Many of you might have faced issue called windows – drive not ready and a message ” exception Processing Message c0000a3 parameters 75b6bf7c 4 75b6bf7c 75b6bf7c” right below of that. It will keep disturb you every now and then even if you close this number of times This normally happens when you remove a drive like Floppy drive, CD Drive or Pen drives from its working conditions without proper instructions. You will get this error message when you remove a CD/DVD from CD/DVD drive during a process happening form CD/DVD like installing software or accessing files etc.
In that situations the programs seeking the files from the drives but its not finding there.So we are getting this error.
You can see the error below.
Here is the steps to solve the issue:a) Simply put a CD/DVD in to the CD/DVD drive and click on Continue.
b) Open the CPU box and make sure all the data cables connected properly.Like data cable for Floppy drive and CD/DVD Drives.
c) Go to BIOS and disable the Drives which you are not using. Nowadays mostly nobody uses Floppy drive. So you can disable Floppy drive. You can disable unused IDE or SATA ports in bios.Save the settings and restart your PC, Now you will not get the annoying pop ups now.
