Question about Nintendo GameCube Console
Gaming on bigscren
Came i play my gamecube on a bigscren tv without damaging the tv?
  • 167 Answers
If you enable screen burn in reduction in the wii settings you will have nothing to worry about if you pause it for a long time
Posted on Feb 25, 2008
  • 41 Answers
Well the only way you can damage a bigscreen playing a game is leaving the game paused for a long time then the image would be faded into the screen so dont leave the gamecube on for 5 hours on pause and youll be ok this goes for all game consoles
Posted on Feb 12, 2008
Does a nintendo gamecube damage a sony t.v.?
No, it will not damage your TV. It is possible for a surge of electricity, like by a lightning strike, to damage the TV and or gamecube.
Aug 05, 2012 | Nintendo GameCube Console
I have a RCA TV 2002. i CANNOT GET THE NINETO GAME CUBE TO PLAY. HOW CAN I GET TO PLAY?
You're not very clear about why you cannot get the GameCube to play, but if I may assume, it sounds as though your TV does not have the necessary input to get the game cube plugged into it.
If this is correct, you can find an RF Adapter which will work on Any TV with a coaxial (cable) input. If your TV doesn't have the red, yellow, white inputs, this will work for your gamecube and your TV:
http://store.richspsxparts.com/garfadc.html
Jun 16, 2011 | Nintendo GameCube Console
It reads the disc and when i play it crashes, sometime it does not read it.
Single Disc
The following steps are for problems with a single Game Disc or if you only own one game. If more than one game is experiencing problems, please link here.
Note: It is possible that the problem you have may be game play related. For example, if you cannot defeat a particular enemy, or are missing an item you need to complete an area, the problem is likely game play related and there is nothing wrong with your Game Disc. Please check our game play help for assistance.
  1. Ensure the disc is free of dust and contamination by cleaning it. Clean the disc with a soft, slightly damp cotton cloth (use water only). Clean the disc from center towards the edges; do not use a circular motion. DO NOT use paper.
  2. Dry the disc, using a dry portion of the cloth and wiping in the same style as you did in step 1. After all of the water is gone, let the disc sit for at least two minutes to completely dry before inserting it into the Nintendo GameCube.
  3. Check for Unlicensed products. Make sure that you're using only licensed products with your Nintendo system. Unlicensed products are not tested for compatibilty and may not work correctly with all games. Try playing the game without the unlicensed accessory.
  4. Check for specific game issues. Some games may have known issues or game play elements that appear as problems.
  5. Ensure the game is being loaded properly. With the power turned off on the system, replace the Game Disc (label side up) in the system, press down gently on the Game Disc until it locks on the center hub. Close the Disc Cover and press the power button ON to see if the game comes on the screen.
  6. Look for obvious physical damage to the disc. Remove the Game Disc and check the non-labeled side for cracks, scratches, smudges, or dirt. The Nintendo GameCube has extensive error correction capabilities and minor scratches or contamination should not cause issues in most cases. However, it is important to determine if disc damage is causing the problem.
    • If the disc is cracked
      Review our disc replacement policy to determine how to get your game replaced.
    • If it's dirty, scratched, or shows no obvious damage
      1. You may try cleaning the disc again with a soft, slightly damp cotton cloth (use water only). Clean the disc from center towards the edges; do not use a circular motion. DO NOT use paper.
      2. Make sure the game is dry, then re-insert it and see if the error occurs again.
      3. If the game had been working normally, shows signs of physical damage, and now displays errors or lockups in areas it previously didn't, the problem is likely to be the damage to the disc. Use the disc replacement policy to determine how to get your game replaced.
      4. If the game never worked or you are discovering errors in areas you have entered for the first time, it is possible that the problem could be with the system or the disc. (The system may still be the problem even if the disc shows some signs of damage.)
  7. If possible, try the disc in another Nintendo GameCube. If the disc works properly in another system, the problem is with your Nintendo GameCube. Please check out our system repair options. If the game still does not work in another system, it is likely a problem with the Game Disc. Please review our disc replacement policy to determine how to get your game replaced.
If you are not able to try the game in another system and the other troubleshooting steps haven't narrowed the problem down, it is impossible to determine for certain whether the problem is the Nintendo GameCube or Game Disc. Please contact Nintendo's Consumer Service Department at 1-800-255-3700 for assistance.
Feb 24, 2011 | Nintendo GameCube Console
I inserted my game and it said "the game disc
Single Disc
Feb 20, 2011 | Nintendo GameCube Console
I have a gamecube.on the game smashbrothers,it will play for a few moments and then it says:can't read disc,refer to gamecube manual but i don't have one.please tell me what to do.
If you are not able to try the game in another system and the other troubleshooting steps haven't narrowed the problem down, it is impossible to determine for certain whether the problem is the Nintendo GameCube or Game Disc. Please contact Nintendo's Consumer Service Department at 1-800-255-3700 begin_of_the_skype_highlighting 1-800-255-3700 end_of_the_skype_highlighting for assistance.
Jan 19, 2011 | Nintendo GameCube Console
A gamecube game is stuck in wii... Please help...
You may check out Wii Fix Guideto fix the problem yourself. This DIY guide will show Step by Steppictures to fix the problems yourself without any technical knowledge.
Jan 02, 2009 | Nintendo Wii Console
Wii/Gamecube game
Yes you can play gamecube games with no emulators. The memory card slots and controller ports are located on top.
Dec 06, 2007 | Nintendo Wii Console
Games initial load before Play Starts receive error 'cannot read disk see instruction manual'
If this happens for only some games, you should try cleaning the discs with a disc cleaner. Otherwise, you could try asking around at stores like circuit city, radioshack, best buy, etc. for what you could use to clean the lens, the part that reads the disc in your gamecube. If that doesn't work, chances are that the lens is damaged and your only hope is to send it in for repairs or get a new gamecube (or Wii).
Oct 13, 2007 | Nintendo GameCube Console
Nintendo GameCube Console Logo
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Zhenya Ogorodnikov
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
