Rank: Guide
Rating: 85%, 4 votes
From the sound of the "new" problem, you may have TWO DIFFERENT phone lines hooked together.
Or, it could just be an extra pair, to another jack in your house somewhere (have you looked for another one?).
Try connecting just ONE PAIR (red & green, also known as Tip & Ring) to your jack, and then call your number with your cell phone.
If it doesn't work, try disconnecting that pair, and connecting the other pair, and call yourself again.
Also, if you reverse tip & ring (red & green), your phone may not break dial tone, if thats the case, just reverse the pair, and you should be good to go.
Please let us know if you get it working.
Comments:
Feb 13, 2008
- One more thing...
Did you strip ALL of the insulation OFF of the wires you connected?
Just one small piece will interfere with your connection and cause static.
But don't strip off too much insulation, the wires still need to be covered right up to the connection, to prevent short circuits (which, if intermittent, can also cause static).
And all screw connections need to be tight, or static will occur.
