Question about Epson Stylus CX3810 All-In-One InkJet Printer
Epson 3810 My printer says there is a paper jam. There is no paper loaded and it won't allow me to print.....any ideas? Donna
  • oDonna Feb 13, 2008
    silly question, but how do you hard reset?
    the hard reset didn't work but I sincerely appreciate your help!
    Scholar:
  • 84 Answers
Look in and around where the paper is fed into.there maybe a small piece of paper stuck somewhere inside. if you do see something, unplug the machine and try to pull it out with a pair of needle nose pliers. if you do get the obstruction out, try feeding the paper back in and see if it now works.
good luck.
wg
Posted on Feb 13, 2008
My epson xp-312 will not print on photo paper.it keeps saying paper jam.how can i load when the back tray only allows one sheet of normal paper?
When a printer indicated paper jam, it means one of its sensors does not indicate a movement of paper, where it expects it. In only rare occasions the sensor is defect, but most of the time here is really a jam. This must not be a complete sheet of paper. Can be a little scrap left somewhere in the printer. Sometimes a paperclip fell in or just a paper tray was not put in place. Please open the printer and look careful using a flash light, to see if you can find anything that does not belong in the printer. Then switch it off and really unplug it for a few seconds. Reinsert the plug and switch on. If the error keeps coming back you should call a service centre, although ig you have to send it in for repairs, a new printer is probably cheaper, unless it is still under warranty.
Jan 13, 2015 | Epson Office Equipment & Supplies
How to print A7 invitations on epson stylus 3810
you have to go to print custom paper(paper size) and put the dimensions of your a7 paper size
Apr 20, 2014 | Epson Office Equipment & Supplies
Paper jam
Epson stylus paper feeder keeps jamming
Feb 16, 2014 | Epson Stylus Sx535wd
Hi, there is continous paper jam flashing light indicated at the printer (epson 600). i have checked but i found nothing jammed. i wounder i could be the reason. your support is...
Sorry - no solution, except to perhaps agree with the guy who says throw it out the window. I only wish I wasn't just on the first floor. This thing does more jamming than printing. It claims a jam when there is none. Infuriating.
Nov 06, 2010 | Epson WorkForce 600 All-In-One InkJet...
Epson Stylus photo 340 r printer paper jam when trying to print
first, make sure you the paper correctly to avoid paper jam.
Single Sheets 1. Open the paper support and raise the extension. 2. Place your paper short edge first against the right edge of the feeder, under the tab, with the printable (whiter or glossier) side up. If you are loading multiple sheets, fan the stack of paper before loading it to prevent paper jams. Note: Don’t load paper above the arrow mark inside the left edge guide. Some special papers can be loaded only one sheet at a time. Slide the left edge guide against the paper. Make sure it is snug, but not so tight that the paper is bent. (For letter- or A4-size paper, you may not need to move the edge guide over.) paper.4.2.1.jpg 4. Open the output tray and pull out the extension. You should also follow these guidelines:Always load the short edge first, even when you’re printing landscape-oriented pictures. • When using special papers, check the paper package for additional instructions. Some papers require using a support sheet included in the package. Note: Always keep unused paper in the original package and store it flat to prevent curling.
if you loaded the paper, it jammed again, remove the paper and tried to print, still the same, its a hardware issue, alraedy, the printers roller is broken
Feb 09, 2010 | Epson Office Equipment & Supplies
Epson 3810, paper will not feed, no paper jammed in printer
Paper feeder problem. Distortion of pick up rubber in paper feeder or loose of thickness. Take to Epson service center for replacing it. Or if you have experience in disasembling and asembling printer, you can repair by add thcikness pickup rubber and rearrrange position of the rubber. Also check lubrication of paper feeder mechanic.
Aug 19, 2009 | Epson Office Equipment & Supplies
Printing on acetate sheets with a epson dx7400
i had the same problem i solved this by sticking plain whitecopier paper to the direction strip with double sided sticky tape printed asultra gloss photopaper
May 15, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Paper will not load into my Epson PHOTO R340 printer.
May be the problem is at paper sensor, that dirty. The sensor is at bottom of head casing. When paper feeding, the sensor not get the light back, so the printer "think" that no paper. Try to clean paper sensor.
Jan 12, 2009 | Epson Stylus® Photo R340 InkJet Printer
Open Questions:
See all Epson Stylus CX3810 All-In-One InkJet Printer Questions
Epson Stylus CX3810 All-In-One InkJet Printer Logo
178 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
