Washing Machine This is the third time I've had to pay a repair man to get a quater, unstuck from the drain of our Maytag MAH-24 front loading washing machine. Is there an easy way to get the drain ourselves? It's only a matter of time before it happens again. Do they really build these machines to swallow change, I've never had this happen before this unit?
  • Meggers720 Feb 20, 2008
    Super Fast Response! You've saved us hundreds in bills!!!!!! A true Guru!
  • washerblues May 12, 2008
    similar problem- maytag MAH2400 front loading washing machine. Noise when pump operating- load clanging as if coins trapped somewhere. Also SUDS error message, as if not able to pump out properly. Please let me know how to clean the pump filter
    President:
  • 1,314 Answers
You lean the washer back as far as you can remove the 4 screws from the bottom panel to access the pump then remove the hoses from the pump and unplug it after that there are four screws securing the pump to the bottom of the washer remove them then then slide the pump out and clear it the easiest way to deal with this problem is to check your pockets for change and small articles before washing
Posted on Feb 13, 2008
I have a Maytag MAH-24 Washing Machine showing a 5E error code
You will have to contact Maytag and speak to their service dept and give them your model number. Ask them what a 5E eror is and when you call for service, tell the repair facility what Maytag told you. That will next to eliminate labor cost for Diagnostic.
Apr 17, 2012 | Maytag Washing Machines
I have water draining from the bottom of my front loader washing machine. It doesn't happenned every time. I have had the local repair man out cannot find the problem. I know its the machine because...
ok ,,take your time and get a flash light,,check the rubber gasket around front of tub for pen hole...giood luck,,if you dont find leak repost..and we will got to another step..pull on rubber tub gasket while searching..
Sep 09, 2011 | Maytag MAH8700A Front Load Washer
Maytag neptune mah 4000aww wont drain properly
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 06, 2011 | Washing Machines
HAV2360 Maytag does not drain before spinning. Drain cycle seems not to engage.
Unlike Whirlpol and Kenmore washers Maytag Washers drain and spin at the same time.
Apr 10, 2011 | Maytag HAV3460AWW Top Load Washer
My maytag washer mah-24 have a "nd" msg. which mean "not draining" and now i cannot open the door to take the clothes out. pls. help.
Unlocking the door:
Turn on the washer, but don't start any wash cycles. After a few minutes, the door should unlock itself.
Troubleshooting the "nd" message:
"nd" means "no drain". Empty the (now unlocked) washer and fill the wash tub with just enough water to see a bit of water at the bottom of the tub. Run a drain cycle and check a) if it drains and b) if there are any unusual noises while it is draining. If either event occurs during the drain cycle, the drain pump may have to be repaired/replaced.
Nov 25, 2010 | Maytag MAH2400A Front Load Washer
Washer won't spin and drain, repair man said it was the transmission and should cost over 300 to fix it????
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Jun 04, 2010 | Maytag Ensignia MAV2757AWW Top Load Washer
My dish washer is not draining it is a maytag jet clean aprox10 years old
heatman101
May 20, 2010 | Maytag 24 in. MDB8750A Jetclean II...
ND Error code
Error code "nd" means it is not draining. Click on this link to get the user manual:
http://laundry.manualsonline.com/manuals/mfg/maytag/mah24.html
Then click on "GET THIS MANUAL" to download the manual.
Not draining can be caused by the controller, pump, solenoid valve, or clogged drain.
If this information was useful, please select YES to the first to rating questios. Good Luck and thank you!
Oct 22, 2009 | Maytag MAH2400A Front Load Washer
Maytag MAH 24 does not drain and makes weird humming noise
i also have this problem. to get the door to unlock, just unplug the washer and it should open in a min or two. you will hear a click. you may have a mini flood but at least you can get your cloths out and bail out the water. my problem started when i began using a new detergent from Tide called total care. Still tying to get the pump to work.
Jan 25, 2009 | Maytag MAH2400A Front Load Washer
Unlisted error code on MAH-24 Maytag front-loading washer
Did you connect the wires back to the pump. The neutral runs through the pump winding and to the door interlock. Check the connections on the drain pump and the harness in general. Sounds like a broken connection somewhere.
Nov 05, 2007 | Maytag MAH2400A Front Load Washer
Washing Machines Logo
177 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
