Question about Whirlpool RBS275PD Electric Single Oven
Whirlpool RF396LXE2 Oven
Oven door accidentally came off when moving. I have tried everything I can think of to put it back on. Zero success. Please help!
    President:
  • 1,314 Answers
I posted the solution under premium problems i don't know how that works but what you have to do is get a couple of nails pull the hinge on the door down far enough to insert the nails in the holes and let it rest against the door this will hold the door at the proper angle to engage the hooks inside the hinge slots on the body of the range grasp the door on each side and insert the hinges in each side to engage the hooks then open the door all the way and remove the nails
Posted on Feb 13, 2008
Upper oven door will not close completly to shut off light
Not sure if the door was removed recently, if so you may have to try to put it back into it grooves properly - if not is may be the hinges but before you look into that option, check this video out and see if it may help you
Apr 13, 2014 | Whirlpool GBD307PDS Electric Double Oven
Whirlpool Supercapacity 465 Oven (RF396 LXE2) Door Problem
These are the instruction on how to remove and replace the door, be sure you locate the removal pins to being able to put it back
Feb 13, 2008 | Whirlpool RBS275PD Electric Single Oven
Oven door won't close
remove door completely then reinstall door
Feb 21, 2014 | Ovens
How to put oven door back on after removing!
Although very tight (because the oven is only 1 yr old) i managed to get the hinges into the open position, then slide the door into position on the oven and close the door. The hinges did go back and lock as they should but I struggled for almost 30 mins before success.
Jan 08, 2010 | Whirlpool GMC275PD Electric Double Oven
I need to take the door off - any ideas
A lot depends on the type of hinges fitted to your oven door.
Try this link, it should help you .www.youtube.co.uk
In the search box type, replacing oven door hinges
Please let me know if you were successful .
Thanks.
Barkencoa
Nov 25, 2009 | Whirlpool RBS305PD Electric Single Oven
Took the oven door off and now cant get it back on
Typically one cannot fight the hinges while putting the door on.
USUALLY you can move a hinge down/open and there is a hole to put a nail through to hold each hinge down while you get the door in place.
Nov 20, 2009 | Whirlpool SB160PEE Gas Single Oven
Can't put door glass back in Whirlpool RF396LXE2 range
The answer is not as hard as it seems. I just tried for 10 minutes unsuccessfully to put the glass back in the two side tracks. Well the glass actually goes in front of them, the top holds the glass in place.
Apr 05, 2009 | Whirlpool RBS275PD Electric Single Oven
Stove won't unlock
some of the kenmores have the door lock motors in the back behind the large panel slide out an remove panel an pull or push the rod to unlock door if motor is bad for a temp fix just remove rod
Aug 29, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Whirlpool RBS275PD Electric Single Oven Logo
196 people viewed this question
Top Whirlpool Ovens Experts
Sal De
Oloyede Monsuru
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
