Question about AT&T 962 Corded Phone (A21076)
AT&T 926 Corded phone
My phone stoped ringing and the speaker will not work. When I get a call i can hear it on my other handset, when i answer the phone it seems to work correctly. does anyone know how to turn back on the speaker and the ringer. (I have also checked the mute button)
I JUST purchased a E2562 and i cannot get the base and handsets to work. please advise me what to do. when i put the base code in the handset it does nothing...
Posted on Feb 15, 2008
    Scholar:
  • 84 Answers
Check for a button or sliding switch on the side,top,or bottom for the ringer on/off, [ some phones even have this switch on the back ] as for the speakerphone, you may have to push the speakerphone button, then put the handset back on the cradle for the speakerphone to work.
hope this helps.
wg
Posted on Feb 13, 2008
Why can;t I hear anything on outgoing calls
Cordless/Corded Phones, Digital Photo Frames 1-888-331-3383 Mon-Fri 7:00AM-7:00PM CST
Contact our team for assistance.
Mark
Motorola Support
Sep 14, 2014 | Motorola IT6-2 DECT 6.0 2-Handset Digital...
How do you set the phone to automatic pickup a ringing phone line when you lift handset?
If the ringing line is programmed into one of your dss/blf buttons it should answer when you lift the handset. Else, if it is someone else's phone ringing, lift your handset and dial 40. That will only work if allowed in the pbx programming. Hope that helps.
Mar 07, 2013 | Panasonic KX-T7453 Corded Phone
I need another corded handset. Mine has no volume. I can call out using the speaker phone, but am unable to used the corded handset.
Please check the CORD to the handset , this can be replaced and is available in all stores. Also the earpiece speaker or the microphone can be weak and can be replaced which can solve this issue..
Jul 08, 2011 | Panasonic KX-TG2770 Phone System w/...
Phone will not ring
Is the ring volume turned up? Turn the ring volume up by attaching and plugging in the cord for the answering machine. Next leave the handset on the phone and press the up volume button with the plus(+) sign next to it.
Picking up the handset while pressing the up or down volume button will increase the voice volume.
The answering machine does not have to be on for this to work.
Feb 09, 2011 | GE 29870GE1 Corded Phone
I would like connect kx-t7730 to tda100 .can I connect it ?
Yes. However, it will only work if you have the 8-port hybrid card(TDA0170) installed. Besides costing a lot more money(the card, not the phone) the phone uses 4x the power of a 76xx or DT series phone and you only get 12 lousy working buttons.
Carl
Nov 30, 2010 | Panasonic KX-T7730 Corded Phone
I can hear the caller but caller cannot hear me on 29870GE1-A digital answering machine
Hi, Please check whether the mic has gone bad in your handset.
the connectivity is just fine as your are able to hear the caller. but if you think there must be something wrong with the caller's phone, try calling someone else and check.
please let me know if you need more help. Thank you:)
Oct 23, 2010 | GE 29870GE1 Corded Phone
Can't hear
go to the setting on the handset -> advanced-> reset
I think the default pin is 0000
It will restart. I had the same problem And find the solution somewhere else
I worked for mine
Good luck
Feb 01, 2009 | NetGear SPH150D SKYPE CORDLESS HANDSET IP...
Handset problem.....
sounds like a faulty handset, plug in another one from somewhere else on the system to compare, then renew. ( handsets often get bumped or dropped )
could also check user manual for secrecy options here is link
http://www.westlakecom.com/KXT7700-User-Guide.pdf
Nov 30, 2007 | Panasonic KX-T7730 Corded Phone
Ringing problem
I assume it does not ring but just beeps to let you know another line is ringing in case you want to put the current call on hold and answer it. It's called Off-Hook Call Announce, you want to have that option turned off on your extension or possibly the entire system. Do you have someone at your location that makes programming changes to the system or do you pay a company for that?
Aug 22, 2007 | Toshiba DKT-2020 Corded Phone
AT&T 962 Corded Phone (A21076) Logo
241 people viewed this question
Top AT&T Lands Phones Experts
Paul C.
Are you an AT&T Lands Phone Expert? Answer questions, earn points and help others
