Question about Samsung HCL5515W 55" Rear Projection Television
Convergence problem We have a Samsung HCL5515W projection tv. The blue started ghosting everything on the screen and from what I read online it's the IC's that need to be replaced. We would like to do this ourselves but do not know where to find them or the part numbers to be able to purchase them. I am told the Blue and Red need to be replaced. Any help would be appreciated!
  • Grneop Mar 04, 2008
    I'm also getting the same problem, the repair center close to me ask me $351.00 to fix it and I know I can do by myself, any help will appreciated.
    Scholar:
  • 170 Answers
Check all resisters around conv ic's, also replace ic that connects to the burnt resister.
Posted on Apr 09, 2008
CONVERGENCE IS OFF PINK AND GREEN LINES ON THE TV SCREEN
Projection TV2_bing.gif sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony, Samsung2_bing.gif, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith2_bing.gif, and others. You can get a convergenece repair kit from the link below.
Common Symptoms include....
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on - TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash2_bing.gif focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a solution
93a1209.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you know what you are doing. If you have never done this before we would advise calling a shop or if you want to do it yourself get a complete kit with instructions and support from www.TvRepairKits.com
May 30, 2010 | Samsung HCL5515W 55" Rear Projection...
How do you adjust the focus lenses for an HCL5515w TV?
You have one of two problems. Sometimes both.
Problem #1) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #1
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Problem #2)
Your TV may have a convergence failure. ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
Using your original remote go-to the tv settings then goto the convergence section.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
0667c5f.pngSolution # 2
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses. Its a fairly easy DIY job or you can hire a pro. If you want to do the repair yourself check the site www.TvRepairKits.com. Their kits include a step by step picture instruction guide, original OEM parts, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
Mar 12, 2010 | Samsung HCL5515W 55" Rear Projection...
Samsung HCL5515W...when using coax input pic convergence is off, red and blue seem off....when I use the component inputs it constantly flickers between the squigly lines and picture with convergence off?...
on component your device may have to be on progressive. old dvd players you could switch back and forth on progressive and normal. the squigly lines sound like you need to make sure its on progressive. hook it up using the yellow video slot on player and tv (any cable will work). go into menu and look for progressive and change it on.
Jul 14, 2009 | Samsung HCL5515W 55" Rear Projection...
Green and pink shadow on my samsung 55in proj tv what can i do to fix it. i all ready fixed red and blue line but green is way off and i dont see any way to fix it
hi, this is the early signs of convergence board chip failure. you will need to replace this board in order to correct the collaboration feature. the convergence is responsible for regulating the RGB stream in you set. if it is malfunctioning, you will not be able to regulate the red blue green streams.
May 16, 2009 | Samsung HCL5515W 55" Rear Projection...
Convergence problem, blue ghosts
Projection TV sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - makes a chirping sound.
Example Photo:
Problem #2 CRT Fluid has clouded over.
Symptoms
  • Dull Video, Washed out
  • White/Bright looking video
  • Halos around objects
  • Red/Orange looking
Example Photo:
You can see more examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Sep 01, 2008 | Samsung PCN5425R 54" Rear Projection...
Blue ghost
Replace convergence IC'S and check values of convergence circuit resistors.
Aug 07, 2008 | Samsung HCN4226W 42" Rear Projection...
Samsung HCL5515W
You need to replace both convergence ICs they are STK392-040 you can get new replacement ICs at the following link and they come with free instalation instructions with pictures and free tech support by way of instant messaging in case you need additional help. hers a link to where you can get the new convergence Ics.
http://servicemanuals.vstore.ca/
May 28, 2008 | Samsung HCL5515W 55" Rear Projection...
Samsung HCL5515W red convergence problem
sounds like your convergence IC's have fail and possibly a bad dcm. Some of there models have a small board with the ic's them. It may be cheaper to replace the board. But you can repair it if you have proper equipment
Jan 20, 2008 | Samsung PCN5425R 54" Rear Projection...
Samsung HCL5515W 55" Rear Projection Television Logo
87 people viewed this question
Jerry Greenberg
Jerry Greenberg
