Question about Microsoft Xbox 360 Console
Xbox giving white page
I turn my x box on just fine, but then when i put the cd in there, it says: To play this disc, put it in an x box 360 console, when it was already in it. So i don't really know what to do, and i tried other discs to see if it was the disc, but it wasn't the disc... so is my x box 360 messed up?
  • skippy8 Feb 13, 2008
    i turn my x box on just fine, but then when i put the cd in there, it
    box 360 messed up?
Its screwed
Posted on Feb 13, 2008
My xbox work read copy games or originals
Did you try to flash the X-BOX drive with the j-tag exploit, if yes then it must have not run successfully , if you have not dont do it as it will just ruin your console if you donot know what you are doing. Try using a Cd-Lens cleaner as your DVD-Lens might be dirty and could be a cause. Does the disk spin when it is inserted into the drive ?
Clear your system cacheIf your Xbox 360 console can't play multiple game discs, try clearing your system cache. Here's how:
  1. On the console, go to My Xbox, and then select System Settings.
  2. Select Memory.
  3. Highlight any storage device, and then press Y on your controller.
  4. Select Clear System Cache.
    Note If Clear System Cache is not available, follow the steps in Clearing the System Cache (http://support.xbox.com/en-us/pages/xbox-360/troubleshoot/hardware/clear-system-cache.aspx) .
  5. Try to play a game disc.
Disconnect memory units or USB flash drives
  1. Turn off your console.
  2. Unplug any memory units or USB flash drives attached to your console.
  3. Turn on your console.
  4. Try playing a game.
If all these fail try this
http://support.xbox.com/en-us/pages/xbox-360/troubleshoot/hardware/disc-drive-wizard.aspx
Mar 04, 2011 | Video Game Consoles & Games
XBOX 360 cd rom is not reading discs
1. Make sure you REMOVE any discs from your XBOX' tray. 3. Turn on the console again, either by using the controller or the POWER button (NOT the EJECT button) and WAIT for the initial XBOX setup. ... This fixes the OPEN TRAY error 100 % of the time on my XBOX 360. XBOX 360 cd rom is not reading discs Google Search
Jan 13, 2018 | Microsoft Xbox 360 Console
X-box 360 screen says " to play this disc put in xbox 360 console"
That might be something related to your Xbox 360 console itself or the disc you are trying to play on, so first have a look on the Xbox 360 game disc itself and check whether there is any kind of scratches or flaws on it.
If you find a scratch or a flaw on the disc that seems to be the reason and just to check it you can put any other game in your Xbox 360 console and try it once more, if the other game is working fine that definitely assures that it's a fault with the game disc & check on the scratched discs page on our web site for more information about the reason for this issue to occur.
In case there is no scratch or a flaw on the game disc try the following steps:
1- With no discs in the disc tray, go to the System section on the dashboard.
2- Select Console Settings.
3- Select Start Up.
4- Make sure it is set to Disc not dashboard.
If it is set to dashboard, select Disc and try the game again. It should work.
If is already set to disc or you tried setting it to Disc and still not working try the following steps:
1. Just clean the disc & put it back in your Xbox 360 console and see whether it's going to work again or not.
2. If it's still not working try also another discs to know whether it's an issue with the actual Xbox 360 console then or not.
3. If the other discs work fine you can try it then without the hard drive because it might also be something related to the hard drive.
4. If it is still not working so this game disc would be for sure faulty and you have the right to exchange it from the retailer you bought it from as it's not scratched.
In all cases if other game discs are giving you the same error message "To play this disc, put it in an Xbox 360 console" you need then to contact Xbox 360 customer support to send your console to get repaired or exchanged.
Aug 29, 2009 | Microsoft Xbox 360 Console
Will not play games
Make sure discs are not scratched. Try cleaning the discs using rubbing alcohol and a soft cloth.
Jan 31, 2009 | Microsoft Xbox 360 Console
Will not play a game
this usually happens to bad/damaged/dirty game disks. try cleaning the disks. if that doesn't work, contact microsoft via xbox.com/support.
When i put a game in and play for a minute then it says this disc is unreadable turn off console. i did that and it still says the same thing
CHECK THE DISKS FOR AND WHITE MARKS.
IF THERE ARE WHITE MARKS ON THE DISK THESE ARE LASER MARKS FROM THE XBOX 360 BEEN MOVED WHILE A DISK WAS PLAYING IN THE CONSOLE.
IF THERE ARE NO MARKS ON THE DISK UR CD LENS NEEDS CLEANED. IF U HAVE DONE ALL OF THE ABOVE AND IT STILL DOES THE SAME THING UR XBOX 360 MAY BE FAULTY.
GO TO WWW.XBOX.COM
AND CLICK ON THE SURPPORT LINK
Dec 11, 2008 | Microsoft Xbox 360 Console
Disc wont read
Hi
Are you using a modded Xbox 360 console?, if not then the disc you are trying to play is probably a copied Xbox 360 disc which would not work on an original Xbox 360
Regards
KreativeGeek
http://gamingbox.wordpress.com
Aug 30, 2008 | Microsoft Xbox 360 Console
Help Me!
the disc is broken look at it closey for scartches are look for a big ring around the disc. then clean the disc.
Jun 19, 2008 | Microsoft Xbox 360 Console
XBOX 360
Try using a cd lens cleaner in the XBox 360 dvd drive, and make sure the game cd does not have scratches.
Nov 06, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
49 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
