Question about Canon PIXMA iP4300 InkJet Photo Printer
How do I print Cds
Printer only prints part of the cd
  • 148 Answers
Try printing your cd to other printer. If it print ok then your printer is defective if not then the Cd is the problem
Posted on Mar 21, 2008
Epson Artisan 1430 How do I print labels onto CDs?
Hi Joe
for most printers there should be a print cd label option in the Software that comes with the printer
install the Software and go to label settings >>CD label
Mar 23, 2014 | Epson Artisan 1430 Wireless Wide-format...
What printers support "PrintOn" direct on-disc printing?
Cant give you a full list, but the Pixma series from Canon does.
Apr 15, 2008 | Roxio Easy CD & DVD Creator 6...
I have pixma mx300 Can I print CD labels? Thanks Bryan Will my Cannon Pixma MX300 print Cd Labels.For standard printing the paper is fed from the back.
You can print adhesive sheet labels (such as avery 5931/8931) with no problems. Some canon printers will also print directly on CDs; check this website: http://damnprinter.com/. They have lists of printers that will work and pretty good instructions. I didn't see the MP300 listed. I managed to get a canon 6600D printer to print directly onto CDs, but I had to buy a tray (ebay-$12.00) and it took about an hour to convince it to do the job. The website says to follow the steps "several" times if necessary; it took a while.
Aug 03, 2009 | Canon Office Equipment & Supplies
My hp photosmart c5580 won't print the correct ink color on dvds
Unless a printer is specifically designed to PRINT on CDs or DVDS, that's the problem. Usually a program called "LightScribe" is used to print on CDs or DVDs right in your DVD/CD Drive. For printers, use a Self Adhesive DVD/CD PAPER Label(s) that you can buy in the store. Inserting DVDs or CDs through a printer can really mess them up and Damage the rollers inside!
Jun 11, 2009 | HP Photosmart C5180 All-In-One InkJet...
Epson stylus r1800 problem with printing on cd/dvd
Try this :
Disconnect the printer from the computer.
Turn it off & make sure the CD/DVD tray is closed then turn it back on.
Here's generic instruction for you:
If you are receiving an error pertaining to the CD TRAY NOT BEING INSERTED CORRECTLY, please do the following:
Recommendations:
-Don't force the CD/DVD tray into the printer.
-Make sure your printer is powered on, and the output tray is in the upper position.
-Please ensure there is at least 3 inches of space behind the printer, or the CD tray may eject.
Included, are the correct CD/DVD loading instructions. Please follow the instructions below:
CD/DVD LOADING:
1. Ensure the printer is powered on. Remove any paper from the sheet feeder.
2. Push in the paper support extension on the printer, and close the paper support.
3. Push in the output tray extensions, but leave the tray open.
4. Lift the output tray. Place one hand on the top of the printer, and pull up on the output tray until it stops. Lay the tray down in the upper position.
5. Place the CD or DVD into the CD TRAY with the white (or printable) side facing up. Note: To print on small 8cm CDs, please place the small CD ring on the tray first, then place the CD inside the ring.
6. Slide the tray into the tray guides located in the output tray. Push in the guide until the arrow on the tray matches up to the arrow on the tray guide.
7. Press the PAPER button to load the CD/DVD into the printing position. The CD is correctly loaded when the printer's POWER button stops flashing.
General tips for CD and DVD printing:
-Burn data/video/images onto CDs or DVDs before attempting to print on them.
-Do not use thermal-printable or regular CDs or DVDs in the printer.
-Moisture or fingerprints on the printable surface of the CD may cause marks or smearing to appear after printing.
-All printable inkjet media is different. Some surfaces will absorb ink better than others. If output appears banded, faded, or streaky, print a Nozzle Check pattern to confirm that all colors of ink are printing completely. If the ink does not completely dry or smears after 24 hours curing time, you may need to use the Epson Print CD tools to adjust (lower) the print density.
-The only supported resolution for CD/DVD printing is 1440 dpi (aka "Photo")
-Borderless printing and printing on the "inner circle" (plastic around central hole) of CDs is not supported.
-Do not use the "print preview" feature provided by the Epson printer driver as it will only show the image on a blank field and does not offer a clear indicator of where the image will print.
-The Epson Print CD software works best with JPG images and may not import some TIFF images.
Sep 26, 2008 | Epson Stylus Photo R1800 InkJet Printer
I cant print on cds
clare.... are you putting the actual cd into the printer ?
Robert
Sep 18, 2008 | Epson Printer
PRINTINGON CDS
Usually, the CD for ROXIO is came with the box when you purchase the product. You can install that SW and you can print or label a CD without any hassle. Again, the CD called ROXIO Software.
Thank you so much.
adonscott
Jun 22, 2008 | HP Photosmart C5180 All-In-One InkJet...
I Purchased new HP notebook - with vista operating system today. Loaded driver for my Konica Minolta 2530 DL from cd provided with printer. Indicated it was successfull. The printer indicates ready and...
that's a printer settings issue...when you open the print dialogue..go to print preferences, and make sure you are selecting the printer, and NOT print to file
Apr 27, 2008 | HP DeskJet F380 All-In-One Printer
Epson 1800- trouble printing cds
Try to print on a sample or spare CD, before that Click Print Position Confirmation Pattern in the Print Confirmation Pattern section.Click Print to print the confirmation pattern on the disc and remove disc..
--Using a metric ruler, measure the distance from the hole to the cross marks labeled A and B. On print cd application click file and click print and select adjust print position, click enter values then select the distance for A into the height (top) box and distance for B in the width (right) box then click on ok
Mar 14, 2008 | Epson Stylus Photo R1800 InkJet Printer
Will not print cd covers
Describe what YOU call CD covers? There is an anomaly here. Are you simply printing onto a4 paper for jewel case inserts or do you mean actually printing onto the CD.
Jun 16, 2007 | Epson RX620 All-In-One InkJet Photo...
Canon PIXMA  iP4300 InkJet Photo Printer Logo
32 people viewed this question
old marine
old marine
