Question about Asko D1716 Built-in Dishwasher
Mid cycle stop
The unit will not progress past either of three spots on the programme timer. If left alone it will continue with that part of the cycle forever.
The locations on the Control knob are :-
- 2 spots a click apart 1/2 way between 5 and 6.
- just past 6.
By moving the control knob along into the cycle just past the stopped point the machine continues the cycle.
The unit also gets extremely hot.
Is this a programme control timer or thermostat problem
Hoping you can assist
thanks
Max Hearne maxhearne@optushome.com.au
Thankyou I have fixed the problem. The dual thermostat with the comon connection was faulty. This prevented the timer motor from operating.
thanks again.
Max Hearne - Sydney Australia
Posted on Mar 02, 2008
    Sergeant:
  • 351 Answers
The thermostats need replacing thers 3 of them you can get to them from the front its better to take the door skin off first so you can see better then take the lower panel off.the thermostats are on the right hand side underneath.
  • 3 Answers
My Smeg pl 622-x dishwasher,(no digital display - just a mechanical timer) wouldn't advance past any heat part of a cycle ie a heated wash or drying. The thing just got hotter and went on for hours.Turned out to be a broken thermostat in the bottom of the tub. Replaced it and all worked perfectly.
Posted on Jan 06, 2012
H6 error code on a NEC NFL-1065 washing machine
see this causes, and fix it. God bless you
If the washer stops mid cycle the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer.
f the washer stops mid-cycle the main control board might be defective. This is not common. Check other causes first such as the lid or door switch and other components
f the washer stops mid cycle the water inlet valve cold water side may have failed. Most washers have a cold water rinse and so if they can't fill with cold water they just sit indefinitely waiting for the cold water to enter. If there is cold water to the water inlet valve and the cold water works in other parts of the cycle - or to make warm water - the valve is not the problem.
If the washer stops mid cycle the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design
If the washer stops mid cycle the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Sep 26, 2012 | Washing Machines
The dishwasher delays mid cycle and will stay in the same spot, just after "short wash." If allowed to just hang there, it also develops a slight rubber burning smell. If I turn the dial past...
it sounds like the timer has a worn gear and will need to be replaced if you check with your local parts distributor they are rebuildable for a lesser cost
Feb 28, 2011 | Dishwashers
It is a Bosch WFF2000. The programme stopped mid
circle at bottom right take it off there is a filter there remove it and look of obstructions.WATER WILL POURE OUT!
Jun 23, 2010 | Washing Machines
Sticking programme
This could be a problem with the controller as it is not waiting for water to warm before continuing.
Water element should be checked, as well as the water thermostat switch (which may be stuck on), possibly a substitute timer fitted to make sure you replace the right part.
Jun 06, 2010 | Neff 24 in. S4443 Built-in Dishwasher
S5N27B keeps stopping mid cycle
If the cycle doesn't complete, check these:---
Water-heating cycle Many dishwashers heat the wash and/or rinse water to a higher temperature, as the cycle calls for it. In these cycles, the dishwasher pauses after it has filled with water, waiting for the water to reach the pre-set temperature. What happens next, depends, as follows: On some units, the pause is timed and the unit continues after the allotted time. On others, the cycle can't continue until the water reaches the higher temperature. If you have this type of dishwasher and the water isn't being heated (say, because of a problem with the heating element or thermostat), after the unit stops at the heating cycle, it never continues. When you repair the heating-system problem, the "cycle problem" is fixed too. Timer Timers don't often fail. But if every other part of the dishwasher seems to be working properly and the timer knob seems to be stuck in one place--doing one function continuously--the timer may be at fault. Dishwasher timers can't be repaired. If yours is defective, replace it.
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
Dec 28, 2009 | Bosch Dishwashers
Washer stalls mid-cycle and keeps running but doesn't progress
check to see if the water is warm if not the heater has gone or the thermistor is faulty
if warm i can be a dead spot on the timer where the contacts are worn if so needs new timer
Jul 29, 2009 | Maytag Neptune MAH5500B Front Load Washer
Rotating programme unit stops mid cycle, all programmes
according to that i think the problem come from timer after you fix this problem pleas donot select your program during conncting electrical power thankyou
May 27, 2009 | Whirlpool AWM5145/2 Front Load Washer
Whirlpool washer stops in mid cycle
check the connection at the main control board top right side just remove the top
Nov 29, 2008 | Washing Machines
Bosch 3030 wash cycle does not advance beyond mid-point
The cycle timer is hanging at mid-point. You may have to replace it.
Oct 19, 2017 | Dishwashers
Asko D1716 Built-in Dishwasher Logo
515 people viewed this question
Top Asko Dishwashers Experts
John Tripp
John Tripp
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
