Question about HP Compaq Presario V2000 Notebook
Speaker problem i do not hear sound from my computers speaker.but headphones work.
  • sganesh07 Feb 16, 2008
    Same with mine as well ... i have the same V2000 PC notebook and the speakers have just gone silent. The only solution i see here i guess assumes external speakers, which obviously isnt the case here in the Notebook. Kindly let me know if this is a common problem and if it has a solution that can be applied by the end user.
    thanks
    ganesh
    uvegotme@yahoo.com
    Problem Solver:
  • 6 Answers
Check the power adapter for the speakers. Make sure it is plugged in to both the outlet and the port on the back of the speakers.
Posted on Feb 13, 2008
Toshiiba satellite p205 Internal Harmon Kardon Speakers Do Not Work
Most likely its a nardware problem.
If Device manager shows the audio driver is working and enabled and when you plug an headphone into the headphone/audio out and you only get sound from the right headphone then the audio amp chip is faulty.
If the headphone sounds OK then the easiest solution is to connect a set of powered speakers to your laptop.
May 03, 2012 | Harman Kardon HK695 Computer Speakers
I can hear sound through headphone but not through speakers. The volume of the speaers are turned up
The most common issue with speakers. I hope you have not plugged in the headphones while trying to hear sound from speakers. However, go to control panel - sounds & audio devives - and select the correct sound device installed for your computer.
Chio,
Anirban Mazumdar
Dec 04, 2010 | Toshiba (P000230850) Computer Speakers
Dell speakers wont produce sound
Check your system if you are able to hear sound using any headphone..if you are able to hear sound from headphone then the problem is with your dell speakers,else you need to update sound drivers for your system...Thanks..
Aug 08, 2009 | Dell A215 Computer Speakers
My speakers wont work suddenly unless I am using my headphones
Make sure in the volume mixer that it is using the right sound device. You most likely have it set to the wrong device output. When you plugged in the headphones in kinda automatically switches, but to use the speakers again you have to do it manually. Just hook up a cheap av receiver to your computer and use this headphone input instead. a 100$ 5.1 av receiver beats any pc speaker system.
Aug 01, 2009 | Toshiba (4CH-VOUT) Sound Card
I can hear sound in head phone where as i am unable to hear sound from speakers
You must set the sound output on your computer either through the motherboard sound controller or through the windows control panel.In each of these sections will be a speaker set-up control allowing you set up the type of sound you want to come out of your computer. Headphones only, speakers only, Headphones and speakers. Hope this helps you with your problem.
May 10, 2009 | Compaq Computers & Internet
Speakers not working-- can only hear using headphones w/computer
unplug your headphones, and plug the speaker cord into that jack. its possible that the speakers you are using require power either by a cord or batteries and without them, it wont play sound. also, possible, your speakers are bad.
Apr 15, 2009 | Audio Players & Recorders
No sound from headphones connected to speaker
I may be too simple of an answer but that would happen if the headphones weren't plugged all the way in. If there is a bend in the connector and it's hitting the speaker they may not be plugged in all the way.
Jan 31, 2007 | Altec Lansing VS2221 Computer Speakers
Computer stopped recognizing the speakers
Check the sound card system Can your hear through headphones for example?
Nov 15, 2006 | Logitech X-230 Computer Speakers
HP Compaq Presario V2000 Notebook Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
