Related Tags:
This problem should be removed because:
Problem with Bissell 7901-1 ProHeat Scotchgard Upright Wet/Dry Vacuum
Bissell Proheat 7901 has continual leakage from
Bissell Proheat 7901 carpet shampooer has continual leakage from the spray heads after the trigger has been released. In disassembling the machine, the tubes to (before) the switch (in the handle) are charged, but all tubing between the switch and the spray heads is empty. Is there something about the switch that would be allowing air into the line? Or the tubing at the switch? Or. . . ?
Solutions (1)
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
456wet
Bissell Proheat Pro-Tech #7901 will not spray any...
Bissell Proheat Pro-Tech Mod #7901 Will not spray any liquid to the carpet and red cross indicator is not turning It is not spraying either...
my bissell proheat rug shampooer wont wet carpet...
my bissell proheat wont spray solution on carpet, What is the procedure to clean / repair it?
My bissell7901 is spraying water out by the wheels
My bissel 7901 is spraying water out by the wheels and not picking it up from the carpet...How do you remove the bottom to see what the...
Bissell 7901-b proheat cleaner, will not **** up
Bissell 7901-b proheat cleaner, will not **** up water from carpet. What can I try to fix the problem. Did not realize it until I went to...
Add Your Solution
need manual and scamatics for oreck carpet...
need manual and scamatics for oreck carpet shampooerWhat's your problem?
hand attachment does not spray
The water does not seem to spray.
Bissel proheat 7901 rear wheel broke off. How do...
The rear wheel cracked and eventually broke off after a recent move. Axle is still in place.
Manual, anyone?
Does anyone have a manual for a Bissell SC Carpet Extractor 1632?
See all Bissell 7901-1 ProHeat Scotchgard Upright Wet/Dry Problems
Fix-O-Meter
65
65 people viewed this problem
- 0 people are following this problem. Be the first!
Top Bissell Vacuum Experts
Verification:
Please enter the characters below to complete your post
Can't read it? Try a different one
