Question about Protron PLTV-4250 42 in. LCD Television
HDMI connection I am using MONSTER HDMI cables. When I switch to HDMI source, I have sound, but no picture (blue screen). Manual is misplaced, but I remember reading about a precedure when hooking up HDMI. Can you help?
  • mccoyr Feb 16, 2008
    Thanks for the manual, but it did not solve the problem. I have everything hooked up right and have tried another HDMI cable. When I am on the HDMI screen, I cannot access the TV icon. There is audio, but no video.
    As previously stated, the screen is blue. It is NOT a Contrast/Bright problem.
    Brigadier General:
  • 3,614 Answers
Adjust the Contrast and Bright of your Television, that's why you can't see any picture on your screen.
Posted on Feb 16, 2008
    Brigadier General:
  • 6,966 Answers
A downloadable copy of the manual for a Protron PLTV-4250 is available here.
I went through it to check up on your concern. It was mention in page 34.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FIXYA.
Protron > PLTV-4250
Posted on Feb 13, 2008
  • Louie  Role
    Louie Role Feb 16, 2008
    Pl what HDMI device is installed and connected to the Protron PLTV-4250
Sony tv no picture on screen
Hello, You probably hit the input button by mistake. If your using cable TV your input setting will depend on how the TV is connected. If your using an HDMI cable check to see what number HDMI the cable is plugging into on the back of your tv and then set the input button to the same port number. If your tv is connected with RCA cables (red,blue,green) Then hit the input to AV.
Feb 05, 2018 | Sony Televison & Video
Picture in picture operation & connection to dvd player
Now--first--connect the DVR cable box HDMI output to the HDTV HDMI input (use the lowest numbered one e.g. HDMI 1) for this connection. Use a standard (not Monster brand) HDMI cable for this connection. Then turn on the TV, turn on the cable box and switch the TV to the HDMI input. A picture should come on. You may even hear the audio on the TV speakers. If so, that is OK.
Then--connect the component video output of the DVD HT to the TV component 1 input. Use a three wire component video cable with red, blue and green connectors on each end. Connect color to color on both ends. Then turn on the DVD, put a DVD in the player and start it running. Switch the TV to the component input and it should show a pix. The audio will come from the DVD player speakers.
If your DVD player does have an HDMI output, you can use it and just connect as above to the second TV HDMI input.
To get audio from the cable box out of the DVD player speakers, you will need to connect an audio cable from the cable box go the HT amplifier. Use a set of RCA patch cables and go from the analog audio output of the cable box to the rear panel audio inputs of the DVD player. The owners manual for this unit will give directions on using this input. Since your HT unit does not have any other inputs, you will not be able to get Dolby Digital audio.
Hope this gives you food for thought. If so, and you have more questions, just come back in with a follow up.
Good luck. Remember, the owners manuals all have hook up connections diagrams. Sometimes they will help.
Dont forget to rate me as fixya..
Jan 30, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
Nec MT1060 blue screen when connected to a Hdmi source thru dvi port.Dvi setting to match Hdmi resolution.tried different cables and dvi to Hdmi adapters....any ideas..??
Hi Genaro,
Sounds like an issue with the HDMI HDCP content protection. I do not think it will be possible to connect using a DVI to HDMI cable.
Jan 19, 2014 | NEC MT1060 Multimedia Projector
Wd65738 blue screen
blue screen means no video signal, if the source is on hdmi ensure the cable is rca or in simple audio video jacks which u will have to connect in the dvi input of the tv reason is hdmi means high definition interface and transmits by hdcp like the data of an internet meaning its digital platform which the tv can only process thru the dvi inputs or component y,p,b
Jul 17, 2013 | Televison & Video
Sanyo DP46840 purchased less than 1 week ago from Walmart. Worked fine for first couple of days, now HDMI connections don't work. monster cable works on other lcd tv and all video sources. rest TV...
Hi gregschirk,
I bought the same model and I am experiencing a similar problem. My HDMI components worked fine before. Now both my cable box and DVD player will not be recognized as HDMI systems. It thinks they are DVI to HDMI connections. Good picture but no sound. Would like to know if there is a fix for this.
Thanks Gilbo72
Nov 27, 2010 | Sanyo Televison & Video
How do i use it so my tv programming is in surround sound?
if the Comcast cable box has an HDMI output, it should connect directly to one of the TV HDMI inputs. Then connect the LG DVD unit HDMI output to the second HDMI input of the TV. Use two HDMI cables. Do not buy the expensive Monster HDMI cables. If you have already done so, I recommend you take it back for a refund, then buy the low cost HDMI cables which will work just as good and then you can bank the savings toward a new Porsche Boxter!! Now we have the video connected from both the cable box and the LG system.
Now--what do you do if the cable box does not have an HDMI output--just use its component output and your component cable (red, blue and green) to connect to the TV component input. This will still get the video to the TV and good HD pictures. Hum--do you have an HD cable box? You did not say and I just assumed that you did since you got the HDTV. If not, let me know with a follow up question and I will assist in that area further.
Now for the audio connections--The DVD player will not need any connections since it in the LG unit. The sound will come out the speakers when you start playing the DVD. The cable box is where we get the TV audio to feed the LG unit. If the cable box has an optical output, use an optical cable (again the low cost one)and connect to the optical input on the LG.
This will get the TV audio to the surround system. If no optical output, use the red and white (left/right) audio connections and connect to one of the two the LG audio inputs. To hear TV audio on the LG speakers, just switch to that input or the input associated with the optical input.
To watch DVDs, switch the TV to the HDMI input to which you connected the LG unit. For TV, go to the other HDMI input (or component input).
Switch the LG to the audio input to which you connected the cable box to get TV sound.
Sep 11, 2009 | Audio Players & Recorders
No owners manual can't get new blue ray dvd player to work on tv
Here is the manual:
http://www.hdtvsolutions.com/pdf/JVG%20HD52G56G.pdf
When using the HDMI connections you may have to tell the DVD to output to that port.  Also you may have to connect additional sound cables from the DVD output to the TV.
Jun 02, 2009 | JVC HD-52G786 52" Rear Projection HDTV
Samsung hl61750a - unable to display video service over hdmi
I was using an hdmi cable purchased online. A friend told me that it might be the 'cheap' hdmi cable. I tried a set of Monster hdmi cables and problem solved. So all hdmi cables are not the same.
Jan 29, 2009 | Samsung HLN5065W 50" Rear Projection...
HDMI to DVI cable connection picture problem
You are Just trusting on Monster Cable, thats what your doing wrong. HDMI and DVI are not same formates.
Jul 29, 2008 | Hitachi 51F500 51" Rear Projection...
Protron PLTV-4250 42 in. LCD Television Logo
216 people viewed this question
Top Protron Televison & Video Experts
Jaime Hernandez
Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
