Question about Sony KP-65XBR10W 65" Rear Projection Television
Green lines across screen
The picture doesnt show like it should,very dim, and the picture flickers ALOT!!! thinking it may need a new bulb, it also looks like the green could be off.........the led light blinks 5 times....could be white balance???Just wanted to know if its worth fixin or should I jus buy another tv???
    Sergeant:
  • 395 Answers
Check these components in the Video out, IC7101, 7201, 7301 and others in C
board circuit.
Q510,516,524 (A board)
if they are good then the picture tubes would need to be replaced, but since they are no longer available it realy wouldn't matter much would it.
Posted on Feb 13, 2008
There is a humming in back of tv.the sound always good but picture doesnt come thru and i get a green screen someetimes blurry with distortion.color wheel or dmd chip or lamp starting to go out
as my experience, the most possible reason should be the color wheel or its photo sensor board.
firstly try to clean its photo sensor board, or have to replace a new wheel.
i just have this wheel, when you need to replace it, contact me freely
May 02, 2016 | Televison & Video
Screen flickers and pictures have lines across them on my lumix DMC-TZ3
The camera is probably damaged, this also happend to my DMC-TZ5 as well after a few (5-6) years of heavy use but without any visible damage, a repair is most likely more expensive than just buying one of the new lumix cameras which have also improved A LOT, so you wont be disappointed!
Apr 08, 2016 | Panasonic Lumix DMC-TZ3 Digital Camera
Luxor 40 914 tvb
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
Apr 13, 2014 | Televison & Video
White line across screen
- Flickering screen
- Dim screen
- Slow start
Apr 05, 2014 | Sony 46 KDL46EX523 LCD TV
Screen flickering, dim, lines moving up the screen
If it was new in 2006, it probably is not worth repairing.
Jan 06, 2018 | Toshiba 72HM195 72" HDTV
Color lines in tv screen
it's an lcd filter fault it's betwine lamp and screen before mirror, seems like u will need to replace it but it hard to say without look at it.
Mar 22, 2009 | Philips 55PW9363 55" Rear Projection...
Mitsubishi DLP WD 52525 has small green lines on the screen
do the lines go from top to bottom, and are they about 1 inch apart? or do they move diagonally across the screen?
Dec 27, 2008 | Mitsubishi WD-52525 52" Rear Projection...
View screen has purple lines across whole screen cant take a pic.
It is bad ccd issue in Canon A95 camera and ccd imager needs to be replaced.
Canon will repair A95 free of cost as per announced scheme.
Click Canon CCD Advisory for details.
Good luck.
Dec 21, 2008 | Canon PowerShot A95 Digital Camera
Picture issues
your green tube is trying to go out
Oct 21, 2008 | Mitsubishi WS-55613 55" Rear Projection...
Even spaced vertical lines across the whole screen on all sources
If you are handy with SMT rework it might be possible to fix this problem. The heat spreaders on the LCD drivers are insufficient to cool the chips and they will get hot enough to reflow the solder and cause a short on some of the pins. I think it most often happens after bulb replacement since bulbs near their end of life are dimmed and run cooler. After replacing the bulb the bit of extra heat is all that is needed to push them over the edge.
The problem also seems to be most prevalent on the green IC since it shares a heatsink with red and has a smaller area to dissapate the heat into.
If you pull the heatsink you will probably be able to see the short with careful inspection. The pitch is very small - 0.6mm but I was able to wick, clean, and reflow one side of my green IC and the problem went away.
I am planning on adding some additional aluminum stock to the heat spreaders with some thermal adhesive to give the chips more cooling.
By the way the very common rattle noise in these projectors is not a fan but the auto iris. You can unplug the iris servo from the mainboard and disable the auto iris in the menu to work around the problem or you can replace the iris servo for about $75, again, if you are handy with that sort of thing.
Dec 19, 2007 | Panasonic PT-AE900U Multimedia Projector
Sony KP-65XBR10W 65" Rear Projection Television Logo
53 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
