Question about Hitachi 50V500 50 in. HD-Ready LCD Television
My whites are pink
I have been told that I need to reset the memory to fix this problem. How do I do this?
  • DaveStewart Feb 15, 2008
    I have no input button on my remote, but used the input button on the TV. A memory reset option came up, and I checked it, but nothing happened. All the rest of my colors are just fine. The whites are pink. When the TV Tech came to my house, he said he reset the memory and fixed the problem.
  • 50 Answers
Try going into the service menu. Turn off TV, and wait for all lights to stop blinking. On the remote press the input button, and on the TV press the power button. This should put you in the service menu.scroll and find the reset button.
Posted on Feb 13, 2008
  • Nick Newman Feb 15, 2008
    Have you call Hitachi, and asked for tech assist? If this doesn't fix the problem, your light engine may be going out.
My Nikon D50 has a white balance problem, white is showing up as pink
Thats format, you need to reset your whit balance go to menu then white balance then set to white
Dec 21, 2012 | Nikon D50 Digital Camera with 18-55mm Lens
The color on my tv is mostly pink. Is this
Try a reset to factory defaults. Show some image with lots of white. If it is still pink, it could be the backlights starting to fail. Or a circuit board. To be sure, you would have to disconnect the LCD panel from the board and turn on the set so that you have a blank white screen....with no signal. A pink screen, backlights are bad.
Apr 23, 2010 | Insignia IS-LCDTV32 32 in. Television
Had problems with key switch got after market switch put in dash i was told black was battery, red was starter, yellows 2 1 ingintion other alt. but didn't work need to know what wire's what
Black is ground......
you may have more than 1 red wire,the heaviest / thickest is the posstive wire ( all red ), the yellow are accessory wires,and there should be another 1,and if my memory serves me correctly,,, the wire colour is white with a pink/red tracer.hope this helps.
Jul 12, 2009 | 1984 Ford F 250
1989 toyota camry with oil leaking from ?
get you some cleaner like gunk engine and spray engine while engine is cold let set for a while and spray off with water hose, crank engine and start looking for the leak
Feb 25, 2009 | 1989 Toyota Camry
Optio S40 white objects are pink
Sounds as though the white balance is off, check your manual on how to alter the white balance to manual - then change it back to auto. It should fix it.
Feb 12, 2009 | Pentax Optio S50 Digital Camera
I need a diagram for the factory stereo wiring on a 1999 ford f150. I need to know what color the speaker wires are and the memory
1999 Ford F Series Stereo Wiring Constant 12V+ Light Green/Pink Switched 12V+ Black/Purple Ground Black/Green Illumination Light Blue/Red Dimmer n/a Amplifier Remote Blue Antenna Right Front Front Speakers 6" x 8" Doors Left Front (+) Gray/Light Blue Left Front (-) Tan/Yellow Right Front (+) White/Light Green Right Front (-) Dark Green/Orange Rear Speakers 6" x 8" Rear Corners Left Rear (+) Orange/Light Green Left Rear (-) Light Blue/White Right Rear (+) Orange/Red Right Rear (-) Brown/Pink
Dec 30, 2008 | 1999 Ford F150 Regular Cab
Display shows pink color lines in white areas of the screen
Reinstall your VGA driver and i assume, it should be fixed if not you need to think about *********** board.
thanks
Dec 27, 2008 | Lenovo ThinkPad T61 Notebook
Color problems with moniter
check that the data cable is connected firmly, if it is check that there are no curved or brocken pins.
open the computer and firmly press on the graphic card into his socket, close coputer case.
May 04, 2008 | HP Pavilion M70 17" CRT Monitor
Pink cloud covering most of the screen
If the pink spot appears as mostly a circle in the middle if the screen then a light engine is needed. If it is an even coverage than possibly just a memory initilization needed by a technician.
Jan 13, 2007 | Hitachi 50V500 50 in. HD-Ready LCD...
Hitachi 50V500 50 in. HD-Ready LCD Television Logo
138 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
