Question about Bissell 3522 PowerForce Bagged Upright Vacuum
Blowing out? I have checked all hoses for clogs, I have even taken it all apart, but it seems to be blowing out? The bag inside the canister is sucked in? Can the motor reverse on itself, I'm baffled!!
  • 1 more comment
  • baffaboutvac Feb 13, 2008
    Yes, that hose is clear. Is that what you mean when you say inlet?
    Yep, its clear, I unscrewed it from the back and straightened it out and it clear. Now what????
    Is it possible for the motor to start spinning the opposite way? Why would my bag inside be sucked in and not puffing out with air going into it?
    President:
  • 1,673 Answers
Did you check the inlet down by the brush roll?
Posted on Feb 13, 2008
  • 1 more comment
  • Lauren Junge
    Lauren Junge Feb 13, 2008
    Number 23 on the pic. is the inlet.
  • Lauren Junge
    I assume you took the bottom plate off and checked that opening? If everything is clean and open, then it is possible that there is a problem with the motor.
  • Lauren Junge
    Wish I could help more, but the only way I can do that is by looking at the vacuum in my shop.
Why is it sucking fine when the floor hose is connected but not when the carpet vacuum is connected?
There is a clog somewhere past the point where the hose attaches. You may have to take this apart to get it unclogged. I have had to do this more than once on vacuums.
Feb 10, 2016 | Rainbow Vacuums
The cleaner sucks very poorly. The motor sounds fine, it blows well and there is no obstruction.
If it blows, then it should suck equally unless there is leakage on the intake (suck) side meaning something inside disconnected or cracked, letting air in from other directions. I do not know the vacuum you speak of; upright (which has a short hose often clogged by itself) or canister which might also have a leaky seal at the bag door.
Sep 26, 2015 | Vacuums
Why is my wet dry vaccum blowing and not sucking?
The clog or the bag or canister is full. Clean or replace filters.
First of all, make sure you put the hose on the suction port. If it's blowing where it should be sucking, the polarity of the motor is backward; the wires are hooked up wrong.
Feb 25, 2012 | Vacuums
Aerus/Electrolus canister vacuum model C152C turns off and full bag indicator lights even with new bag.
Here is a list of things that could cause this, and how to check and/or "fix" them.
First, turn dial on top of vacuum counter-clockwise so the smallest dot lines up with the arrow. See if it stays on. If not, detach hose and turn vacuum on. Place palm of hand over intake. If it turns off, it's possible that the tubes connecting to the CVA are clogged and simply need cleaned. This is most often caused by using "made to fit" Electrolux bags. Dust is sucked through the bags and into the motor compartment of the machine. All interior parts get covered in dust and need to be cleaned. If this is the cause, the vacuum is best cleaned and repaired at an authorized Aerus Electrolux store. If the vacuum shuts off, or won't turn on before placing hand over the intake, it's probable the control valve assembly is bad and needs replaced.
Another cause is an overheated motor due to clogged screen at back of bag well, full or clogged bag, dirty afterfilter, bad wiring/connections, clogged hose, clogged power head, or bad motor. It depends largely on the type and model of cleaner. Clogged wands are also a possibility, but unlikely.
Check and clean screen at back of bag well.
Replace bag. Make sure it's a genuine Electrolux bag made by Home Solutions.
Check and replace afterfilter if necessary. These should be replaced after every six bags.
Broken and worn wiring connections are often found in the hose ends due to abuse and normal wear and tear. You can check the continuity of the hose using a continuity tester or multi-tester. If a multi-tester, turn dial to one of the Ohm settings. Place one probe into one of the terminals on the end of the hose. This will be referred to as T1. Touch the other probe to each of the terminals/connections on the other end of the hose. These will be T3 and T4. One of them should read zero, the other should read infinity. Repeat this with the other terminal, which will be T2.
Drop a marble in one end of hose and let it roll through. If it doesn't roll through, the hose is clogged and needs to be cleared. Plug hose into the exhaust port of the vacuum, place other end in the in port. Turn vacuum on. This provides a blowing and sucking action which should clear the hose.
Detach hose from power nozzle (PN). Drop a marble into the wand end of PN. If it rolls through, it's clear. If not, there's probably a clog behind the brush where the intake opening is. You may be able to reach this through wand end with needle nose pliers, or either end with a knitting/crochet needle or a bent coat hanger.
If none of these "fixes" provide the answer to the problem, it should be taken to the nearest Aerus Electrolux store for diagnosis. Repairs or checks involving disassembly of the vacuum should always be done by an authorized Aerus Electrolux service technician.
The store nearest you can be found by following the instructions at the below listed link:
http://www.aerushome.com/storelocator/
Mar 11, 2011 | Vacuums
Dirt Devil bagless upright. sucks up dirt in the front and spits it out in the back. I have taken it apart to check for visible clogs in hoses and checked belt and rollers all of which are fine. what next?
There seems to be no vacuum drawing the debris away from the brush head. Remove the debris canister to check for air blowing into it. Check particularly, the area where the brush head pivots off of the upright portion. Hope this helps!
Jul 26, 2010 | Dirt Devil M110000 Bagless Upright...
My kenmore hida filter vacuum cleaner no longer has the sucking ability it used to have. It is only 4 years old and has worked extremely well up until this week. The motor is functioning well, as is the...
well i've hade one come in a while ago and it didn't have good suction so I looked at the bag it was buljing w/ dirt so I put a new bag in it and it had better sucktion but still not good enough so I cheched the fabrick filter and it was dirty too so I washed it and it had even better sucktion so try the paper filter on the end too and if your vacuum still haves bad sucktion try looking if the hose is clogged buy putting your mouth on the end and blowing through it i recomend whiping the end off befor blowing if hard to blow it is clogged, if clogged i would put something thin like a metal rod or or a stirty stick to push the dirt out i'm sorry if my info didnt work out :D
Jun 12, 2009 | Kenmore Whispertone 23312 Bagged Canister...
The vacuum is not sucking up material. Rather it
Either the bag is full, or the belt is broken that drives the brush on the underneath side of wand.
Jim
Jun 09, 2009 | Kenmore 23313 Whispertone Bagged Canister...
No suction with my Hoover Breathe Easy Upright
If the bag fills up with air it should be sucking since the air that fills the bag is blowing air into the bag thus the dust gets carried along with it. However it should be easy to inspect the hose by taking it off by either removing screws *dont lose them, by the way! And looking at the dust channel after the beater bar. Either way something is clogged if the dust bag is filling up with air. Also check that the filter underneath the bag or beside the motor is completely clean.
Feb 20, 2009 | Hoover Breathe Easy U5250-930 Bagged...
Blows
Check all airways ,it is clogged somewhere. 1 take off the emptor 2check the flexable fill tube in side the bag 3 look inside the casting where u took the emptor off 4 run the machine without paper bag - there should be a free flow of air-LOTTS-u need the emptor back on to do this-keep your face away incase something comes rushing out Cheers Phil C
May 11, 2007 | Kirby Ultimate G Bagged Upright Vacuum
Bissell 3522 PowerForce Bagged Upright Vacuum Logo
220 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
