Question about 2wire (1000-400108-001) Router
No wireless connection
I am still having problems have an acer with windows vista shows good strength but cannot connect how do you set ip and gateway address manually and what would they be Thanks
  • tawpaw Feb 15, 2008
    found out all you have to domis type in the 10 digit code found on your modem, in box below where it says wep and leave index key at 1
  • Anonymous Feb 17, 2008
    I have sbc as my ip provider. My modem is 2wire which I've been told has wireless ability. I've installed it software but I can not link the connex to my lap top.
  • 51 Answers
Hi.IP address and gateway depends on your ISP and if you have Dynamic i address from your ISp then it wud be automatically assigned.hey check if the wep key on the laptop and the 2wire are the same and they share the same type on encryption(64/128 bit)
Cheers
Posted on Feb 13, 2008
When my wireless access point is turned on, my computer is unable to renew the ip address. I show excellend signal strength, but "little or no connectivity"
Hi, Your computer is most like have IP address permanently asign. To change the setting for windows 7, click start, click control panel, click network & internet, click network sharing, click connection, click lower left hand property, click Internet protocol version 4 (TCP?IPv4), click property and click obtain and IP address automatically. Your Router will asign IP address. Windows XP, Click start, click connect to, click to show all connection, right click to the wireless connection adapter, click the property and click the down arrow click to TCP/IP, click the property and change it to obtain IP address automatically. That should work for you. Get back to us if this information help you solve you solve the problem. Good day now.
Jul 13, 2011 | NetGear WG602 802.11g/b Wireless Access...
Cannot get wireless internet to work. Set up wireless connection. Icon shows connected, excellent strength. There is another computer icon next to it on the task bar however that shows a red X through it,...
find that ip of the router e.g 192.168.0.1 or something like that
gott to the lan network connection of pc
got tcip option
in ther enter the ip addree 192.168.0.xxx ( anything but ther router address)
subnet mansk 255.255.255.255.0
defualut gateway the routers ip address
primary dns router router ip address
leave the secondary ip blank
Mar 05, 2011 | Computers & Internet
Problem with Network and Wireless driver
Hello Ken,
It sounds as if the problem is with your wireless setup. If you go into your property setting for the wireless when you are "connected" to your router, make sure it is showing a Gateway IP address. If not, you get limited or local access only. You will need to get the gateway IP address from your ISP provider or if you know the IP address of the router (DHCP) you can get all the IP addresses to get you connected to the Internet.
Good Luck
C2Solutions
Jul 04, 2010 | Computers & Internet
We have great difficullty accessing the internet on our laptop, which runs Windows Vista. We use a wireless router, which the computer can see with excellent signal strength. Our ISP has tried over and...
I have had the same issues with Vista.. Even thou the wireless shows an excellent signal the only thing I could do was to disconnect and then reconnect and then I was able to get it to work. I finally had to upgrade to Windows 7 and now never had the problem again. I would have to say that Vista might be your problem.
Jan 11, 2010 | Computers & Internet
Connection
Connect your broadband router to the netgear router, set your netgear router as "gateway" and put netgear's IP address as your DNS Server and Gateway in your laptop wifi connection.
Mar 21, 2009 | NetGear WGR614 54Mbps Wireless Router...
Acer 3000 builtin Wireless adapter says disconnected
update the drivers and run the wizard again to set up fresh settings
are you networking this unit or direct of the modem
Feb 11, 2009 | Acer Aspire 3000 Notebook
Wireless shows connection,but will not connect.
This kind of problem occur due to dhcp disable in the wireless router for the security purpose. So try to give the ip adress manually by right clicking on the wireless and give the ip adress of the same range in which your network in working e.g 192.168.1.0 is the range of your ip addresses so please select the ip which is not been used by any other computer and than in default gateway enter the ip address of you wireless router and you will be able to access the internet on your system.
Dec 01, 2008 | Linksys Wireless-G WRT54GS Router...
Can not connect to internet through wireless router...
First thing as ur able to access internet using ethernet cable, that indicates that ur router is fine. Now, also as u mentioned signal strength is excellent still its not getting connected, what u have to do is : click start then run type cmd and press enter it will open up command prompt or if ur using vista then click start >all programs> click accessories>right click command prompt>click run as administrator it will take u to the command prompt screen there  type ipconfig and press enter and check what is the ip address if ip address is like 169.254.----- then that it indicates that ur comp and router are not able to communicate wirelessly u have o set up a new wireless network. and if ip address is like 192.168.0.4 and default gateway is 192.168.0.2 then u don't require to setup a new connection  now in any case run this following command on the same command prompt window netsh int ip reset reset.log and press enter and then run this command netsh winsock reset catalog press enter it will ask u to restart and then restart the laptop after that try connecting if still not able to access internet then connect ethernet cable open internet explorer type in this address 192.168.0.1 and press enter it will ask for username and password that is admin and password respectively and it will take u to netgear settings  and from there setup a new wireles network......... try this if not able to do so revert to me.
Jun 01, 2008 | NetGear WGR614 Wireless Router
Password setting not going
Hello there.
You need to give the correct IP address to connect to your router through your web browser. 192.168.0.50 is most likely your Vista PC's IP address, not the D-Link router.
To find out what IP address to type into the web browser please do the following:
1) Press the "Windows" key + "R" on the keyboard, at the same time.
2) Type "cmd" without quotes in the run box and click "ok"
3) Type "ipconfig" without quotes.
Notice it says Default Gateway followed by an IP address, this is your router's IP.
Hope this helps.
May 04, 2008 | D-Link DWL-G700AP 802.11g/b Wireless...
Netgear wireless connection
Check the wireless IP address on the XP computer. try to ping default gateway and see whether its giving succesfull reply, after that do ping yahoo.com and check successfull pinging. if it pings successfully the yahoo website , then you should go online.
Oct 24, 2007 | NetGear : WG111 54 Mbps Wireless USB 2.0...
2wire (1000-400108-001) Router Logo
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Ron Stone
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
