How can I remove the doubling of letters in my Pro-200? Picture is fine but when letters come out, there is a double image of the letters. I lost my remote and I cannot find a menu button to calibrate of try to fix it.
-   I have letters shadowing red on top of green, also in the middle of the screen from left middle then curving down to the right of the screen looks like a almost transparent blue twisted ribbon. looks like the words that are on the tv is twisted up in it it as well. but when the movie has dark colors the ribbon seems to disappear where it is dark and ever present when the screen is light. how ever the picture on the tv is good.And yes the remote is gone in the move.-   kweenEl
You need to use the convergence feature for your set. What this is is
having the three color guns aligned properly, There is hopefully an
automatic adjustment on your set-up menu, if not adjustments for each
seperate gun. Basically you adjust the lines of the adjustment screen
so the line turns black and white. You can easily see what needs it.
If this needs to be done manually, it is a chore. Contact me for
directions how to do this. It is best left to a pro but this can get
costly and wouldn't hurt if you tried yourself as if someone comes in,
the cost would be the same whether it is out slightly or severely.
Pioneer Elite Pro 118: 1) Bottom half picture only with Red/Green/Blue across middle, no upper half...
(More)
Pioneer Elite Pro 118: 1) Bottom half picture only with Red/Green/Blue across middle, no upper half picture. 2) Now... Standy by only, no green power light. Does the Is IC SANYO IC 15-PIN SIP 2 CHANNEL VID CONVER CRXN CKT I.C, part # Sanyo STK4274 need to be replaced? Thanks!
Lost A/V with a pop. After I turn the TV off, when I push the power button, I get the red light,...
(More)
Lost A/V with a pop. After I turn the TV off, when I push the power button, I get the red light, followed by green, but then it clicks back to red immediately. Unplugging and waiting does not change the situation. Other postings note either a bad pcb or bad soldering on the pcb. Is this the likely problem?
Now its stuck in standby mode. None of the buttons do anyhing but the main power button. It keeps...
(More)
Now its stuck in standby mode. None of the buttons do anyhing but the main power button. It keeps blinking that stupid red light.
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
