Question about Vacuums
Bessell steam cleaner #%$@#%%$%
On this unright steam cleaner the "wet trigger" is not working. There is good vacuum that will pick up liquid off the carpet but neither the liquid squirting mech nor the brushes are working. This machine has been used once and at that time worked great. There appears to be no blocks of belts etc. please help
  • Anonymous May 26, 2008
    cked vacumn everything else on vacuum works but will not spray the cleaning sol. is there a way to get in side to see if little tube is blocked
    President:
  • 1,673 Answers
Model number would help. With water squirt out of the hose? If it does then the heater in the handle is probably clogger and will have to be cleaned out. If no water, then is the pump belt ok? If it is then you could have a bad pump. Also check that the seal is on the bttom of bothe tanks, and not sitting in the hole that the tank sits in. It has to be on the valve on the bottom of the tank.
Posted on Feb 13, 2008
Vax problems
Hi, it's Jeremy from Crucial Vacuum.
There are a few potential solutions you should try. First, check to make sure that the is nothing blocking the fluid on both ends of the liquid reservoir. Check to make sure there is nothing blocking the inside of your reservoir preventing the liquid from traveling out of the dispenser. If nothing is there, then check the other end of the reservoir on the outside of it where the liquid flows out to make sure nothing is blocking the flow. If each of these solutions do not work, the issue may be related to the trigger mechanism. The trigger may not actually be functioning and may need to be replaced. To determine this remove the reservoir and pour liquid straight through the dispenser and see if it comes out. If it does, the issue is most likely the trigger and you will simply need to swap it out for a new one.
You can purchase direct your replacement vacuum parts from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Jeremy Lerner
Crucial Vacuum Customer Care
Jun 29, 2014 | Domena Window Steam Cleaner Handheld...
My bissell steam cleaner will not spray any water or soap how do I correct this problem
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
kjgtllgj
Aug 23, 2010 | Bissell ProHeat Turbo Deep Cleaner Upright...
Bissell ProHeat Turbo Model 9300 stopped dispensing liquid, but water is vacuumed up okay.
heatman101
yru347
Mar 01, 2010 | Bissell ProHeat Turbo Deep Cleaner Upright...
I do not know how to operate are hoover steam vac
pull out water container, fill the inner "bag" with hot water and cleaning solution, (the dirty water goes outside of the "bag" inside of the container. First run, squeese trigger to wet area, leet sit for a minute or two the go back over it until you feel it has picked up enough of the water. It will still feel wet, but as long as it was not picking up any water when passing over the area, thats all you can do. run fans and open a window.
Jan 24, 2010 | Hoover F5886-900 Steam Vacuum
Bissell Carpet Cleaner Won't Release Solution...
heatman101
h
Sep 25, 2009 | Bissell ProHeat Turbo Deep Cleaner Upright...
Wet dry vacuums and shampooing rugs
they do ok, but a dedicated wet/steam cleaner does better
Sep 02, 2009 | Dirt Devil CE6000 Featherlite Wet/Dry...
Vacuums Logo
128 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
