INOi MH-720 problem
Hi, I have an INOi MH-720 wich I have used for a few months. I had the unit previosuly on the FAT32 system and decided to convert it to NTFS. Since I had big files on the disk I used the "convert h: /FS:NTFS" command on the cmd on windows xp. The conversion process was succesfull and it has no problem when connecting to any pc. But now everytime I attempt to connect my media drive to use the av playback function it starts but gives me a no disk screen and stays like that.
The drive is running on basic disk type and just has the primary partition
so my questions are:
- is there a solution to this issue?
- is there a solution to this issue that doesnt require a full format of my drive?
thanks in advance
luis paez
  • scott209 Dec 19, 2008
    I've owned an iNOI MH-720 for about a year. A few days ago the video output died. The unit turns on, the hard drive spins, and the unit responds to signals from the IR remote control but there is no video from the component or composite outputs.
  • briankv Dec 23, 2008
    I have tried several times of formating the drive different ways. Computer sees the drive fine as NTFS but the media player never pulled up a directory listing. When formated Fat32 always worked fine. Have searched internet several times still empty handed.
  • 121 Answers
Sounds like it needs formatted
Posted on Mar 03, 2008
Is WDBAAU0015HBK is fat 32 system file format? IsWDBAAU0015ABK is also available? How to convert my existing seagate 1tb hard disk from ntfs to fat32 with out making partition?
You can convert FAT32 to NTFS, but you cannot reverse this process. If you want to set up the hard drive for FAT32 you need to delete the NTFS partition the create a new partition and then format in FAT32.
Aug 24, 2011 | Western Digital WD Elements Desktop...
Tip
How to Convert NTFS External Hard Drive to FAT32?
My friend Michael bought an external hard drive last month, yesterday he ran to me and ask how to convert external hard drive from NTFS to FAT32 safely and easily? I was so curious about why does he want to convert NTFS to FAT32; he said NTFS partition can't be read by DOS system. Since protecting data and files, I recommend him to convert external hard drive from NTFS to FAT32 with a third-party software-AOMEI Partition Assistant, which can convert hard drive from NTFS to FAT32 without data loss.
To computer users, NTFS and FAT32 are not strange. But seldom of them can tell what the difference between them. NTFS and FAT32 to partition are what DOC and TXT to text. In text, the file with DOC format can't be read by TXT application. Similarly, in some condition, not all files in different formatted partition can be read by same application. First, you'd better know some knowledge about NTFS and FAT32.
A Brief introduction of NTFS and FAT32
About FAT32
FAT 32 is one of partition format in windows system. It has 32bit file table, which strengthen FAT32's management to partition, and break through the limitation of 2GB space in every partition. Since the production cost of hard drive decreasing, the volume capacity is increasing. After applying FAT32 partition format, a big volume hard drive can be definite as a partition but not be divided into multiple partitions. It is good for management to hard drive. Now, FAT32 is replaced by NTFS.
About NTFS
NTFS is standard file system after Windows NT, 2000, XP, server 2003, server 2008, Vista, and 7. It replaces FAT to offer file system for Microsoft. NTFS make advanced on FAT and HPFS, such as to support metadata.
The difference between NTFS and FAT
As mentioned above, NTFS and FAT both are file system. However, NTFS is produced late than FAT32, but NTFS is more advanced in technology. In summary, the specific distinction are following below:
NTFS can support up to 64GB single file and 2048GB partition. FAT32 supports up to single file with 4GB and partition with 32G.
NTFS does not need Defragment your hard disk.
NTFS support to compress partition, folders and files.
NTFS takes a little cluster, which can help to manage space of hard drive effectively, and avoid wasting space of hard drive at the most extent.
In NTFS partition, you can share sources, folders and set access permissions on files. It is more secured than FAT32 partition.
How to know which partition format is suitable for you
As mentioned above, NTFS and FAT32 have its own advantages. When we choose which file system, you should consider the factors below:
Computer is installed with single system, or multiple systems.
The number and capacity of local installed hard disk.
Whether has consideration about security or not.
If computer is installed single system, and there is security to consider, you can select FAT32. Or NTFS is not bad choice absolutely.
Why need to convert NTFS External Hard Drive to FAT32?
NTFS and FAT32 are two different types of file systems, and both of them are commonly used and contain different characters. You may make conversions between the two types, and here we got several cases that you need to convert external hard drive to FAT32:
If your external hard drive is formatted in NTFS, you would not be able to access some files from DOS mode or Windows 9X, then you need to covert external hard drive to FAT or FAT32.
NTFS can't be recognized by many devices, such as Xbox 360, PS3, etc. in that case, you have to convert the external hard drive to FAT32 so that it can work with your devices.
There are more situations in which you need to convert external hard drive to FAT32, and there are different ways which you may realize the goal.
