Question about Nokia 3110 Cellular Phone
Restarts I have a Nokia 3110 classic mobile with a micro sd card of Kingston(1GB). It restarts for three times and switches off thereafter(While card is intact/in use) otherwise it works properly(Without card). Also one of a snap clicked & stored in card is displayed correctly while the other one shows that" File format is not supported" however both the pics. are of .jpg extn. Pls help Hemant
  • 10 more comments
  • GameTheDON Feb 19, 2008
  • Anonymous Mar 03, 2008
    I have the same problem as described by Hemanth
  • satyakanth Mar 05, 2008
    I am also having the same problem which i had read from mr. hemanths comment
  • Anonymous Mar 20, 2008
  • ekanath Mar 26, 2008
    yes i bought the set 15 days back and started using kingston 1GB micro sd card started loading music files problem started as others expressed
  • imruler Mar 29, 2008
    i got nokia 3110c n thought it will work fine but it restarts again and again now i think my nokia ngage qd was a better one i updated my software version to 5.5 but still it exists can any one help me out
  • Anonymous Mar 31, 2008
    my Nokia 3110 is restarting 3-4 times after receiving files from other mobile by blutooth. what can i do? should i format my memory card or handset? if then how to format?
  • Anonymous Jul 21, 2008
    my 3110 sets gets restart momenterily for 3 times and it will switch off.
  • alazeemmobil Nov 17, 2008
    3110 rstarting
  • Anonymous Mar 24, 2009
    Sufering from same proble. this phone is a total Junk.
  • Anonymous Apr 03, 2009
    when i transfer data or videos from my computer to 3110 classic that should make asign of ? and when start in mobile it will shows file format not supported
  • Anonymous Apr 05, 2009
I think this may work.I faced the same problem(retarting& switch off).while it is getting restarted we can operate the mobile few seconds.In this small period of time u try to do the same action which u have done before u got this problem. this worked in my case.
regards,
Vineel...
Posted on Mar 04, 2008
I tried to work on it and come to one solution thougn with a lengthy procedure.
First format your card.
Click photos using Phone Memory as target folder.
Create a sub folder in your memory card.
Move your picture into that subfolder of memory card by marking the photo. Don't move the picture directly, but use the "Open Folder" function of Memory Card in Options when "Select the folder" is displayed.
Hope it works!!!!!!
Hemant
Posted on Feb 16, 2008
My memory card is not showing my pc
2 possible problems (1) your computer is not recognizing the slots which
means download new drivers or (2) our memory card is locked on most cards there is a little switch on the side lock and unlock
Sep 30, 2012 | Kingston Secure Digital MicroSD /...
How do I unwrite or copy files to a protected Kingston 8GB SD Card
Unprotect the card. SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Apr 25, 2012 | Kingston Secure Digital MicroSD /...
I need take out the write protection on my micro sd card..please help me.
There should be a small sliding switch on the side of the card. It should show a LOCK and UNLOCK or symbols as to which way to slide it. If this is not apparant, try tethering it to your computer and find it in MY COMPUTER or WINDOWS EXPLORER. Do a RIGHT CLICK on the drive and click on PROPERTIES. On that tab you will see READ ONLY checked. Uncheck it and you should be good to go. If this doesnt work, give me your results and we will figure it out.
Feb 14, 2012 | Kingston Secure Digital MicroSD /...
Where do i install on pc
You either need a card reader for the SD card or a digital camera that supports SD cards and use the camera's USB cable to connect to the computer. They also make MICRO SD card adaptors that use USB plugs to connect to that computer!
Please rate if this was helpful :)
THANK YOU
Mar 03, 2011 | Kingston Secure Digital MicroSD /...
I have a problem with switching my nokia 3110 classic answer pls!
The Problem with Nokia 3110c – Switching off and automatically restarting This is what happens. Nokia 3110 hangs, gets switched off and restarts randomly. More often, it restarts around 3 times or so and then gets switched off.
Possible Causes and Solutions Cause 1 – Phone Memory Full – Nokia 3110c mobile phone has got 9MB of internal memory.
Solution – Keep the free space between 350 to 500 KB, so as to keep things running smoothly on your phone and prevent Nokia 3110c from restarting.
Cause 2 – Changing Themes – Some people have reported that the phone restarts automatically when they try changing display themes on the phone.
Solution – Don’t get your phone loaded with too many themes downloaded from the internet or atleast, don’t switch themes frequently. These themes, mind you, also load up things into your already falling Nokia 3110c phone memory.
Cause 3 – Memory Cards – Some people have reported that Nokia 3110c restarts due to some issues with the memory card.
Solution – Remove the card, get it formatted and then insert it back and then restore factory settings. This just might solve the issue.
Cause 4 – Transferring data via Blueooth / USB data cable (or) Updating Music Library – A few people have reported that their Nokia 3110c mobile phone restarts when updating the music library.
Solution – Don’t try updating of music library frequently or don’t often transfer data in/out of your Nokia 3110c phone.
Cause 5 – MP3 files
Solution – This may seem dumb, but consider converting all your MP3 music files to WMA and then store them on the memory card. Some users suggested this.
Also try this:-----
It ll work . you dont need to go 4 the firmware v5.05
If ur phone restarted 3 or 4 times and switched off automatically. Try this
method
1] Remove the battery and Micro SD card
2] wait about 5 minutes
3] Then switch On the phone WITHOUT the memory card
Now ur phone working well without restarting
4] Then you must restore Factory settings frm the Settings Menu
[default security code:12345]
{i know most of people have done this thing,but remember u have 2 go
with the correct order.Unless it will not work.OK}
5] Now apply a theme. The theme's size should be below 100kb
6] Now ur phone working fine without the Micro SD
7] Then wait about 5 minutes and Switch off ur phone
8] Remove the battery and insert the Micro SD
{Don t Format the memory card}
9] Switch On ur Nokia 3110c phone.
10] Now Keep ur free Phone memory space [Not the memory card's free space]
between 470kb - 499kb.
Now surely ur 3110c working fine about 5
months.During these time u can
1] Send/receive any file via bluetooth.
2] Enjoy Music,video, GPRS,Yahoo Go .....etc
3] Also u can Update music library anytime.
but remember below DONTs
1] Don t try to change themes.{u have to stick with a theme}
2] Charge ur phone in ON mode
3] Dont fully discharge the battery
4] Start charging ur phone when there is only a bar on Battery indicator
5] Dont erase calender notes
Make sure about above 5 Donts
Dont worry if ur phone restarted once.{U know the problem is restarting several times
and automatically swiched off.}
After 4 or 5 month there is a possibility to occur the problem again.
if so Follow the above steps again.
Good luck
To be frank, This mobile has this as a generic problem. As I told, The problem can come back again.
Thank you Sir, Have a nice day.
Sep 21, 2009 | Nokia 3110 Cellular Phone
3110 classic hangs
s/w upgrade & mmc format.
Dec 17, 2008 | Nokia 3110 Cellular Phone
Unlock 1 GB micro sd memory card of Kingston Made
i forgot my password...pls help me unlocked. i have got nokia 6233with 1gb micro sd. i tried to give password for the sd card. but it doesnt worked. i tried it many times. one day my phone automatically got switched off. when i switched on the phone the sd card was locked and it was asking for the password..i tried many passwords but not able to open it.. what shall i do npw . is there any software or something to open the sd card.....anyone please help me.......Solve This!
Aug 23, 2008 | Nokia 6151 Cellular Phone
Nokia 3110 Cellular Phone Logo
195 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
