Question about Maytag MAH2400A Front Load Washer
Front Load MAH2400AWW Washer
Purshed less than a year ago. I'm being told the motor blew and it needs a new pump. The repair guy order 5 parts and it's still not working. When you try to use it, there is a horrible burning smell of wires, my light flicker on and off throughout my condo and it will only spin to the right. I don't feel safe with this product. I'm fighting with Maytag to replace it.
Why does it take the Dryer MDE2400AYW so long to dry?????
  • 63 Answers
Sounds like you have a short in control board on washer buy service smart agreement from sears it will cost a little and cover up to 500.00 or give you 500.00 towards replacement value, dryer if you have heat its your vent in wall not breathing well , it will cause long dry times
Posted on Nov 14, 2008
How to repair nd code on a maytag mah2400aww washer
Remove the back panel (2 screws). On the bottom tray is the water discharge pump. Clear any obstructions.
Nov 14, 2012 | Maytag MAH2400AWW: Compact Front Load...
Maytag washer leaking from bottom
This is a fix for the Maytag MAH2400AWW, the machine kept displaying SUDS, the machine is 2-3 years old and it started doing this 4-5 months ago. I cleaned out the washer, and used HE detergent, ran it empty, to try to flush it out, used approved cleaners and ran it throught the cycle, still no good. I finally took out out a maintenance contract with BSF, the service guy came out today pulled the pump off and showed me inside it was missing half of the blades off the impeller. I remembered a year ago a coin had wedged in the pump which I took out and put back, not realising it had taken some teeth off the pump. Therefore the pump was not able to pump out the sudsy water very well which was staying inside the drum causing the suds light to come on, they installed a new pump for me, which was covered in the contract for free. Now it's working like new again.
Mar 06, 2012 | Maytag MAH2400A Front Load Washer
I have the LG Tromm, WM2277HW. I followed the
I took the entire washing machine apart. I checked the drain pump as the repair service said I needed a new one, as well as a rear and front drum, shocks rear bearing assembly. Would you believe the only thing wrong with the unit was that the drain pump was clogged at both ends. Machine is running fine and not throwing the LE Code. The repair service (LG recommended dealer) should be shot for telling me to throw out the unit.
Aug 01, 2009 | LG WM-2277HW Front Load Washer
I have a front load washer model #44832. We had a
FREE??
The unit is not under warranty.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 05, 2009 | Kenmore Washing Machines
Older Maytag fills with water, but doesn't run.
I have a 20 year old A512 & replaced only a very few items on it (fill valves, belts & air gap).
I would troubleshoot it & repair myself....can you use a voltmeter & are you comfortable exposing the timer / wiring.
My guess is motor (or timer, but less likely since its dead in all cycles). but you've got to get a solid diagnosis so you can order parts.
I suggest oyu find a guy on Craigslsit to repair..
cheers
Bob
Feb 05, 2009 | Maytag Atlantis MAV6451 Top Load Washer
MAH2400AWW washer won't drain
pump is plugged unplug washer lean back against wall under unit right front 2, 5/16 screws lets pump free take hoses on both sides free check for coins after pump and objects before pump and in pump clear reinstall if clear replace pump just had 2
Nov 12, 2008 | Maytag MAH2400A Front Load Washer
Maytag front loading washing machine
3E = Drive system is not working correctly. Bad windings, speed sensor, wiring connections or Control Board.
Jun 12, 2008 | Maytag MAH2400A Front Load Washer
Equator EZ 2500C - Need a pump
You can contact Appliance Desk who carry parts for all Equator models.
You can get their contact information from their website www.appliancedesk.com and also place the order online.
Mar 27, 2008 | Equator EZ 2500C Front Load All-in-One...
Washer wont spin. BUT, DOOR IS LOCKED. MAH 4000
Solution is right ...its your MCU Easy repair.
~Baloo
May 06, 2007 | Maytag Neptune MAH5500B Front Load Washer
Repair front load washer
We've had that same problem since we bought ours 3 years ago...but it was intermittent, and we never knew when we'd get the spin-dry cycle to work. Sears made 10 service calls, and replaced everything in the machine except the motor and motor control board. Those two parts were ordered and delivered as a result of the 10th service call. Of course, when the service guy was here, the spin worked! After he left, the next load did not spin. Frustrated, I opened the front end and looked around. I had noticed how violently the drum shook while operating when the service guy was here, so I decided to see if the wiring harness from the motor might be loose where it plugs into another harness that must go to the motor control board. There was a definite tightening of that connection as I squeezed the two harness plugs together. (I tightly secured a plastic zip-tie around that connection to prevent it from vibrating loose again) Since then, I have had absolutely no problem with the washer. I called Sears and told them I had managed to solve this long-standing problem on my own, and how, and also told them to cancel the service call to install those parts I ordered, but to pick them up and reimburse me for them. (I never opened the two boxes that arrived) They did just that, and we finally have a washing machine we can rely upon to complete the wash like it's supposed to. It's been a very frustrating and expensive 3 years, but now all is well.
Dec 15, 2006 | Kenmore 43142 Front Load Washer
Maytag MAH2400A Front Load Washer Logo
311 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