Methods to convert NTFS External hard drive to FAT32
At present, there are two main ways that you may convert external hard drive to FAT32, one is to convert to FAT32 with Windows built-in Disk Management, and another one is to convert to FAT32 with third-party software like AOMEI Partition Assistant. Let's see the details:
Method1: Convert an External Hard Drive by reformatting
1. Open the Disk Management in Windows.
2. Right click on the external hard drive and select "Format..." in the drop-down menu.
3. Select "FAT32" in the "File system" line and then choose "Quick format".
4. Finally click "Start" to format, and this process may cost you minutes.
Note: If the drive is larger than 32GB, the "FAT 32" option would be invalid and once format, the information or data in the external hard drive will disappear. So, backup the data or partition if necessary and you need to know how to convert hard drive larger than 32GB into FAT32.
Method2: Convert an External Hard Drive without formatting
You can download the third-party software to convert external hard drive from NTFS to FAT32, what is the most advantage is that convert NTFS to FAT32 without data loss. Comparing with disk management in computer, the third-party software will save your time and money. You don't need to buy other external hard drive to store data, just for converting partition format. Of the third-party software, AOMEI Partition Assistant is good choice. The specific introduction of how to convert NTFS external hard drive to FAT32.
As a kind of advanced partition software, AOMEI Partition Assistant can easily convert an external hard drive to FAT32, and you can also convert an external hard drive larger than 32GB into FAT32. This software is running well with Windows platform including Windows 2000, XP, Vista, Windows 7 and Windows 8. Both 32-bit and 64-bit Windows editions are supported. With its help, you need no to format your external hard drive and thus you can convert NFTS to FAT32 without data loss. Now, you may download AOMEI Partition Assistant Pro Edition and have a try.
source from
on Dec 29, 2017 | Computers & Internet
Tip
Convert FAT or FAT32 File system into NTFS
You can increase the performance of your computer using NTFS (New Technology File System) hard drive volume with windows XP, because this advance file system provides some extra features, for example security, reliability, file encryption and Compression features.
But if you are still using old file systems like FAT or FAT32, you can covert it into NTFS with a simple command. The interesting thing is that you can convert your hard drive volumes file system without losing data on the drive. Follow the giving steps to convert FAT or FAT32 partition to NTFS:
  • First go to Start button then click on Run option.
  • Now type here “CMD” and press Ok to open command prompt.
  • At the command prompt type convert drive letter name: /fs:ntfs
  • For example if you want to convert drive E to NTFS then the command will be “convert e: /fs:ntfs”.
  • Now restart your computer and enjoy NTFS features, but keep in mind you cannot covert back it to FAT or FAT32 again.
on Jan 29, 2010 | Computers & Internet
I have Pentax 100D and using Ni-MH battery. But battery is going empty very quickly after few photos
Sounds like, due to age, the batteries aren't able to hold their charge well anymore. I'd suggest picking up a new set of Ni-MH batteries.
May 10, 2011 | Pentax K100D Digital Camera
In the setup I defined the Video to 720, and now I cant see anything on the TV, can you help me restoring the settings?
One way to do it is shut the system down by the button on your tower and bring it back in safe mode. Do a system restore back to when it was working.
Dave
Mar 12, 2011 | INOi HD350 USB 2.0 Hard Drive
Cannot format octagon veridisk T118 usb
Try this
Microsoft Windows 95, 98, ME syntax
Formats a disk for use with MS-DOS.
FORMAT drive: [/V[:label]] [/Q] [/F:size] [/B | /S] [/C]
FORMAT drive: [/V[:label]] [/Q] [/T:tracks /N:sectors] [/B | /S] [/C]
FORMAT drive: [/V[:label]] [/Q] [/1] [/4] [/B | /S] [/C]
FORMAT drive: [/Q] [/1] [/4] [/8] [/B | /S] [/C]
/V[:label] Specifies the volume label. /Q Performs a quick format. /F:size Specifies the size of the floppy disk to format (such as 160, 180, 320, 360, 720, 1.2, 1.44, 2.88). /B Allocates space on the formatted disk for system files. /S Copies system files to the formatted disk. /T:tracks Specifies the number of tracks per disk side. /N:sectors Specifies the number of sectors per track. /1 Formats a single side of a floppy disk. /4 Formats a 5.25-inch 360K floppy disk in a high-density drive. /8 Formats eight sectors per track. /C Tests clusters that are currently marked "bad." Microsoft Windows 2000 and Windows XP syntax
Formats a disk for use with Windows 2000.
FORMAT volume [/FS:file-system] [/V:label] [/Q] [/A:size] [/C] [/X]
FORMAT volume [/V:label] [/Q] [/F:size]
FORMAT volume [/V:label] [/Q] [/T:tracks /N:sectors]
FORMAT volume [/V:label] [/Q] [/1] [/4]
FORMAT volume [/Q] [/1] [/4] [/8]
volume Specifies the drive letter (followed by a colon), mount point, or volume name. /FS:filesystem Specifies the type of the file system (FAT, FAT32, or NTFS). /V:label Specifies the volume label. /Q Performs a quick format. /C Files created on the new volume will be compressed by default. /X Forces the volume to dismount first if necessary. All opened handles to the volume would no longer be valid. /A:size Overrides the default allocation unit size. Default settings are strongly recommended for general use.
