what to look for main power board. 1 x dry joints 2 x leaky capacitors just remember when changing cap's make sure to use the 105' and same value.
Feb 04, 2010 | Panasonic CT-27SC14 27" TV
Blurry Screen on Panasonic CT-32HL44
I solved my problem. Apparently the RCA cables where missing with the image. So I bought some Component cables and that fixed my problem.
Dec 30, 2008 | Panasonic CT-32HL44 32" TV
CT-36HX42F
I had the same problem. Sometimes the processor gets overheated, particularly when dealing with high definition signals. Unplug the television from the power strip or wall outlet and it should reset everything. When you plug it back in it should work. Not a long-term solution, I know, but it will get your TV working again.
May 07, 2008 | Panasonic CT-27SX11 27" TV
No response from remote
Remote problem could arise from either tv or remote. First check your universal remote on some other tv and if it is okay your tv's infrared sensor has stopped working. You can get it from the local component shops, take the existing sensor with you. This problem could be from the micro processor in rare cases. Best of luck.
Jan 27, 2008 | Panasonic CT-32SL14 32" TV
Panasonic tv help
my tv screen just turned brown. sound and everything else works fine?????
Panosonic HD tv
Jan 24, 2008 | Sony KV-27S65 27" TV
Tv will not turn on
This set has a common problem with th main fuse opening for no other apparent reason... One of the few exceptions to my corner-stone statement that a fuse is never the cause only a symptom..
Don't replace it though with the same type grade, use a 6.3a slo-blow gma type - available at Radio Shack... Try that and if everything works you're back in business.. If not we nee to find a cause...
Bill
Dec 08, 2007 | Panasonic CT-36SX12 36" TV
Panasonic CT-32SX12 32" TV Logo
87 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
