Question about Kenmore 62702 Microwave Oven
Microwave just quit working
I have a kenmore model 363.62709200 that just quit working. Light fan timer all work. But tray doesn't spin and no heating of food.
I made sure the child lock was not on so it is not that. Any ideas?
    Master:
  • 619 Answers
Hi , Open the cover unsscrew it , be sure to unplug power ,if you have continuety tester , test the fuse if open replace it , is also availble in appliance parts center near you.
Posted on Apr 16, 2008
Kenmore Elite Microwave oven 63792 doesn't heat - all lights, turntable, fan, etc. work just fine.
Most likely it would be a bad magnetron since the light, turntable, and vent fan are running.
Sep 10, 2013 | Kenmore Elite Microwave, Model...
Kenmore elite microwave model 721.79203010 problems
I'd check to make sure you don't have a door switch that isn't functioning properly. Also, might be a control panel or control panel interface issue.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/david_29ad5d1dd86564b0
Mar 18, 2013 | Microwave Ovens
My 2 year old Kenmore Microwave Model 721.66229 just stopped working. The light comes on when you push start, but the tray will not rotate and no heating happens. Help??
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Basic Microwave Oven TroubleshootingTips
heatman101[p][p]
Jul 07, 2010 | Kenmore 63663 Microwave Oven
Microwave GE JES738 doesn't heat
Almost certainly the magnetron tube in your oven shorted and caused the light show and sound effects. This is the microwave source, and without the waves there's no heat. The tube is replaceable, but it's a costly parts. Add in repair labor, and you'd be better off replacing the oven. New ones are often cheaper than the parts alone today.
Apr 03, 2010 | GE JES738 Microwave Oven
MICROWAVE NOT HEATING
Most likely you have a magnetron problem. Easy to replace (DYI) but make sure the high voltage capacitor is fully discharged first against the case.
Dec 11, 2009 | Kenmore 62622 Microwave Oven
Microwave not heating
OK, you have two components that are faulty. the magnetron and the turntable motor as well. replacing these two components will fix both issues.
Jun 10, 2009 | Frigidaire FMV157GM Microwave Oven
Microwave oven provides no heat
I would suspect that your (or any) microwave that is run empty and runs but does not heat probably has a failed magnetron.
With your model number (usually found on as together on the back, inside the cavity or around the door frame) we may be abel to point you to parts and repair sources.
Aug 30, 2008 | Magic Chef CMV1000B Microwave Oven
Just quit working...but not everything.
Hi , open the cover with philips screw driver , b sure unplug it first , If you have continuety tester check the fuse if open replace it , are available in electronics center brings that sample and insert it.
Apr 16, 2008 | Kenmore 62702 Microwave Oven
Microwave turns on, but no heat or turntable movement
Quite often this is due to a bad door switch. Opening the door while cooking (without first hitting the STOP pad) is the primary cause of door switch failure, but it may also be a broken switch mount. I have a text file called "doorsw.txt" which helps in diagnosing and repairing door switch problems, and a file called "safety.txt" which is of vital importance. It is at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can find helpful exploded view diagrams and order parts by entering your base model number (without the suffix) here: http://tinyurl.com/gv383 or at http://www3.sears.com
Mar 19, 2007 | Kenmore 62702 Microwave Oven
Kenmore 62702 Microwave Oven Logo
161 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
