1996 Chevrolet S-10 Pickup Logo
Posted on Jan 20, 2010
96 s-10 no power
I go to start my 96 s-10 all the bells and whistles come on but when I start to crank the motor I loose all power. I look underneath the truck and I see one of the wires to the starter had come off. I put the wire back on but still no power. All the fuses are ok.
Anonymous
Level 1:
Problem Solver:
  • Contributor 9 Answers
  • Posted on Jan 21, 2010
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
9
Questions
0
Helped
1450
Points
24
Broken fusable link in the starter wire
02 bravada turn key all bells and whistles go great then no crank over won't jump start I'm stranded can I bypass something to get home
I DON;T KNOW. CALL FOR FREE ROAD SERVICE
IF YOU HAVE THIS TYPE OF CLUB MEMBERSHIP.
SERVICE MAN MAY DO A QUICK CHECK.
USE LOAD CELL TO TEST BATTERY.
CONSIDER CLEANING BATTERY CONNECTIONS. COULD BE STARTER. TRY JUMPER/ BOOSTER STARTING TO SEE IF HIGHER VOLTAGE
MIGHT WORK. CONNECTION AT THE STARTER FROM BATTERY COULD BE LOOSE.
2answers
If a2000 s430 crankshaft position sensor goes bad what are the symptoms? and is no cranking a cps problem
I'm thinking a problem with the battery and/or connections . Have the battery load tested for a dead cell . If the battery or terminals are bad there will be no power to let you get the key out and there will be no cranking noise either . A faulty CPS will allow the engine to crank but not fire
2000 Land Rover Discovery 2 hard to start during this winter season
Aside from building a garage or installing an engine block heater I have used this trick in the past on my 98 RR HSE. It may work for you if the starting issue is simply temperature related. Placing a shop-light or shielded work light underneath your block at night will produce just enough heat in many cases to overcome the slow starting problem.
Other possibilities may be under powered/weak battery. The rovers are known for high cranking amp demand and a weak or mismatched battery could certainly cause this problem. On the outside chance that it may be fuel delivery related you might try priming your fuel injection prior to cranking. Do this by turning key to position 2 (or last position before crank) wait til all the bells and whistles stop usually about 3-5 seconds, and repeat a couple times. If this is helpful, the bad news is it may be indicative of mechanical issues on the horizon.
****SAFETY NOTE***** PAY ATTENTION TO LIGHT PLACEMENT MAKING SURE NOT TO PUT IT IN PATH OF OIL LEAKS.
Hope this helps.
1helpful
My 2008 silverado won't start battery is charged
No, it isn't an ignition issue.
Check power to the starter motor solenoid.
If this is getting power when cranking, then the issue is with the starter motor solenoid or starter motor. Replace.
I have an 01 alero that won't start. The security
the previous owner had the same problem with my alero, he had to go get a new security button put in or something like that
I have a Boreem 49cc, new battery but lights, horn etc don't work?
Your alternator might be bad. Check if your alternator is functioning well.
2answers
I have a 97jgc limited 4x4 5.2 wont start from every post i read it points to crankshaft position sensor but i cant find it on my jeep what is the easiest way to get to it? from underneath or lean over the...
Should be very close to the harmonic balancer that's on the front end of the crank shaft. You will likely have to remove a component and the belt to gain access to it. Good luck.
1helpful
3answers
Top Chevrolet Experts
ZJ Limited
ZJ Limited
john h
Thomas Perkins
Thomas Perkins
Are you a Chevrolet Expert? Answer questions, earn points and help others
