Question about EliteGroup GeForce 6100SM-M Motherboard
Usb's dont work properly
Since last post concerning scanner not working, scanner now works thanks to p.c. world they down loaded drivers from HP
But p.c.does not find any thing that is conected to usb
    Scholar:
  • 80 Answers
Hi
Pls try all the usb ports at the front and at the back.
If it doesnt work, then go to Device Manager and then under Universal Serial Bus Controllers, uninstall all the USB Root Hubs tht you see and then restart the computer.
If this doesnt work, then trhe computer has to be serviced.
Posted on Feb 13, 2008
  • 178 Answers
Yes this is a common problem with this motherboard. The USB always goes out. You have to replace the whole motherboard
Hi my scanner is not working and my computer is a hp how do i fix it please
Make Sure Scanner is powered up and connected via USB
Connect scanner to a different USB port in your PC.
If it prompts to install driver, reinstall it with the provided drivers.
Go to Control Panel -> Devices and Printers & see if you can detect Lexmark scanner there.
If still not, you can try out a different OS or a laptop just to make sure that scanner is working properly.Post results if you tried this option.
Mar 14, 2011 | Lexmark X5150 All-In-One InkJet Printer
Have HP scanjet loaded software and driver but it just does not work checked electrical connection and usb ok thought it had gone wrong so bought new HP g2410 still cannot load checked hardware manager...
Having re-read your post it seems you have a visioneer scanner and installed HP scanjet drivers so this would definitely be an issue.
Ok, unplug usb lead between scanner and pc.
go into add/remove programs and remove any scanner software that may be showing.
load correct scanner driver (preferably the latest version from the manufacturers website).
plug in scanner usb lead when prompted and turn scanner power on.
It should then install correctly.
If usb stuff starts playing up it's usually easier to unplug it, uninstall it then re-install it using the latest drivers from the manufacturers' website. Don't just stick the disc in and re-install. Can save hours of messing about.
Apr 28, 2010 | Visioneer OneTouch 5800 Flatbed Scanner
I cannot get the drivers for my HP Scanjet 2200c. It worked in XP but now I dont have the disk. I have tried the old XP drivers and they dont work. There are no updates available under windows update or HP...
Below is the link where you can go and download the drivers and firmware for the HP Scanjet 2200C Flatbed scanner.
Click Here to download
Please let me know if you have any further questions or concerns.
Thanks.
Apr 16, 2010 | HP ScanJet 2200C Flatbed Scanner
Doesn't scan. Only print and copy. Say's no USB
Usually the scanner and printer have separate drivers, even though both are included in one machine.
Check HP's website to see if there's a separate driver for the scanner or a program which installs both drivers from the same setup program. You might have to check device manager to see if a scanner is listed and if the driver is properly installed.
In XP and VISTA, go to control panel/device manager and see if there are any yellow caution signs by the 'imaging device' icon. If there is no 'imaging device' icon, either the driver is not installed or not installed properly.
One additional factor... HP usually requires that the driver be installed before the hardware is connected. After drivers are installed, New Hardware Wizard should find your HP devices and install them properly. If not, you might want to unistall them altogether and reinstall.
Hope this helps.
Jun 15, 2009 | HP PhotoSmart C4280 Laser Printer
Down load driver for HP Scanjet3200c Flatbed scanner
http://www.scanner-drivers.com/drivers/126/126586.htm has the driver you need. The website does ask you to register- it's free. Alas, it's no longer offered on the HP website. Dowload and run it. It's an executable file, let it install choosing all the defaults and then plug in and turn on your scanner. There should be no problems as long as your scanner is still working!
Please rate my solution accordingly if it helped you. Thanks.
Jan 15, 2009 | HP ScanJet 3200C Flatbed Scanner
I dont have a cd to install hp psc 1210 all in one
Hi-
YOu can download the driver from this link, click HERE and save it on your desktop then run it afterwards to continue installation process, this link is for windows xp driver. keep me posted if you have other concerns. hope this helps, pls dont forget to rate solution.
Thanks!
Aug 17, 2008 | HP PSC 1210 All-In-One InkJet Printer
Precision Pro 3.1
You may want to try this web page that tells you how to get the HP 5300C
working in Vista. It works fine on HP 5400C as well.
'Tutorials - How to get your HP Scanjet 5300c working in Windows Vista'
(http://www.pixel2life.com/publish/tu...windows_vista/)
Jul 29, 2008 | HP Scanjet 5400c Flatbed Scanner
EliteGroup GeForce 6100SM-M Motherboard Logo
73 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
