Question about Dell Latitude D600 Notebook
Battery Charging
Battery wont charge! Warning message says the computer cannot identify the battery so it wont charge, any suggestions?
  • 58 Answers
Try to go to the bios page (F2 on start up). Load defaults. save and exit.
Posted on Feb 13, 2008
I replaced my battery now my car is cutting out and wont stay running how do i reset computer?
Make sure the battery is tightly connected , the cables should be securely fastened to the battery terminals.
Make sure the alternator is charging it, if you are getting any warning lights on the dashboard regarding charging check the belt too.
The computer of your car should have reset when the battery was removed.
Jun 23, 2015 | 2005 Saturn VUE
Why doesn't it charge at idle?
It depends if the system is RVC/regulated voltage control. If so, there are about six modes of operation. One is, "fuel economy mode". In that mode, the targeted generator out-put is 13 volts and battery state of charge is greater than 80%. There are two other conditions.
Is there a battery discharge problem? Does the instrument cluster give charging system message or warning lamp?
Any charging system trouble codes? My info on your charging system is limited.
May 02, 2013 | 2010 Chevrolet Express Passenger
I have charged it and i still cant get it to turn on.
If your laptop works fine while plugged in but stops working while unplugged it's likely that either your laptop battery is bad or your laptop is not charging the battery properly.
Below are steps that can be taken to help identify the cause of this issue.
Leave power plugged in
Make sure the computer has been charging from the power plug for at least two hours before attempting to unplug it.
Remove and reconnect battery
In some situations the battery can become loose.
Removing it and then put it back into the laptop.
Third-party utility
Use a third-party battery utility to determine the total capacity of the battery. For example, BatteryCare is a free software utility capable of doing this.
Replace battery or AC adapter
If your computer is still in warranty we suggest skipping to the next step.
If the above steps have been completed, we suggest replacing the battery in the computer or AC adapter. In most situations it's a bad battery.
hope this helps
Sep 05, 2012 | Computers & Internet
What is the solution the battery is fine
Third-party utility
hope this helps
Aug 05, 2012 | Dell Latitude D510 Notebook
Can't identify power source warning
Your AC Adapter Power Cord is bad based on what you are telling in your request for help. You need to replace the AC Adapter Power Cord.
You can further isolate and verify by the following steps:
If you remove the battery, and plug in the power cord, but the computer will not boot up or work, then the power cord is bad.
If you have them both plugged in and you are running off the battery then the power cord is bad and it is not charging the battery. Eventually your laptop is not going to power on because the battery will be drained and cannot be recharged until you get a working Power Cord.
May 15, 2012 | Computers & Internet
Battery light went on while driving and radio went off in my 2003 pt cruiser
Check or have checked the alternator. If it is bad the radio is not the only thing that will shut off. When the battery drains enough the engine will shut down.
Jul 30, 2011 | Chrysler PT Cruiser Cars & Trucks
ABS malfunction warning light on Airbag malfunction warning message Battery not charging Message No power steering battery totally flat
This time of year alot of batteries fail because of the cold but a bad battery will not turn on the charging light. This usually only occurs when the alternator isnt charging. When the battery drains enough its possible thats why you have these other issues.
Codes only set when the computer does not see the correct voltages
Dec 20, 2009 | 2004 Saab 9-3
Battery Not Identified.
hello
I suggest you a few steps to solve your problem.
  • remove the charger and press the power button till all residue power is radiated.
  • then connect the charger and charge the battery fully and try booting the system.
  • if this don't work check the output of your charger and see if it is working fine.
  • if it is working fine then remove the battery and connect the charger and try starting the system.
  • if it works then there are two things possible.
  1. battery gone.
  2. IC responsible for charging is gone.
i hope you can figure out the problem through this.
Thank you
Aug 07, 2009 | Dell Inspiron 1525 Laptop
Battery problem for my k800i
if charge down in 3 hours mean battery problem. if the mobile show "not charging" message mean charger problem.
Jul 07, 2008 | Sony Ericsson K800i Cellular Phone
Dell Latitude D600 Notebook Logo
122 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
