Well code 128 is for a thermostat problem in the fact the engine is not reaching normal temp. If you have heat the engine is warming up but still may not be getting to normal range. Normal is 190 - 210 degrees.
I would replace the thermostat first and see what happens.
Is the air temperature control blend door working correctly check that and then also check to see if the cars engine is reaching proper temperature, you may have a stuck open thermostat.
Sounds like ?? If the compressor is running and the system is full of freon, you may have a blend door problem under the dash. The blend door directs air flow thru the heater core and evaporator core depending on the temp setting on the dash.
Hello. The most common cause for no heat is the thermostat. This is a quick and easy repair. Go to any autozone or similar parts store for the part. They may even install it for you.
