Drain out is done via the pump out motor. Is the pump out motor working? Check by deternining with a AC voltmeter to see if supply voltage is across the terminals in pump out mode. If voltage is present and motor does not spin - the motor is open circuit and must be replaced. Remove the 2 clamps and the 2 electrical push on terminals with the MAINS voltage disconnected. Is the outlet pipe not blocked or obstructed ?
Two things to consider....clean water or
dirty water?
Clean water usually indicates the fill valve
is not shutting off all the way and the fill valve is "weeping" water
in all the time = new fill valve time!!
Dirty water usually is not a dishwasher
problem but more of a plumbing issue. Often the sink drain that carries the
sinks water outside is not fast enough and some of this sink water is backing
up into the drain hose and filling up the dishwasher through the drain hose.
The drain from the sink to outside needs attention as this type of a problem
indicates a slow house drain for that sink.
The dishwasher drain line should be clamped to the top underneath part of the counter before entering the sink drain plumbing, this may help the water from coming back inside the dishwasher.
dirty water?
dirty water?
dirty water?
dirty water?
dirty water?
Hello, is this a first time occurence ? If so I would check and see if something ie: a foreign object has become lodged in the drain. You may have to remove the small panel in front below the door you would load from. You will see the drain and can remove a hose clamp to allow yourself access to it. Let me know how it works out and if you need more assistance !!
