Question about Motorola Mobility MOTOKRZR K1 Cellular Phone
KRZR Doesn't Stay on Line
My Krzr cycles through no service, to on line, to a blank screen. It doesn't charge but for an hour. I've tried removing and replacing the battery but that made no difference. I can't text because the dropped service erases what I've typed before I can send. Have you seen this, is there a fix, do I go get a new phone?
  • PBlair Feb 15, 2008
    I t turns out I was able to fix the problem by emptying my message box. I'm not sure how this effected the power and charging, but, once I cleaned out the memory, it started working like new.
    Brigadier General:
  • 7,752 Answers
Have the firmware reflash, so take it to a mobile service center and have it reflash.
Posted on Feb 12, 2008
I need a subsidy passwork for a Rogers Motorola krzr k1 IMEI 359206011317237
It is very simple to get Subsidy Code for Motorola KRZR K1 Phone....Visit the site
Theunlockarena.com get Subsidy Code and unlock it easily.
Motorola KRZR K1 Unlocking InstructionsWarning : Do not enter any wrong unlock codes on your Motorola KRZR K1 mobile phones. If you enter over a certain amount of wrong unlock codes on your Motorola KRZR K1 mobile phone, your phone may get hard locked and sometimes become unusable.
1 - Switch ON your Motorola KRZR K1 with a NOT ACCEPTED SIM Card,
2 - Phone will display "Enter Special Code",
3 - You can now enter the Unlock Code.
NOT ACCEPTED: We mean, to use a sim card from a network other than the network your Motorola KRZR K1 is locked to.
WARNING: If one of theses messages appear :
- "Contact Service Provider"
- "Tampert Alter"
- "Wait before enter special Code"
- "Contact Service'
It's because you or somebody already entered too many wrong codes, you just have to leave the Motorola KRZR K1 ON with the errors message and after 40 minutes to 2 hours the message "Enter Code Special" will appear again!
Nov 03, 2012 | Motorola Cell Phones
I have 2 motorola phones........the v195 and the krzr but when i try to charger both..........they not taking the charge. i tried removing the battery and everything. PLZ HELP
Try getting a mini-usb cable and connecting it to your pc- either that, get a second Motorola charger. I suspect that the charger you currently have is defective- it is rare for two pieces of equipment to show the exact same issue
Nov 22, 2010 | Motorola Mobility KRZR K1 Cellular Phone
My krzr k1m's screen is completely white, why!?
well, i guess, the phone fails to load it's software or firmware. anyway, if you don't know how to flash your phone, and you don't have the back up firmware for it, go to your nearest service center and have it reflashed. at least there, you can rest assure that they will give you the appropriate firmware for your phone.
Feb 06, 2010 | Motorola Mobility KRZR K1m Cellular Phone
My krzr had a drink spilled on it last night. I dried it out and it still turns on, all my contacts and stuff are there. But i cant get service or get it to charge. Can i fix it or no?
well you might try and take out the battery,,and remove as many covers as you can,then put the phone in a plastic bag full of white rice..it could dry up the moister..as rice does absorb it..i have seen this work
Nov 14, 2009 | Motorola Mobility KRZR K1m Cellular Phone
WHAT DO I DO IF A CUSTOMER CAN ACCESS THE WEB BUT CANNOT SEND OR RECEIVE MMS ON HIS KRZR PHONE?
Check the MMS settings...
1. Click your Menu
2. Click Settings
3. Click WEB ACCESS
4. Click Web Sessions
5. Click [New Entry]
Fill in the following fields: (some of the fields may already be setup)
Homepage: http://mmsc.mobile.attwireless.net
Gateway IP: 10.250.250.55
Port 1: 8080
Domain 1: blank
Service Type 1: HTTP
Gateway IP 2: 000.000.000.000
Port 2: 0
Domain 2: blank
Service Type 2 WAP
DNS 1: 000.000.000.000
DNS 2: 000.000.000.000
Time out: 5 Minutes
CSD no 1: Blank
Username: 1: blank
Password 1: blank
Speed (Bps) 9600
Line Type 1: ISDN
CSD no 2: blank
User Name 2: blank
Password 2 blank
Speed (Bps) 2: 9600
Line Type 2: ISDN
GPRS APN: proxy
User Name:blank
Password:blank
Press the left soft key 4 times to return to the main menu.
Scroll to and select Messages.
Press Menu.
Scroll to and select Inbox Setup.
Scroll to and select MMS Message Setup.
Scroll to and select Server Info.
Scroll to "AT&T MMS", then press Menu.
Scroll to and select Edit.
Validate the following settings:
Service Name: AT&T MMS
Server Name: http://mmsc.mobile.attwireless.net
Web Session Name: AT&T MMS
Oct 14, 2009 | Motorola Mobility KRZR K1 Cellular Phone
Blank or White screen on new Motorola Krzr k1 cell phone
i am having a same problem with my krzr phone. it is picking up the screen. solve if you can
May 27, 2009 | Motorola Mobility MOTOKRZR K1 Cellular...
I need the default unlock code for my motorola krzr cell phone
Try the last 4 digits of your phone number.  If that doesn't work call costomer service and they should be able to help.
May 21, 2009 | Motorola Mobility KRZR K1 Cellular Phone
Take the phone to a mobile service center and have the flexcable replaced on the phone.
Dec 04, 2008 | Motorola Mobility MOTOKRZR K1 Cellular...
its the FLEX CABLE! need to change it..the cable that connects the LCD screen to the main motherboard
Sep 07, 2008 | Motorola Mobility MOTOKRZR K1 Cellular...
If the phone still works, check to see if the left side of the hinge (when the phone is open and facing you) is loose. If you can wiggle the top 1/2 of the phone, the hinge is damaged, therefore damaging the flex cable that runs through it. If that is the case, replace the hinge assembly and the flex and you're good.
The K1 is no joke to take apart. Flex replacement requires full disassembly. I would recommend checking out www.wirelessunlimitedinc.com, or www.myspace.com/wirelessunlimited to have it done professionally, less than Motorola will charge you.
Or give it a shot if you want, you need a T5 Torx and lots of patience and care.
Jul 31, 2008 | Motorola Mobility MOTOKRZR K1 Cellular...
Motorola Mobility MOTOKRZR K1 Cellular Phone Logo
32 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
