Question about Philips 55PW9363 55" Rear Projection HDTV-Ready Television
Dptv335 Philips 55PW9363
Hear relay click led on front lights up red no audio or video. I found blown fuse two shorted diodes 6302,6303 and resistor 3306 15 ohm open .i replaced the convergence ics still a no go.i also replaced ic 7302 mc44603ap
  • dogset Feb 28, 2008
    WOULD RATHER FIX ON A COMPONENT LEVEL MODULES ARE TWO HIGH THAT IS FOR THE PEOPLE THAT DONT KNOW HOW TO REPAIR SETS OR JUST HAVE TO MUCH MONEY TO BLOW.
  • dprice75 Mar 16, 2008
    I have the same problem - The red blue & green are out of alignment & it looks like the old 3d colors. I've tried adjusting the coverage & multipoint coverage, but it appears the TV is so far out of alignment on the red that this method does not get it back into spec. I also reset TV to factory settings & the red is still way off. In addidion to this problem, the picture is out of "keystone" in some areas. The view is curved & looks as if it were "wrapped around a fishbowl", kind of like when you adjust a CRT computer monitor. If anyone knows how to fix this or what part needs to be replaced, please help. My only other options are to buy a new TV or have a company repair both of which will cost hundreds of dollars. Thanks !!!
  • Philips Master
  • 3,459 Answers
Did you ever get this set fixed? If so what was the solution?
Posted on Oct 24, 2008
I HAVE A PHILIPS 55PW9363, I NEED PART NUMBER FOR THE LAMP. MY PICTURE IS GETTING BAD ?
Posted on Oct 22, 2008
    President:
  • 4,402 Answers
I would send the board in for repair... ptscorp.com
Posted on Feb 15, 2008
Where is the reset or fuse on the lc391eme tv
The fuse is located on switched mode power supply board. If the fuse has blown the set will be dead no standby led light on front of set also when you plug the set into a power outlet you should hear the relays clicking. if you don't hear the clicking then the fuse has blown or another part of the power supply has failed and will require service.
Apr 27, 2014 | Emerson LC391EM3 39 in. LCD HDTV
Phillips 32 inch lcd will not turn on
What is status of Led lights on front of set?
Mar 14, 2012 | Philips 32PFL3505D 32 in LCD TV
My 42 inch tv wont turn on model nu 42pfl5603d/10
what you need is trouble shooting and a good digital tester to fix that problem. since the problem is power off start at the back light check if their is a small maldischarge at the module then check if their is a click on relay and then if the front LED is turn from red to green. then check the power supply if normal, check the low and high voltage except the stand by supply. then check the Y board the Va and Vs supply look for the blown fuse. and then the Z board check the 5v and Va supply, check also blown fuse.
Apr 28, 2011 | Philips Televison & Video
I just bought the 55 inch philips dptv335 tonight. it was used and did not come with an owners manual. it refuses to turn on although there is a sound like the audio is turning on and a click like the...
This is a very common problem. Your Flyback/HVG has gone out. The most commion symptom is that you have audio but no video. We see this all the time on the DPTV3XX models. The bad news is that its nearly impossible to find one.
You can get complimentary replacment instructuons and part numbers at the following link.
http://www.tvrepairkits.com/component/content/article/104
Dec 24, 2010 | Philips 55PW9363 55" Rear Projection...
Philips 42PF5321D/37 Plasma No Picture Six Red LED Flashes
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Counting of number of blinks to Philips TVs is entirely different to that of other brand TVs. It is not a direct count procedure. The site have details about how to count the number of LED blinks [Fault Codes] to Philips brand TVs are given; along with details of the faulty circuit location.
Mar 12, 2017 | Philips Televison & Video
Philips 37pf9975/12 wont switch on
i have a Philips 37pf9975/12 and after about 1hr it switches itself off the green light stops on the side but you loose picture and sound. if you push the stand by button it clicks for about 1 min and then turns itself back on???????
Jan 09, 2009 | Philips 37PF9975 37 in. HD-Ready Plasma...
Philips DPTV335 Tripping
Even if you find the problem you most likely can't buy the parts, this TV type is obsolete.
May 01, 2017 | Philips 55PW9363 55" Rear Projection...
Non working TV, can someone help???
Replace Q8023 (top224y) which you will find is blown apart or it's shorted, and the Q1 (2sk2662) which would check to be shorted inside the heat shrinked wrapped board next to the blue relay and the smd zener diode ZD8018 (shorted) along with the ceramic fuse F8001.
I don't remember the value for the zener diode but there's lots of them with the same color code. You will have to take one of the others off to test on a resistor jig to get it's value.
The 2SK2662 is a cross for the original.
Nov 29, 2007 | Electrograph Systems DTS42W 42 in....
No video, no audio, red light on in front of TV
Excellent visual acuity technique!! I try to teach that procedure.
IC F6629B is probably shorted and at least one other part will
be open, possibly a zener diode,a fuse,a resistor or combo.
The service diagram would help.Be sure to use OEM first quality
parts.Let me know if you need more help.
Sep 25, 2007 | Hitachi 61SDX01B 61" Rear Projection...
Philips 55PW9363 55" Rear Projection HDTV-Ready Television Logo
748 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
