Standard Televisions
Problem for Standard Televisions
Generic problem for all Standard Televisions
Cable setuo for model 27r410t
By joyriider on Feb 12, 2008
once tv goes thru setup mode i get sound but horizontal lines also and cant change from channel 3
Comments:
Feb 13, 2008
- pishta68 i thank you for the reply. I figured it out on my own and you were right on the $$$. Thanks again Joyriider
Best Solution
posted on Feb 13, 2008
Very Helpful)
pishta68
Rank: Wiz
Rating: 84%, 301 votes
Get an antenna hooked up, even rabbit ears should pull in a few analog channels. Set top boxes will only output Ch 3 (switcheable to ch 4 on the back if needed) and cable may be dead or only give you scrambled CATV channels. You need to set your tuner to "antenna", not CATV, IRC,HRC, or ATSC (if you have a digital tuner) and do the setup again. You could have a bad tuner at worst, and all is not lost, just hook up a VCR via RCA cables and use the VCR tuner to change channels. Keep TV on Ch3.
Comments:
Feb 13, 2008
- There you go.
Was this helpful?
Yes
No
Popular Solutions for Standard Televisions
Questions and Unsolved Problems for Standard Televisions
Answer
My TV doesnt go on when I push the power button, but the light does.
Answer
can the aerial socket inside the tv be replaced and where do i find the parts?
Answer
I have a sony wega KDF-E42A10 that the picture comes on for approx 20 sec and then it goes off and... (More)
Answer
After hooking up my new Samsung LCD, I later went to watch tv in my bedroom where my tube tv is. All... (More)
Answer
I got up today and turned my tv on and the picture was like a gray color and had black at the top... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Standard... Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(21591) 042-9690
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
