Question about Whirlpool GST9679P Top Load Washer
Spin problems attn drcool299 thnx for the tip but i had already chekd the spin action .... it seems to spin fine ... i also checked for blockage .... now i think it may be a pump problem cuz i took the discharge hose off the sink and put it in a bucket much lower to the floor and it worked much better ..... unfortunately when you start the next load the machine drains almost as fast as it fills..... when i went under previously to discon the hose i didnt notice any oil leakage .... but again the tub was spinning fine ..... sorry but i still cant seem to figure out how to respond without listing it as a new problem thnx
  • chris aube May 11, 2010
    do you have the hose shoved too far down the standpipe? that could cause water to siphon as it fills.
Sorry appl_doctor but i already that one too .... the hose goes into a deep sink but it wasnt in a new position since i put it in seven yrs ago ..... but just in case the sink may have been backing up i moved it to a hard pipe that then goes to the sink but the end of the pipe is waaaaay abv any posibl water level .... but low enuff for the washer to drain properly but thnx anyway .... sapperstein
Posted on Feb 18, 2008
Washer not hitting full spinning speed.
Washers have transmissions. Maybe this one has issues.
Jan 12, 2015 | Washing Machines
Another AEG e20 Plea, tried everything please help!
E20 on your machine means some sort of drain problem. If it actually goes through the spin cycle fine; some water will still not drain out at the time of the tumble dry. Check the wall drain to make sure it isn't clogged..
Check the drain of your wall, not the washer, this shd be cleaned out thoroughly; and the exit pipe of your washer should not fit too tight into it, there shd be some space for air.
This is a further tip, if helped click helped.
Apr 10, 2013 | Washing Machines
What will cause the high spin not to ingage? The lwo spin works fine.
Hi.
Principally the following:
Door lock (there is a double check on lid switch before spin)
Drain problem (Machine must end drain before spin-check blockage, rear hose, drain filter at the bottom)
Pressure switch (it determines when to end drain and start final spin).
Here a page about drain and spin problems.
If you need parts or schematics see this tip explaining how to find parts and diagrams for most appliances: Where do I find parts and diagrams for my appliance?
Regards.
Ginko
Sep 20, 2011 | Whirlpool Ultimate Care II LSQ9564J Top...
We have a whirlpool duet dryer and it will not heat up. I've checked for blockages and there doesn't seem to be any. It does spin but no heat
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Jun 29, 2011 | Whirlpool Dryers
Won't spin everything else seems fine
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Mar 27, 2011 | Washing Machines
It won't spin
heatman101
Feb 23, 2011 | Washing Machines
I am having an issue with my LG front loader washing machine model number WM1815cs. The water will not drain and the clothes will not spin out. Everything works fine until the rinse/spin cycle and it just...
Hi
Thanks for using FixYa. OE is a Drain Error which indicates that the water was not fully drained within 10 minutes. To start with check the drain pump filter for any clogs/foreign materials and try to clean the filter. Also if you have already checked the drain hose for any blockage then check the pump for any blockages, if still its not resolved then it seems to be the pump that has gone bad. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Aug 28, 2010 | LG WM1815CS Front Load Washer
Toyota camry 92. when i pump my gas the engine slowly stops.. this happens suddenly once in a while not always.. i chenged fuel pump, plugs, sensor, chekd distributor, chekd controller.. washed my fuel...
This symptom indicates that there is not a correct ratio of air to fuel ratio of 14.6. When more gas is given, there must be more air available to make up the golden ratio of 14.6 to have good mixture for good combustions. You already check for fuel supply, the next thing is to check the air supply. Check out air filter, clean the throttle valve, Air mass flow controller. If all of these didn't make an improvement then the last thing is the Fuel distribution calibration. Cheers.
Aug 17, 2010 | 1992 Toyota Camry V6
Zanussi fs1455w not spinning fast under load. Without anything in the drum it spins fine??? Tried all speeds with the same result. Any ideas???
May be not pumping efficently. when the spin starts the initial rush of water floods into the drum from the clothes a build up of water under the drum causes a braking action on the drum and slow spin speed.. look for partial blockage in pump chamber hoses or under sink if a spigot connection. probably not the belt as it would throw off a loose belt. Check it anyway. if non of these check carbon brushes they may on the verge of failure.
Jul 23, 2010 | Zanussi FS1455W Front Load Washer
Whirlpool GST9679P Top Load Washer Logo
53 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
