Question about Bosch 24 in. SHU66C02 / SHU66C06 Built-in Dishwasher
Bosch shu43c07uc/17 dishwasher
The dishwasher fills up with water overnight. When checked after the cycle is completed, it is empty, but will several hours later it will be full of water. It has leaked out on the floor on one occasion. Is there a valve or something that is not closing?
  • drrod Feb 13, 2008
    This was the first thing I checked. It was not higher and I raised it. It happened again. Thanks for responding.
  • 54 Answers
Hi check your drain hose is fitted higher than were it joins to the sink. there has to be a loop to stop it back filling.
Posted on Feb 13, 2008
  • daniel gooch Feb 13, 2008
    then yes you need a new fill valve. this can be changed from where the fill hose joins its cliped in.
Dishwashwer not cleaning dishes at all, though it runs through a complete cycle.
try removing spray spinner and clean out holes the spray heads get blocked and stop water flow, or you may be able to remove spray nozzles and clean out , i had this several times in the past also make sure the base drain filter is clean some times the small holes in the filter get smaller and smaller reducing water flow
hope this is of some help good luck
Aug 02, 2016 | Bosch SHE5AL06UC 24 in Builtin Dishwasher
Bosch dishwasher gets stuck at 1 minute
New and highly targeted viral marketing campaigns can instantly place your product, service or brand in front of potential customers. See the best examples of viral marketing videos and social media strategies. Viral Marketing Company Plan Strategies and Resources Viral Shot
Mar 11, 2014 | Bosch 24 in. SGS43C12 Classixx...
Our Bosch dishwasher has water filling back in bottom of dishwasher after cycle is complete. You can empty dishwasher and no water will be in the bottom, but several hours later the water has filled the...
Check the drain line underneath the sink.
It should be suspended just below the counter top.
If it is too low,water from the sink will back fill into the dishwasher.
If the drain is OK,then the dishwasher water valve is defective.
Mar 26, 2011 | Bosch SHU3306UC Built-in Dishwasher
Water in Dishwasher Bottom
Hello Richard, Welcome to Fixya ! You've come to the right place. The problem you're experiencing unfortunately is a common one. The water inlet valve has been an issue with B/S/H built ( this includes bosch, thermador, seimens & gaggenau ) dishwasher's going back to the mid 90's. The part to repair it is available at most brick & mortar appliance part centers or you can check out on-line vendors such as repairclinic, apwagner etc. Do a search for part # 1105846 at repairclinic, you'll see what I'm talikng about. By the way it's about $35. Hope that helps move you forward. Let me know if I can assist you further, or need help on how to change it etc. It's relatively easy with Bosch. Thanks for coming to "fixya" for your inquiries and please take a second to rate this answer according to my helpfulness. Goof luck. Macmarkus :)
May 04, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch Dishwasher - Model SHU43C07UC --- intermitently shuts off during wash cycle -- restarts later, sometimes several hours later and then finishes cyc'e
Cold water is the only type of water that fills your tub. The machine looks like it stops because it is waiting for the water heater to heat the water in your machine to a highert temperature, enough to get your dishes clean.On that model you can't say very often that your dishes don't get clean.
Feb 16, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
We have the Whirlpool Gold quiet partner III dishwasher and lately have noticed residue on the dishes after the cleaning cycle is complete. Where is the trap to clean?
Make sure your water is hot, at least 120deg f. Also, use least amount of soap you can get away with. Usually around 2 tablespoons for soft water. Use powdered soap not gel. Gel leaves a tiny residue each load and will clog up plumbing in dw after 4,5,or 6 years. Rinse agent such as Jet Dry is highly recommended.
Try the "Tang" trick. Orange Tang drink mix is mildly acidic. With an empty dishwasher, start and fill, then normal drain. On second fill, add a full jar of Tang then let the dishwasher run for a few minutes. Crack the door to stop the dishwasher and let it sit for several hours or overnight. Then close the door, push start and let the dw run through the remaining cycle. This will sometimes clean out the crud in the water lines.
Hope this helps! Ken
Jan 06, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
Bosch dishwasher fills with water after cycle is completed
Sounds like you need a new water inlet valve. It's not shutting off completely, so water slowly enters the machine even while it isn't running.
Jul 03, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch 24 in. SHU66C02 / SHU66C06 Built-in Dishwasher Logo
437 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
