Question about Sirius Starmate ST2 Satellite Radio Receiver
Getting into a Starmate ST2R
I have a Sirius Starmate ST2R Satellite Receiver.  I need to get inside it to re-solder the 12V DC connection.  I took all the screws out and it still won't open up.  Does anyone know how to get inside this unit?
  • 2 more comments
  • tvshooter Feb 15, 2008
    I'm asking because another poster on this forum (papapump) stated in another thread that this had happened to him three times with his Starmate and he "opened up the unit and resoldered."  Obviously there's some way to do it without destroying it.  Is there any way to contact a specific user, namely papapump??
  • Anonymous Mar 28, 2008
    any tricks on opening up the casing?
  • Anonymous Feb 22, 2009
    i think i have the same problem-not sure if it's the cord or the radio but it just shuts off by itself frequently. any specs on the power supply cord-i want to try another one but no dealers around have the sirius part and i want to try one i have lying around but don't want to smoke the radio.
  • Anonymous Feb 24, 2009
    my starmate has problems staying on at plug to power it. comes on and off iradically. mostly off. told at radio shack he has seen this problem on this unit afew times & is caused by sldering coming loose at plug port.
I got in!!!! i first removed all 4 screws. I then used my pen knife (or the like...i.e. a very thin blade) and inserted it on the right side (rounded end). Insert in an upward direction so that the blade ends up under the gray (top side) plastic. I then very slowly worked it toward the bottom of the unit using a slight prying motion. It popped open a little for me - just enough so that i could more easily work the blade in the other direction and pop more open. eventually i was able to get the whole gray part off. Be carefull because as you begin taking it apart, the rubber buttons may fall out - no big deal because they are just in there via pressure anyway. (for me, very little damage was caused by using the blade - barely noticable)
Once the top is separated from the bottom, be careful...the actual circuit board is no longer attached to the black placstic backing, but it will not come apart due to an internal copper wire (it may be the fm transmitter antenna). It is secured to the black plastic via plastic tabs that appear to be folded over on the wire - and if you pull it out, it looks like you may not get the wire back the way it should be.
anyway, for my purposes, i did not need to remove the copper wire.....i positioned the circiut board far enough away from the black plastic in order to get a soldering iron in there to re-attach one of the "legs" of the 12V plug. I just got a drop of solder on the iron and placed in on the leg. I have not tried it out yet, but it seems to have re-attached securely
Hope this helps.
Posted on Feb 24, 2009
  • 38 Answers
The cases are not made to enter, they have an interlocking plastic housing that isn't suppose to release once closed. The unit can be forced apart at the seam but it will damage the housing,
Posted on Feb 13, 2008
It will snap come undone to fix user error of broken solder joint power connector ........wam listen n to ......octane aaaaaaaa
use good quality backside of exacto get it a little at a time next desolder antenna joint pops out the mobo and you can go from there .........
Posted on Nov 03, 2013
Take the ******* radio back to sirius hq in nyc and throw the pieceof **** thru the ******* window.those assholes dont give two shits about the customer.they are still trying to figure how there going to pay stern.i love sat radio but these assholes make it so you got spend 500 a year for subscriptions and replacement radios.**** them all to hell especially customer service.******** sirius,I QUIT!!!
Posted on Apr 10, 2008
Radio shows antenna not deteted or acquiring signal but does not work . antenna and all connections are good, ??
The problem is likely the actual connection inside the Starmate. It sounds like you have tried alternate antennas, which can only mean the unit itself has an issue. What has likely happened is the antenna jack inside the radio has come loose and is no longer making a connection, in which case it could be repairable. Otherwise there are plenty of other 12v Sirius receivers compatible with the same connections if you are looking to replace the head unit.
Jun 08, 2011 | Sirius Satellite Radio Sirius Starmate ST1...
I have a Sirius Starmate ST2 that is stuck in the Acquiring Signal mode. It is not an antenna problem. The radio has failed. Does anyone know of the fix for this? I know it can be fixed since I've...
More than likely the antenna connection has jogged loose somehow, and just needs to be soldered. The person who handles all of our repairs at TSS Radio does this often, and I'm sure could tell you specifics. His email is sales@tss-radio.com
May 28, 2011 | Sirius Starmate ST2 Satellite Radio...
My ST2 just died. Still picks up all the channels fine but just doesn't output any sound through the 1/8'' minijack. I've only been using it for 5 yrs on my home system, no car, no boom box dock etc. ...
This could be because of an amp, or it could just be a bad solder joint. Unfortunately, it's impossible to find an amp to replace it because sirius does not release a schematic. So, most likely it's irreparable.
If you would like to see if it's a bad solder, just leave it near a heater and plug it in. If it works, that should tell you that you should reflow your radio. Reflowing is easy, just remove the circuit board from the plastics and heat it up to 800-1000 degrees F with a heat gun. Let it cool and reassemble.
Dec 29, 2010 | Sirius Starmate ST2 Satellite Radio...
My sirius starmate st2r wont completely start. It freezes at the opening screen. Any way to repair or any place to send for repair?
Your board needs to be reflowed. Just pop the front cover off, remove the assembly from the back and heat it up (non-LCD side) until you see the solder melt (it will turn shiny). Let it cool for 5 minutes afterwards. You can use a heat gun (set to 1000 degrees F) that can be purchased at a hardware store.
This has a 50% success rate. The problem may also be caused by an internal fault, like a blown fuse or faulty component.
Dec 10, 2010 | Sirius Starmate ST2 Satellite Radio...
Reception
Check your antenna wire to see if it is spliced or cut. If you do not recognize a problem still you can usually get very good help from calling Sirius. They have been good about trouble-shooting and repairs.
Jun 22, 2009 | Sirius Satellite Radio Sirius Starmate ST1...
Sirius Starmate Power
My Sirius ST1 receiver froze. It reads "Sirius Radio" with the logs but goes no further in booting up. Any solutions?
Nov 12, 2008 | Clarion SIR-CL1 SIRIUS Radio Receiver
ST2 12V power input problems
I have had the same problem, the actual power jack has come unsoldered from the board this has happened to me 3 times all I did was buy a cheap soldering iron and opened up unit and resoldered this should fix the problem
Nov 16, 2007 | Sirius Starmate ST2 Satellite Radio...
Sirius Starmate ST2 Satellite Radio Receiver Logo
1,493 people viewed this question
Top Sirius Audio Players & Recorders Experts
John
John
Steve
Scott Thompson
Are you a Sirius Audio Player and Recorder Expert? Answer questions, earn points and help others
