Question about Canon PowerShot A520 Digital Camera
Turning on. my camera won't turn on no matter what I do, for a few days it said low battery and i won't lie i kept turning it on, but one day it turned off but the lens never went back inside and the camera won't turn on. I replaced the old batteries with new ones, but it didn't work. I press the button, but the light only flashes for a second before blinking out.
  • Canon Master
  • 4,738 Answers
Here are some simple things to try first for a camera that won't power on. They won't work for every case, but they're worth a try. Think that the first listed fix may work for your camera:
http://camerarepair.blogspot.com/2007/11/simple-fix-for-dead-cameras-that-wont.html
Posted on Feb 16, 2008
Low battery
Try cleaning the battery contacts in the camera first with a pencil eraser and then with a cotton swab lightly dampened with rubbing alcohol.
May 20, 2010 | Kodak EasyShare DX6340 Zoom Digital Camera
Pentax Optio S10 - Turning on problem
What kind of shape is your battery in?...old, been charged many times, needs charged, dirty contacts on the battery or inside the camera?
Sep 17, 2009 | Pentax Optio S10 Digital Camera
My camera won't turn on
I had exactly the same problem with mine. Here is what I did to fix it.
put new battery in
1- Clean around the lense
2- While turning the camera off, press the lense in (up and down with lense movement) NOT too hard. Try that a few times until the lense either retract 100% or almost 100%. If almost 100%, press on the lense a little harder so that the lense be in 100% (like it normally closes)
If you turn your camera on and off a couple of times, your camera will work as it does normally.
GOOD LUCK!!!!!!!!!!
Jun 14, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
P990i camera application randomly turns on and off
its because of the camera cover its a hardware problem ur cover is sensitive or messed up try fixing ur cover cz when u move the cover back&forth the camera acts...i hope this will solve ur problem.
May 15, 2008 | Sony Ericsson P990i Cellular Phone
FE 230 will not turn on
maybe buy a new battery!!!!!!!!!!
Mar 19, 2008 | Olympus FE-230 Digital Camera
Phone does not work properly
There is some pieces on the board inside your phone you broke off when you dropped it. It will need to be fixed by a technician. Hopefully you didnt brake the flex cable. Have them check the cable before doing anything else.
Aug 19, 2007 | Motorola Mobility MOTORIZR Z3 Cellular...
HP photosmart M417
Hi yban, Not sure if this will solve it but many times such problems occur from 2 reseaons A) loose parts in the battery compartment - causing cutting electricity. See if you can detect any problem there. B) when the memory card is damaged or not well placed. Try running it with an alternative memory and see if the problem reoccurs. Let me know if this helped. Thanks, D.
Apr 30, 2007 | HP Photosmart M417 Digital Camera
Won't turn on
Ouch! You can't use an AC adapter with any battery-operated equipment you choose to just because the plug fits physically. The A70 requires 5-6 volts, and a Pavilion adapter typically puts out 18 volts. You most probably blew out your Canon's power supply within a few seconds, unless it's fused somehow. Next stop: tech support/repair shop/camera cemetery. Sorry.
Aug 23, 2006 | Canon PowerShot A70 Digital Camera
DSC-T7 Power Problems
The only and the only solution is to get the replacement as this seems to be a defect in the camera and you should get it change immediately.
Sep 12, 2005 | Sony DSC-T7 Digital Camera
Canon PowerShot A520 Digital Camera Logo
61 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