NTFS supports 512, 1024, 2048, 4096, 8192, 16K, 32K, 64K.
FAT supports 512, 1024, 2048, 4096, 8192, 16K, 32K, 64K, (128K, 256K for sector size > 512 bytes).
FAT32 supports 512, 1024, 2048, 4096, 8192, 16K, 32K, 64K, (128K, 256K for sector size > 512 bytes). Note that the FAT and FAT32 files systems impose the below restrictions on the number of clusters on a volume:
FAT: Number of clusters <= 65526 FAT32: 65526 < Number of clusters < 268435446
Format will immediately stop processing if it decides that the above requirements cannot be met using the specified cluster size.
NTFS compression is not supported for allocation unit sizes above 4096.
/F:size Specifies the size of the floppy disk to format (160,
180, 320, 360, 640, 720, 1.2, 1.23, 1.44, 2.88, or 20.8). /T:tracks Specifies the number of tracks per disk side. /N:sectors Specifies the number of sectors per track. /1 Formats a single side of a floppy disk. /4 Formats a 5.25-inch 360K floppy disk in a high-density drive. /8 Formats eight sectors per track. Microsoft Windows 2000 and Windows XP recovery console syntax
format [drive:] [/q] [/fs:file-system]
drive: Specifies the drive to format. /q Performs a quick format. /fs:file-system Specifies the file system to use (FAT, FAT32, or NTFS) Examples
When using the format command, remember all information on the drive you wish to format will be completely erased.
format a:
Would erase all the contents off a disk. Commonly used on a diskette that has not been formatted or on a diskette you wish to erase.
format a: /q
Quickly erases all the contents of a floppy diskette. Commonly used to quickly erase all information on the diskette.
format c:
This would erase all the contents of your C: hard disk drive. In other words, unless you wish to erase all your computer's information, this command should not be done unless you're planning to start over.
Or
Right click My Computer-->Manage-->then go to Disk Management
and select the to format right-click it and click format. Thats it Your drive will format and You can also choose in which file system you want to format your drive.
For further help or to thank me mail me on my email ejaz89@live.com
Aug 06, 2010 | Computers & Internet
GO 720 GPS Receiver: Haven't used my 720 for 6 months, have had it plug...
It will do that, diconnect your unit and try switching it on, have you downloaded tomtom home 2 to your computer? as you need this to manage your unit.
May 06, 2010 | Tomtom GO 720 GPS Receiver
Recording stops within 10 minutes
Hi G-DyBiec
If the video capture automatically stops capturing at approximately 18 minutes (17 minutes and 55 seconds), then most likely the drive that is being capture to, is formated using Microsoft's FAT32 file system. Microsoft's FAT32 file system has a maxium file size of 4 GigaBytes (4 GB), which equates to a DV video clip of nearly 18 minutes. (18 minutes = 1080 seconds, @ a data rate of 3.6 MB/sec is approximately 4GB). So for hard drives that are formatted using FAT32, this behavior is normal. This is not a limitation of Studio..
To see what file system your hard drive uses do the following:
1. Right click on the Start button and choose Explore
2. Under My Computer, locate and highlight the drive you are capturing to
3. Right click and select Properites
4. On the General tab, towards the top, it will say "File System". It will be listed as either FAT32 or NTFS.
There are a few solutions if your drives are formatted using FAT32:
  1. Convert your FAT32 hard drive to NTFS *
  2. If you can copy any important data from this drive to other drives, it may be faster to re-format the FAT32 drive using the NTFS file system. **
  3. You can do multiple 18 minute captures and string them together in the Edit mode of Studio.
    • Since the first 18 minutes is already captured, rewind the camcorder or VCR to 5 - 10 seconds before the initial capture stopped (which can be edited out later in Studio).
    • Start a new capture to a new file name.
    • Repeat this process until all the desired video is captured from the tape.
    • After all the files have been captured, go to Edit and assemble the captured files from the Album to the timeline in the order you desire.
This is a manual method to workaround Microsoft's FAT32 file system and if this is too time intensive for your needs, then steps 1 and 2 above may be more suitable and should be considered.
* Note: If you need assistance with step 1 above, go to the Microsoft web site at http://www.microsoft.com/ and search on "convert FAT32 to NTFS".
** Note: If you need assistance with step 2 above, go to the Microsoft web site at http://www.microsoft.com/ and search on "how to format a drive in XP".
NOTE: Microsoft's NTFS file system is only supported on Windows 2000, Windows XP and Windows Vista. NTFS support a file size of 4 TB (terra bytes), which is larger than any current consumer hard drive capacity, so if NTFS is used, the capture file size will only be limited by the size of the hard drive.
Aug 13, 2008 | Pinnacle Dazzle DVD Recorder
CAN I PUT A DVD ONTO A INOi mh386 EXTURNAL HARD DRIVE.
scan your xternal HD... it will help you....
from device properties > tools>check now
tick both option and wait for the job finished
Jun 12, 2008 | Computers & Internet
Computers & Internet Logo
334 people viewed this question
Alun Cox
David Payne
David Payne
