Question about Ricoh FAX2500L Plain Paper Laser
Ricoh Fax 2600L
Im looking for part #s on this unit so i can order new rollers for it
  • chris palmer
    chris palmer Feb 13, 2008
    im looking for a part # list for the Ricoh Fax 2600L or anything that will have the same rollers
  • chris palmer
    chris palmer Feb 15, 2008
    the page did not have the manual feed rollers for the faxing assembly The page input assembly feeds multiple pages. do you have a parts list or know where to find one
  • 168 Answers
This company's website has the feed rollers for the Ricoh Fax 2600L. Go to their website: http://precisionroller.com/
On the left side, select: Manufacture: Ricoh, then Model Number 2600L then select SHOW ALL PARTS.
You should see the parts that the company offers.
Hope this helps.
Good luck.
Mac.
Please remember to post your feedback and or rating if I have helped you with your question.
Posted on Feb 13, 2008
Errer code 304 ricoh copier mp 5000
as per ask i know sc 304 is a charge roller problem kindly check the pcu unit or maybe the high voltage
Dec 16, 2013 | Ricoh MP5000
HOW DO YOU RESET THE PCU ON RICOH CL3500N
I had the same issue with my CL3500N. I kept taking out and reinserting the color PCU with the same resulting error. However, I fixed my problem. My color PCU is now reset and printing
Instructions on how I fixed the issue:
1) Turn off the printer and remove the color PCU from the printer
2) Look inside the printer where you removed the color PCU and you will notice three attach points (gears) that each of the three color PCU rollers connect to the printer.
3) Notice that each roller inside the printer has an arrow stamped in metal pointing toward it. On my printer, one at approximately the 2 o'clock position, 9 o'clock position and 3 o'clock position.
4) On the color PCU look at the end of unit that you insert into the printer. Notice the white female connectors on each of three rollers. Look closely and you will see that there are notches inside each connector (gears). One of those notches is longer than the others.
5) For each roller insert your finger into the white connector (gear) to rotate the roller so the long notch aligns with the arrow inside the printer. Be careful not to touch the photo sensitive area of the roller.
6) Insert the color PCU into the printer and turn it on. May need trial and error to align the notch correctly, but it certainly worked for me.
Oct 06, 2011 | Ricoh Aficio CL3500N Laser Printer
Im using ricoh 2045..Paper jam occurs at point A1 (the lever the drops to remove the paper) . I have noticed roller A1 and registration roller doesn't rotate. When i remove the paper and close the covers...
this is not a thought I am 100% sure and give you the correct solution:
problem with the paper feeding section is dusty or due to developer drooping
1. Open the developer unit and check the rear side developer unit bush one or two bush are faulty
and drop the developer.
2. remove all paper trays with remove the four each screws
3. Remove the toner collection bottle
4. Remove the right side cover.
5. Remove paper left roller plate.(show in the picture)
6. Now remove the first tray paper feeding section(is a complete unit included paper feed rollers motor and clutch and gear section)
7. Clean the drooped developer from all gears and roller and motor section
8. remove the second and third tray paper feeding section and doing the same.
9. now fix it all
10. replace developer unit bush witch are faulty or if you don't have yet cut a plastic sheet and past the upper side of first paper feeding unit gears witch are don't disturb the paper path and stop the developer drooping on the gear good_help.pnggood_help_0.png
Jan 27, 2011 | Ricoh Aficio 450 Copier
Hi.when i m switch on the Ricoh 3310L Fax,the message is coming as shown below "time to change PCU"
Order a new PCU from Ricoh. Power off the machine and replace the pcu.
If you try and cheat it it will run for a short while and then lock-up breaking some gears. Cheeper just to order a pcu. Check Ebay, i see alot of Ricoh supplies there.
Jan 23, 2010 | Ricoh 3310Le Fax Machine, FAX3310Le...
Savin 9935dpe /ricoh 350 toner waste near full. Where is the
If you can locate the imaging drum unit, the ink is usually stored inside. The imaging drum has a roller with green film over it (this part may not be exposed), which is light sensitive, don't leave it in a bright area for long periods of time, or you may shorten the drum's lifetime.
You'll may have to remove the green roller (is sometimes a dark-blue or black), or some other parts, in order to find a grate. This grate is usually where the ink is dumped, though the design may differ depending on the model. Also, be careful when taking apart your drum, as it is filled with powdered ink, and if you turn it the wrong way, it will spill, and it is very very messy. If you're in an appropriate cleaning area, however, this may be a good way to locate where your ink is stored.
I'm not particularly familiar with Ricoh products, but that is how most laser-printer technology works.
Jun 22, 2009 | Ricoh Office Equipment & Supplies
Toner on received faxes thick and rubs off all over hands
You have aa broken spring on your fuser unit...no pressure for the two rollers.
Nov 14, 2008 | Ricoh FAX5000L Plain Paper Laser
Fax rollers
what kind of roller do you want to install...in feeding unit or in fuser unit?
Dec 17, 2007 | Panasonic KX-FL511 Plain Paper Laser Fax
Ricoh 3310L Fax machine - 'Time to change PCU'
You need a new drum. Photoconducter unit. Cost about 140.00 I sell them or you can shop on EBAY
Aug 10, 2007 | Ricoh 3310Le Fax Machine, FAX3310Le...
Fax machine error
HI,my fax machine couldn't send and receive messages.it shows me an error code that read as 0552H call service....what does it mean..? please help me.
Jan 29, 2007 | Ricoh FAX5510L Plain Paper Laser
62 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
