Question about Canon imageCLASS D761 Copier
Paper dents there is a roller in the copier that leaves dents all the way down the center of the page. how do I get to the roller that might be the problem and adjust it. I think it happens after the ink gets on the paper so that the result is that I have dents and ink blobs running down the center of the page. thank you for your help, Jim
  • 42 Answers
We had one doing the same thing-turned out to be one of the fusers plastic exit rolls was out of position causing a dent in the paper same direction as paper travel.
to remove the fuser you will need a small offset phillips #2 screwdriver and some patience.
1. pull platen to left to acess upper cover screw, remove upper and lower plastic covers from exit end of copier 3 screws. as well as left cover next to paper exit area{pops out}
pull back black protective sheet and disconnect 3 connectors one on circuit board two going to fuser assembly. to remove fuser assembly remove 3 screws with your offset driver. fuser pulls up and out. now you can inspect for damaged fuser film sleeve or mispositioned exir rolls. reassemble slowly-panels need some coaxing to get to sit properly.-maybe hand crank a piece of paper through the fuser using it's drive gear to see where the problem is coming from.
Posted on Apr 22, 2008
    Problem Solver:
  • 14 Answers
I believe you have two problems. One the dent you are talking about unless I see it I don't know for sure but I believe this is minor and something you need to live with. The paper goes through a fuser which uses a teflon sleeve over a heater surface and a lower pressure roller made of rubber. It may be that you need a new lower pressure roller they get little cuts in them sometimes. Two the spots are probably from a faulty toner cartridge. It has a leak.
Posted on Feb 13, 2008
Printed pages are dented as if embossed at regular intervals. The dents are consistent as to shape and location. Printing appears in the shapes as required.
This is caused by the fuser unit, most likely it has some hard lumps of toner on one of the rollers. You may be able to clean this off, this video may help, if not then fit a new fuser unit.
https://www.youtube.com/watch?v=BMYZM0_OWKE
Aug 23, 2014 | Brother MFC-9840CDW Laser Printer
Oce 7051 plain copier has dust or something on one of the rollers - prints have a trail of marks across sheet, repeating every 10 inches from top to bottom of page. Probably need to remove or access...
If the drum has marks on it, you might have to replace it.  Sometimes the fuser rollers can leave marks on them as well.
Check for lines on the drum first.  If they are there, it could need a drum replacement.
Sep 17, 2008 | Office Equipment & Supplies
When the printer pulls a sheet down it grabs the right side of the sheet (as you face the machine) leaving the left side up, to warp the sheet and make a grinding noise trying to pull the sheet in. Of...
Solution: Cleaning The Paper Feed Rollers (Windows) iP1600
Clean The Paper Feed Rollers (Windows) Instructions how to clean the paper feed rollers. If the paper feed rollers become dirty, they may not be able to properly feed paper due to the feed roller's slippage.
If paper does not feed correctly, perform the following to clean the paper feed rollers:
  1. Open the printer properties.
  2. Click the 'Maintenance' tab and click 'Roller Cleaning'.
  3. Remove all sheets of paper from the auto sheet feeder.
  4. Confirm the following message, and click 'OK'.
    Note: Clicking 'OK' will activate the paper feed rollers 30 times. Thisactivation will take about 90 seconds. Do not perform other operationsuntil this operation has finished.
  5. Confirm the following message, and click 'OK'.
  6. After the continuous paper feeding operations in step 5 have finished, load three sheets of plain paper and click 'OK'.
  7. Confirm the following message, and click 'OK'.
    Note: The following message is displayed when the paper is fed and ejected.
  8. Click 'OK'.
Roller Cleaning is completed.
Jul 02, 2008 | Office Equipment & Supplies
Lanier 6613 copier. Image is offset down the page by 3 and 1/2 inches. Is this a setup issue? Any suggestions?
try making a copy and then open the door when the paper is in the center of the machine. if the image is offset before the paper hits the fuser(hot) rollers>the problem is in your drum unit (most likely a cleaning blade. If it happens after going through the fuser(hot) rollers you have a fuser roller problem. Most likely you have a worn drum cleaning blade which is cheaper the a drum. Good Luck.
Dec 17, 2010 | Lanier Office Equipment & Supplies
Vertical dots down center of paper HP 1320 printer
If the pattern repeats down the feed path of the paper, then a roller is causing it. The toner cartridge replaces the transfer drum, the fuser roller remains in the printer. Since your old cartridge does not show this problem the fuser roller sounds to be fine. Return the recently purchased toner for a replacment, you should be fine. If not then a proper cleaning by a certified technician would be in order.
Aug 26, 2009 | HP LaserJet 1320 Printer
Thick black line on printed page
If the line runs the way that the paper does I.E. vertical on a portrait then it is dirty rollers normally.
If you open the lid and wipe the rollers this shoukd reduce or eliminate the black lines.
May 03, 2009 | Canon PIXMA® MP530 All-In-One Printer
Small dent in paper
check pc drum or fusing unit roller
Oct 13, 2008 | Minolta 2430DL Color Laser Printer
PAPER JAM
Rotate tires. Pull out paper tray. Pull down on red low paper indicator at left bottom. Two rollers come down on axel near center. I pulled off the rubber tire like roller, then twisted the roller inside out and reinstalled it with the fresh side out.
If tires dry out again will probably buy new ones from ebay.
Jun 26, 2008 | Lexmark E232 Laser Printer
Dents and smears
PROBABLY A BAD LOWER FUSER ROLLER. HARD TO GET OUT UNLESS YOU KNOW WHAT YOUR DOING. NO WAY TO ADJUST, IT JUST NEEDS REPLACED.
Jun 17, 2008 | Canon imageCLASS D761 Copier
Canon MP830
You most likely have some ink residue on the pickup, feed, or registration rollers for the problem to be on the back of the page. Use a flashlight and a q-tip moistened with isopropyl alcohol to swab all of the rollers in the paper path and see where the higest concentration is. You could also try to LIGHTLY dampen a sheet of paper with alcohol and print a "Blank" page a few times with it then do the same with fresh paper.
Jun 04, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Canon imageCLASS D761 Copier Logo
125 people viewed this question
old marine
old marine
